new to me used 05 tacoma with a few questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sidcrocker, Nov 27, 2012.
  1. Nov 27, 2012 at 8:13 AM
    sidcrocker
    sidcrocker [OP] Member
    this is an 05 access cab 4x4 4.0 6 speed with 100k with no mods to speak of. there is a surge when i accelerate strongly. I don't know if surge is the right word but the truck will pause for a 1/2 sec or so then accelerate smoothly, then pause breifly then accelerate smoothly. does this in most gears but doesn't do it if i accelerate gently. also will not do it in cruise control unless going up a long hill and the truck needs more gas to keep it cruising at that speed. drives very smooth at a steady speed. rpms do not drop during the pause.
    also, idle will dip down to 500ish get a little rough then climb back to 800ish at a stand still after warmed up. No other things on like the air conditioner. Is this normal. its not bad just noticable.
    the previous owner said he replaced the 02 sensor, TPS, MAF, changed the oil and filter with royal purple, tranny and diff fluids just changed. he also said the acceleration surge was always there, changing all the sensors didn't change anything. I ran a bottle of sea foam through the gas tank. It had a bit of a rough idle to it to begin with so I sea foamed it, worked well but then the idle flucuation began.
    any thoughs greatly appreciated.
  2. Nov 27, 2012 at 8:15 AM
    Large
    Large Red
    Welcome. Tried changing the fuel filter? I'm not sure if there's one on the fuel pump either but it might need changing too. I've read a couple other threads with this issue but they were first gen issues.
  3. Nov 27, 2012 at 8:25 AM
    custom90gt
    custom90gt Well-Known Member
    Colorado
    05 SWB TRD Off Road
    When was the last time a tune up was done?
    I'd change the plugs and air filter and reset the computer. Sea foam may have moved all of the contaminants from the intake to the plugs... The engine will probably have idle issues for a while after resetting the computer, but will smooth out after the first 20 or so miles while it learns. Start with the simple cheap stuff would be my suggestion.
  4. Nov 27, 2012 at 10:07 AM
    sidcrocker
    I think the fuel filter is in the gas tank and you have to drop the tank to get to the filter. I'm not 100% sure of this but I also read you shouldn't let the fuel tank get to low because of this. Someone correct me if I'm wrong.
  5. Nov 27, 2012 at 10:15 AM
    Large
    Large Red
    You are right. But there is 2 fuel filters I thought, one by drivers side under carriage and one in the pump its self.
  6. Nov 27, 2012 at 10:18 AM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    The fuel filter on the driver side frame rail is only on the first gens. Second gen is in the tank/fuel pump.
  7. Nov 27, 2012 at 10:20 AM
    sidcrocker
    Absolutly, i probably won't send alot of money tracking this down. I can live with it, just though this might have pop up before. Original owner said he changed the plugs about 10,000 miles ago. Dont know abut the air filter, i would guess its the dry filter. It was a k&n air fliter, i could see the oils covering the MAF sensor causing some issures.The truck definately had the engine surge before the seafoam, i just thought it was worth a shot.
    I'm wondering if cleaning the throttle body would help, although the truck isn't sluggish or have poor throttle response, it just has the surging acceleration and a slightly fluctuating idle.
  8. Jan 5, 2013 at 10:10 AM
    Redtaco704
    Redtaco704 Well-Known Member
    Jon
    Charlotte, NC
    05 DCSB 4x4
    Bilstein 5100's all around, Pro-Comp AAL, Pioneer in Dash DVD, Image Dynamics Component speakers, Custom 10" sub enclosure
    My 05' with 130K does the same thing. Has new plugs, clean air filter, syn diff. fluids, cleaned the throttle body, etc.. I hope someone on here figures out what it is. I can live with it but I wish it didn't happen.
  9. Jan 5, 2013 at 9:35 PM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    Did you clean the MAF when you cleaned the throttle body?
    Have you checked for codes?
    I'm not sure if the O2 sensors have a recommended replacement mileage.
  10. Jan 5, 2013 at 10:42 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    An easier way would to unbolt the bed and tail lights and slide it back a foot and pop off the top of the gas tank opening its way simpler then dropping the whole tank but it only works if you have the 6'ft bed either in AC or DC...of course you have to have a few friends to slide the bed but its so worth it....I changed my stock pump on a 05 to a walbro when I had it
