New to me 2019 sr5 a few noise questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dogodell, Oct 15, 2021.
  1. Oct 15, 2021 at 6:20 AM
    dogodell
    dogodell [OP] Active Member
    2019 Tacoma SR
    Hello, been doing a lot of reading and still had a few questions about two noises Before I get yelled at YES I know it's a noisy engine! And yes it's headed to device dept soon (drip from oil drain plug where they reused bung and doesn't appear to have a washer on it?)
    I have only had the truck about a week 25k on it and it has gotten louder since purchased. Have a rather bad knocking sound seems to be coming from driver's side back of engine at times sounds like my old Ford diesel other times only can hear it with windows up radio off from in cabin. When it's at it's worst it gets quieter/ goes away when I step on or pump the brakes. Didn't bother take a video but this same sound https://youtu.be/QbmsXB_fGKM
    Bad vacuum pump or normal loud vacuum pump?
    Also a fairly quiet almost wooshing sound louder with a/c on kind of cycles on and off? Not a big deal just curious.
    Sorry for the long post like the truck so far just trying to figure out some of its quirks. Thanks
  2. Oct 15, 2021 at 11:57 AM
    dogodell
    2019 Tacoma SR
    If anybody wants guess at it or reassure me a little more detail....
    Noise is always there just usually much quieter (normal I think) then gets loud randomly. Might not do it all day might start doing it halfway through drive on the highway might do it right off when starting cold.
    When it's loud can turn radio up around 18 before you stop being able to hear it...
    Much louder with windows rolled up? ( Part that really confuses me)
  3. Oct 15, 2021 at 12:05 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    If you are in park and rev up the engine does the noise increase along with the revs?
  4. Oct 15, 2021 at 12:12 PM
    dogodell
    2019 Tacoma SR
    Yes it does gets louder and faster matches revs
  5. Oct 15, 2021 at 2:46 PM
    vivid02
    Edwin
    SoCal
    OEM+
    Might be one of the pulleys going out.
  6. Oct 15, 2021 at 3:14 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It sounds like valve noise, but I have no idea why pumping the brakes would affect that.
  7. Oct 15, 2021 at 4:09 PM
    dogodell
    2019 Tacoma SR
    Thought rod at first due to sudden onset (have since scoped to top end) and then valve but have never had one be intermittent before?
    Do these 3.5s have hydraulic lifters or shims like the other recent Toyota?
    If dealership won't take an in depth look will stick sensors by pulleys tomorrow afternoon and go for a drive if shops not too busy
  8. Oct 15, 2021 at 7:48 PM
    mrbetelman
    mrbetelman Active Member
    Santa Cruz, CA
    2019 Dark Gray Access Cab SR
    16X9 black TRD wheels Turn signal mirrors w/ MESO sequentials (had to hardwire these as no factory harness) Full interior LED upgrade Full Taillight LED upgrade Intermittent wiper stalk added Kicker 47KSC6904 & Subaru tweeters up front Kicker 47KSC6704 in the rear (had to hardwire these as no factory harness) Alpine S-A32F Amplifier Upgrades on the horizon: Subwoofer TBD CaliRaised Molle system for the bed Hiline Series Front Bumper
    Every time I've ever heard that noise, it was a sticky lifter or a lifter that wasn't getting oil. Either way, When's the last time the oil was changed and what are you using...?
  9. Oct 15, 2021 at 9:04 PM
    dogodell
    2019 Tacoma SR
    Should be oem 0-20w. Dealer took it in a few weeks ago and did all fluids before I bought it last weekend everything looks brand new and correct levels.
  10. Oct 15, 2021 at 10:06 PM
    County 37
    County 37 Active Member
    Minnesota
    2019 SR-5, Access cab, Quicksand - Kenwood TM-D700A
    Does the overhead cam 3.5 have lifters of any kind? What sounds like lifter noise may indicate normal cleaning. Noisy, but normal.
  11. Oct 16, 2021 at 4:45 AM
    dogodell
    2019 Tacoma SR
    I can live with it if it's normal just don't like unexplained noises... will check what's been brought up so far today if works not too busy
    Answered my own question about lifters ran the serial # off a head at the shop I knew the older 3.5s had mini lifters/ hydraulic tappets under the rockers but wasn't sure if they had changed to solid like a few others
    Had to buy this in a hurry so playing catch up with research and questions now. Thanks everyone for taking time to respond and help.
  12. Oct 19, 2021 at 3:55 PM
    dogodell
    2019 Tacoma SR
    On the off chance that someone else find this in the future. Dealerships conclusion was mostly normal loud engine/ injector noise and vaccum pump on the way out (intermittent louder noise). Changed it out and it definitely helped quiet things down for now. Hopefully good to go for another 300k or so.
    Thanks for the help everyone
