New to Tacoma - dome light with key off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zx5go, Sep 13, 2010.
  1. Sep 13, 2010 at 4:33 PM
    zx5go
    zx5go [OP] Well-Known Member
    Southwest Missouri
    2011 Super White TRD Sport
    Ok, I'm a new member and this is my first Toyota. When I turn the key off the down lights don't come on. Is this a Toyota thing? Every car I've ever owned had courtesy lighting that came on when the key went off.
  2. Sep 13, 2010 at 4:35 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    I think it works on the door switch. Open the door.
  3. Sep 13, 2010 at 4:43 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I'm not totally sure but I think its just with the door.
  4. Sep 13, 2010 at 5:18 PM
    JKD
    JKD Well-Known Member
    I've never heard of that. Lights come on with the door or a switch...
  5. Sep 13, 2010 at 6:08 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Please go to cheap free mod section.
    I believe there is a post some where, becasue I do that mod and it is easy to do it.
  6. Sep 13, 2010 at 7:40 PM
    zx5go
    Southwest Missouri
    Thanks! Like I said first car I've had that didn't turn on the lights when the ignition switch went off.
  7. Sep 13, 2010 at 7:43 PM
    wing103
    Boston
    I agree with you also this is the first car I have like this! Hhhaaaaa but you know what I still love my Tacoma!
  8. Sep 20, 2010 at 7:00 AM
    zx5go
    Southwest Missouri
    I couldn't find a fix in the cheap mod section.
  9. Sep 20, 2010 at 7:12 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    my 2011 interior light comes on when I remove the key as long as the switch is set to the "door" mode...and thats without any mods...put a year for your taco in your profile and maybe someone will have an idea
  10. Sep 20, 2010 at 7:13 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I don't think there's a mod for it nor will it come on when you turn off the ignition. What you can do is turn the ignition to off, then unlock the doors (I know it works when the doors are locked because this is what I do at the commuter bus stop in the mornings). I think the Mod referred to above is to have your map lights come on with the dome light (a very worthwhile modification for us double cab owners because it really helps light up the front area of the cabin).
  11. Sep 20, 2010 at 8:02 AM
    zx5go
    Southwest Missouri
    Thanks, the unlock method should work.
