New to me: 2014 Tacoma D-4D
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaD4D, Dec 29, 2021.
  1. Jan 5, 2022 at 5:15 AM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have a feeling they will be able to straighten things out.
  2. Jan 5, 2022 at 6:32 AM
    #42
    fresyota
    fresyota Well-Known Member
    2013 Tacoma Base Access Cab 4x4 2.7 A/T
    Their website says take it to a Volkswagen dealer, motor is similar to Volkswagen diesels.
    2015WhiteOR likes this.
  3. Jan 5, 2022 at 6:54 AM
    #43
    TacomaD4D
    TacomaD4D [OP] Well-Known Member
    Central TX
    2014 Tacoma TRD D-4D
    DieselToys engine swap Lots more to come….
    I read that yesterday too…..but I’m only 45 mins away from DT. Seems like it would make better sense. I’m sure it would cut down on diagnosis time. I would love to have Todd’s genius mechanic brain right about now. At this point I would pay just to talk to him about this build. Sent an email to them couple of days ago…awaiting response.
    Torspd likes this.
  4. Jan 5, 2022 at 6:32 PM
    #44
    TacoTuesday1
    FL
    I wonder how it communicates. OBD2 seems like a US EPA thing.
    VW is just one of many with small diesels. 3L V6, I4's in Jetta/Golf, etc.
    Benz as well such as I6 CDI's, V6 BlueTec, etc.
    Interesting, looks like going forward they're looking at changing the swap to GM 3L
    which may come in Ram, Gladiator, Wrangler - not sure what GMC/Chevy Colorado/Bison uses
    might be an easier swap if those vehicles end up totaled. Parts available stateside, communicated on OBD2, etc. but would come with newer crap like adblue
    TacomaD4D[OP] and 2015WhiteOR like this.
  5. Jan 5, 2022 at 6:58 PM
    #45
    fresyota
    I had a '98 VW with a 1.9 TDI. When it ran it was the greatest thing in the world. 90hp and I could go up the Grapevine without downshifting with the cruise set, 40+ mpg no matter how or where I drove it. When it broke nobody around here knew how to fix it and charged you out the ass to try and fail.
  6. Jan 6, 2022 at 4:45 AM
    #46
    TacomaD4D
    Central TX
    It has an OBD2 port but the computer wouldn't connect to the vehicle. One of the DT youtube videos clearly shows a scanner connecting to a 4runner for diagnostics and even a laptop cable.
    Torspd likes this.
  7. Jan 7, 2022 at 10:46 PM
    #47
    TacoTuesday1
    FL
    the fact they said take it to a VW dealer suggests the D4D is either a rebadged VW 1.9L TDI ALH, or copy of it.
    Seems like something that would be cheaper to swap in than paying $20k.
    Not hard to find that engine in a junkyard stateside for less than a few grand
    there's a thread on TDIclub of a guy swapping BHW into his 2nd gen (probably later TDI that replaced ALH)
    https://forums.tdiclub.com/index.php?threads/2nd-gen-tacoma-bhw-swap.516662/
    + ALH has turbo, not sure if D4D does
    more power is Audi/VW/Porsche 3L V6 TDI
    cars have reached their expiration date. Fix leaking upper oil pan is $10k+. Only reason people keep them is because warranty extension pays for that.
    When the extension eventually runs out, they will sell the cars even cheaper.
    But many or all have adblue
    tuned = 426 ft lbs torque
    Taco 422 and Torspd like this.
  8. Feb 2, 2022 at 5:46 AM
    #48
    TacomaD4D
    Central TX
    Found out from DieselToys that this truck needs at least one new injector and wire harness repair based on when the previous owner took it in last year.
    Towing it in to them this morning to start diagnosis and repair. So grateful Todd worked to fit me in!!
    Sub_Par, JimIowa, Rick's 2012 and 4 others like this.
  9. Feb 2, 2022 at 5:53 AM
    #49
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Subbed.
  10. Oct 25, 2022 at 6:09 PM
    #50
    TacomaD4D
    Central TX
    Got really busy with life and purchased a new house that needed a full renovation.
