new to tacoma world....need to replace smelly bench seat
Discussion in 'New Members' started by lourdes007, May 25, 2020.
  1. May 25, 2020 at 2:35 AM
    lourdes007
    lourdes007 [OP] New Member
    Ladyspy007
    2005 tacoma single cab
    Prior owner must of smoked in the car. Is it easy to replace the bench seat?
    what is compatible?
    Bigdaddy4760 likes this.
  2. May 25, 2020 at 3:33 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If prior smoker owner is the issue I would assume there is more than just a smelly seat (e.g., headliner and carpet). Yes, you can take out the rear seats, fairly DIY easy. Replace with a junk yard find. Maybe find one online. Matching the rest truck interior may be an issue. There are aftermarket seat covers. Do you like camo?
    Suggest removing only the seat to determine it is the single source of offending odor. Have you tried a DIY wet-dry vac clean?
    EdgemanVA likes this.
  3. May 25, 2020 at 4:35 AM
    lourdes007
    Ladyspy007
    it does not have a back seat. its the bench seat, front primary....
  4. May 25, 2020 at 4:45 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to the TW, try a good cleaning with Pinesol, then leave it open to air out.
  5. May 25, 2020 at 6:22 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW !
    Black DOG Lila likes this.
  6. May 25, 2020 at 6:29 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I’m sorry but you’re never going to get the stink 100% out. It’s in the vinyl, vents, carpet, wires, and everywhere. You can reduce the smell by taking it to a detail shop that uses an ozone generator running for a day. Live and learn. I would treat a smokers car like a flood damaged car - never buy one except for parts.
  7. May 25, 2020 at 6:33 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    Yes it's fairly easy to remove the seat. IIRC it's 9 bolts and a couple electrical plugs. Good luck, and welcome to TW. :)
  8. May 25, 2020 at 6:41 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  9. May 26, 2020 at 6:31 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  10. May 26, 2020 at 6:44 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Not sure if you'll ever get all of the smell out, but recommend trying to clean everything possible in the interior. Pull the seat & have it cleaned or replaced. Pull the carpet & have it shampooed. Wash everything inside! Also see if you can find a way to clean the car's duct work. Replace the cabin filter with something like Fram's "Fresh Breeze" filter. That's not the only activated charcoal filter out there so you have plenty of choices.
    At the very least you'll knock the smell down significantly...hopefully to something you can live with.
    Good luck!
  11. May 26, 2020 at 7:48 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
