New to pick ups and lifts. Please help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaJorge7, Jun 25, 2018.
  1. Jun 25, 2018 at 8:41 AM
    TacomaJorge7
    TacomaJorge7 [OP] Member
    Hi my names Jorge and I’m new to the pick world. I purchased a 2018 Trd sport last week and instantly found a nice used pair of wheels. They are Fuel vectors 18x9 +20 with 275 65r18 Nitto grapplers. The gentleman I bought them from told me they would be fine on stock suspension and me being the noob that I am with out researching beloved him. Now that I have been reading threads on here, I’m pretty sure I need to do a lift kit. If some one can please point me in the right direction on what lift kit I need if I need one the information would be greatly appreciated. Thank you
  2. Jun 25, 2018 at 8:50 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Lift isn't the answer. Put the tires/wheels on there and see what happens. Will probably be good enough. If it rubs too much for your taste you'll need to look into a cab mount chop and trim a bit. Lift is irrelevant with respect to fitting those.
  3. Jun 25, 2018 at 9:09 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I'd personally lift the truck first before chopping. If you do put them on, there is a very high chance you'll rub.
    You can go cheap and get spacers for the front to lift it...this is a cheap way to do it and not recommenced on this forum or you can get Bilstein 5100s and new coils to lift the front up a bit to get more clearance. Depending if you like that stance or not you can lift the rear to keep it level with the front or a bit higher.
    My truck on stock suspension with 265/70/17 tires and 17x9 -12 offset wheels rubbed horribly...even with the truck lifted around 1.5" up front it still rubs on the mud flaps when reversing and when wheeling.
    Try doing a search about lifts and you can find a lot of good info.
  4. Jun 25, 2018 at 9:09 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    Stock tire size is 31.6 and the tires you picked up is 32.1. I think the tires are fine.
    I would be more worried about the width and offset of the wheels. 9" is pretty wide ... hopefully the +20 offset helps.
    The rears will be fine (I think). For the fronts, check if the tires clear the UCAs. If they do, drive it around and do some full lock turns to check for rubbing. But yeah, @Doggman is correct ... install it and see if it rubs
    EDIT: Welcome to TW! :thumbsup:
  5. Jun 25, 2018 at 9:30 AM
    TacomaJorge7
    Thank you guys for all the info I’ll throw them on and see what happens first
  6. Jun 25, 2018 at 9:35 AM
    tcjacado
    tcjacado Well-Known Member
    BE sure You have the right lug nuts for those rims.:thumbsup:
  7. Jun 25, 2018 at 9:43 AM
    harl3ygonewiild
    harl3ygonewiild Well-Known Member
    Harley
    2017 tacoma TRD off-road
    if they do rub it will be very little, could get a 1/2 spacer/leveling kit from headstrong off road should fit no problem
  8. Jun 25, 2018 at 10:13 AM
    TacomaJorge7
    I waiting on the old owner to find them in his garage. If he does not, do you know what the correct one are?
  9. Jun 25, 2018 at 10:15 AM
    TacomaJorge7
    Ok. I’ll look into that. Thank you
  10. Jun 25, 2018 at 10:47 AM
    tcjacado
  11. Jun 25, 2018 at 11:01 AM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Laughed for a good minute. Ugga dugga life :headbang:. Waiting for the day of my demise.
  12. Jun 25, 2018 at 11:03 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Not to step on your post. OP has 265/65/17 stock tires (Sport) which are 30.6, not 31.6
  13. Jun 25, 2018 at 11:11 AM
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2020 GLE 350, 2008 FJ
    This is correct. I purchased these same lugs for my Fuel Vectors a few weeks ago. I also purchased a set of Gorilla locking lugs, so each wheel has 5 of the normal spline lugs plus one locking lug nut.
    https://www.amazon.com/gp/product/B00C5SFYNI/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
    siznarf and tcjacado[QUOTED] like this.
  14. Jun 25, 2018 at 11:11 AM
    tcjacado
    Ok just got 18 inch rims and tireso_O
  15. Jun 25, 2018 at 11:37 AM
    siznarf
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    I think you are correct ... I have a sport but don't remember the stock size.
    My current KO2s are 32.7 if I recall ... so yeah, he might rub lol
  16. Jun 26, 2018 at 4:04 PM
    TacomaJorge7
    Thank you every for the input. Put the wheels on,drove around,did some wheel locks... NO rubbing and they CLEAR the UCA. very happy right now.
    CoastieRon likes this.
  17. Jun 27, 2018 at 9:19 AM
    harl3ygonewiild
    Harley