    This tacoma was thrown on the back burner for a while.
    I am proud to say I drove 45 mins home for the first time today with zero issues.
    Diesel Toys got it hooked back up!
    Rick's 2012, Torspd, nd4spdbh and 4 others like this.
  11. Oct 25, 2022 at 6:51 PM
    #51
    aggr0crag
    aggr0crag Well-Known Member
    19 DCSB 4x4 Sport M/T
    What all had to be done to get it road worthy again?
  12. Oct 25, 2022 at 8:04 PM
    #52
    TacomaD4D
    Central TX
    Reliability was a big concern and still is so I really hope it proves itself.
    Wiring harness, injectors, high pressure fuel pump, etc
    aggr0crag likes this.
  13. Oct 25, 2022 at 8:06 PM
    #53
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I'm curious if the previous owner thought they could do their own work and got it in that mess.
  14. Oct 25, 2022 at 8:19 PM
    #54
    TacomaD4D
    Central TX
    Diesel Toys had information from the previous owner and the known issues. Its likely that he didn't have the cash to fix it and dumped it at the dealership.
    Either way its done now... Wasn't cheap but I got a good deal on the truck.
    I will say that the work that was completed at DT looks professional.
    Let's see how it holds up.
  15. Oct 25, 2022 at 8:36 PM
    #55
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    an OP with an epic story.... THAT CAME BACK TO TELL THE ENDING!!!! This is a miracle!
    26k for a DT swaped D4D tacoma stateside is a FUGGIN COME UP. That is a neat rig OP. Im sure once the random issues have been sorted the thing will serve you good for a LONG time.
  16. Nov 28, 2022 at 6:58 PM
    #56
    TacomaD4D
    Central TX
    30 day follow up...I have now put over 2,000 miles on this rig.
    Averaging about 26 mpg with 32" tires, lift, and front bumper. Lowest I have seen is 24 mpg
    Working on sourcing 1KD-FTV spare parts from ebay (belts, hoses, alt, wtr pmp)
    #56
  17. Nov 28, 2022 at 7:15 PM
    #57
    2015WhiteOR
    Gainesville TX
    That's totally the MPG these trucks should have gotten from factory with the 1GR V6, given their size. Jealous!
    TacomaD4D[OP] and YotaProject like this.
  18. Nov 28, 2022 at 7:36 PM
    #58
    Braddman
    Braddman Member
    Brad
    Southern Ontario, Canada
    2005 Tacoma 2.0L TDI
    2L BHW VW TDI Swapped
    That sounds pretty accurate. I averaged 25mpg in my 2L VW TDI swapped Tacoma on 35s with a 2” lift. My truck was tagged on post #49. I have put 49,000km on the diesel until I burned a hole in #3 piston from excessive engine load and exhaust gas temp. Now I’m swapping a 3L TDI into it for improved reliability.
    @werleyr20 If you didn’t already know you should be able to order European Toyota parts at your local dealer. I ordered a clutch friction disc from a 2019 2.8 D4D Hilux to install in my Tacoma from my local dealer in Ontario, Canada. That dealer couldn’t lookup the part diagrams but as long as I gave them the part numbers as referenced online. They were able to order them. It did take 2 weeks to receive it but at least they were able to order it.
    TacomaD4D[OP] likes this.
  19. Nov 28, 2022 at 7:55 PM
    #59
    TacomaD4D
    Central TX
    Beautiful work and truck!! @Braddman
    I wish I was more mechanically inclined but swaps are way out of my league. I have noticed that lots of D4D parts can be ordered through the Toyota dealership or can be had stateside. Even found a cross referenced serpentine belt with Prime shipping
    Braddman likes this.
  20. Jun 17, 2023 at 11:34 AM
    #60
    TacomaD4D
    Central TX
    10,000 mile update!
    Zero issues and I love the truck.
    Lost 1mpg when I added the Fab Fours Premium front bumper.
    Also added some creature comforts (Clazzio covers, Seat Heaters, Audio upgrade, OEM power sliding rear window)
    Toyko Joe and banditcamp like this.
