New to T.W!!!!
Discussion in 'New Members' started by TacoNoob29, Sep 24, 2014.
  1. Sep 24, 2014 at 9:49 PM
    TacoNoob29
    TacoNoob29 [OP] Member
    Kyler
    Nor Cal
    2012 TRD Sport 4x4
    ReadyLift leveling kit 1in blocks in rear 2.75in strut extensions up front
    Sup everybody!
    New to Tacoma World with my first Tacoma. I have a 2012 TRD Sport double cab 4x4.
    only mods i have done is install a 3" Readylift leveling kit as well as a Bulletproof Fabricating mesh grill
    More on the checklist to do with wheels and tires next!
    Stock I'm running 265/65r/17 but I'm considering throwing on some 285/70r/17
    Can i go any bigger on tires if i trim more out of fender liner???
    Anything helps! Thanks guys
  2. Sep 26, 2014 at 10:35 AM
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    Welcome! And try and keep molesting to a minimum. Bigger is not always better.
  3. Sep 26, 2014 at 10:36 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Welcome to TW
  4. Sep 26, 2014 at 10:37 AM
    TIM.TRDSparks
    TIM.TRDSparks Well-Known Member
    Myrtle Beach, SC
    08 Taco DCLB RR
    CBI BUSHMASTER, BUDBUILT SKIDS SET, OME SUSPENSION, DAKAR LEAFS, TRD EXHAUST AND CAI PLUS MORE
    Welcome to TW!
  5. Sep 26, 2014 at 12:33 PM
    TacoNoob29
    Kyler
    Nor Cal
    2012 TRD Sport 4x4
    Agreed I'm sure I will stick with the 285s
  6. Sep 28, 2014 at 10:32 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Does your wallet feel lighter since you got here?
  7. Sep 28, 2014 at 10:36 AM
    medic2230
    Murph
    Bama! Roll Tide
    Welcome to TW!
  8. Sep 28, 2014 at 10:38 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Welcome from TN
