New to me 95
Discussion in '1st Gen. Tacomas (1995-2004)' started by rcbs204, Nov 10, 2019.
  1. Nov 11, 2019 at 3:42 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    $4100
  2. Nov 11, 2019 at 4:20 PM
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    Seems to be the going rate for these trucks.
  3. Nov 12, 2019 at 7:41 PM
    rcbs204
    Hi Gang,
    I need a little advice from my Toyota Pickup owners. It appears that this truck has been lifted via the torsion bars, about 2" in the front. I am certian that this is what took out the CV joints that I just replaced because the the A arm is about 1/2" from the upper bump stop. Lowering to stock in the front is rather straight forward. The back on the other hand the previous owner must have changed the leaf pack becasue there is no add on's or blocks. Can I get some pics of a stock height 1995 Pickup rear springs if anybody might have one.
    I looked on the interwebs and it tells me that the top of the 15" rim to the fender in the front should be 13.5" and the back should be 11.5" the back seems low to me but I just don't know this little truck yet. Any stock truck owners out there would be a great help.
    The leaf spring currently installed in the back has 5 leafs and is 2" thick. The stock springs I found online say they are 1 7/16 thick 4 leafs. Thoughts?
  4. Feb 16, 2020 at 8:59 PM
    rcbs204
    Well its been awhile since I have updated this.
    What has been done thus far you ask, well a bunch actually.
    I have replaced the entire front suspension, all new brakes, shocks, tires Nokian.
    Exterior, truxedo tunneu cover, new H7 headlights upgrade, clear front markers, new rear led tails, removed all side graphics and replaced the back emblem in black.
    Interior, all frogaudio speakers driven by a Kenwood DNX995S with reverse camera and front breakover camera. All new heated leather front bench custom upolstered, not a cover.
    I did have this truck running for a bit with the new exhaust and what not, and then noticed that I had a coolant leak on the back of the head on the cross over plate. Found that there was a rusted out bolt on the that plate and the only what to get to it was to pull the motor and once that happened I went all in!
    The truck will be getting the LCE long block to be ordered this march.
    aggr0crag and HomerTaco like this.
  5. Feb 16, 2020 at 9:04 PM
    rcbs204
    Here is what we had prior to engine removal.
    HomerTaco likes this.
  6. Feb 16, 2020 at 9:09 PM
    rcbs204
    Cut and buffed the paint, for a 25 year old truck the paint was in really good shape.
    Looks like the wheels will clean up really good when I get some good weather.
  7. Feb 16, 2020 at 9:34 PM
    rcbs204
    Here is what has been done so far.
    Shocks all 4
    CV Axles
    Sway bar bolts & bushings
    Plugs, Wires, rotor & Cap
    Upper & Lower Ball Joints
    Inside & Outside Tie Rod ends
    Steering dampener
    Front Wheel bearings & all seals
    Brake Rotor, Calipers, pads
    New Radiator and Electric Fan
    New cooling system hoses
    New belts both
    AudioFrog Door Speakers
    Sound Proofed Doors
    New Tires, Nokian
    New Lugnuts
    Rear driveline u-joints, going to replace the drive shaft with a Tom Wood's
    TB ICAV & O-ring
    Clutch Master and Slave Cylinder
    LCE BigBore TB
    LCE TB Spacer
    K&N FPIK
    LCE BigBore Intake
    LCE Fuel Injectors
    LCE Exhaust Header
    LCE CatBack
    LCE Pro Clutch
    LCE 35# Flywheel
    140 Amp Altenator
    New Starter
    Replaced back slider window with solid tinted 15% glass.
    Lowpro Tonneu Cover
    H7 Front Headlights
    Clear blinker markers
    LED Tails
    New rear Toyota emblem on tailgate
    Kenwood Head unit
    FrogAudio Component door speakers
    Reverse camera
    Front breakover camera
    SoundOrdance Sub
    Heated calf leather custom bench, gotta keep the ladies close with the bench!
    Coming in March
    LCE Street stroker long block with crank scraper.
    https://www.lceperformance.com/22R-RE-4WD-85-95-All-New-Street-Stroker-Long-Blo-p/1011056.htm
    Was going to do the stage 3, but did not want to mess with the ECU and fuel managment just yet. The nice part is the bottom end will be built stout enough for some boost when I am ready. According to the boys at LCE it will just take a little head work when I am ready to turbo this little guy.
    aggr0crag, HardTaco03 and trdtacojef like this.
  8. Feb 17, 2020 at 7:20 PM
    trdtacojef
    trdtacojef Well-Known Member
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    OME Dakar Medium duty rear leafs Total Choas UCAs Elka 2.5” Extended Travel CO and Rear Shocks w/ RR and DC FN FX Pro 17” Silver Rims Nitto Ridge Grapplers 285/70R17
    That makes me want one. That’s cool. Can’t wait to see it in March.
    rcbs204[OP] likes this.
  9. Feb 20, 2020 at 8:08 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I love everything about this thread. :yay:
  10. Mar 27, 2020 at 3:22 PM
    rcbs204
    Look what I got today!
  11. Mar 27, 2020 at 3:51 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  12. Mar 27, 2020 at 4:00 PM
    trdtacojef
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    Looks like COVID19 Christmas.
    rcbs204[OP] and "OldManTan" like this.
  13. Mar 28, 2020 at 6:48 AM
    trdtacojef
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    Man I’m excited to see this thing in the truck. Perfect timing on it arriving.
  14. Mar 28, 2020 at 9:56 AM
    Dirt Ferguson
    Dirt Ferguson Well-Known Member
    Daniel
    Napa Valley
    15 MGM DCSB TRD Sport
    KING 2.5 EXT, Total Chaos UCA, SCS F5, Katzkin
    Really pumped to watch this all come into place. Thanks for taking us all through your process.
    OP, what was the "cut" you were talking about when you said you "cut and buffed the paint"?
    cornbread_wy likes this.
  15. Mar 28, 2020 at 12:02 PM
    #35
    Dino1
    Dino1 Well-Known Member
    Dean
    2000 Tacoma 4WD 5sp
    Stock for now
    Sweet truck. How many times over have you spent your original investment? : )
  16. Mar 28, 2020 at 2:38 PM
    #36
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    https://www.youtube.com/watch?v=-oiZtrP4DY0
  17. Mar 28, 2020 at 7:21 PM
    #37
    rcbs204
    Mequires makes a DA paste that I used to cut, it is a fine grit buffing compound and has seven levels. You have to be very careful as it will go right to the primer on the corners with the DA.
  18. Mar 28, 2020 at 7:28 PM
    #38
    aggr0crag
    aggr0crag Well-Known Member
    19 DCSB 4x4 Sport M/T
  19. Apr 21, 2020 at 6:40 PM
    #39
    rcbs204
    Well,
    It's been awhile since I have posted here. The motor is installed and she runs like a champ. Just going through the first 500 mile break in now.
    BeLance89 and HomerTaco like this.
  20. Apr 21, 2020 at 7:41 PM
    #40
    trdtacojef
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    Wow. Incredible. Sounds amazing. Looks amazing. How’s it handle on the road so far? Noticeable difference with that LC Engineering engine?
