New to Tacoma World
Discussion in 'New Members' started by Truckoma SR5, Nov 22, 2022.
  1. Nov 22, 2022 at 4:04 PM
    Truckoma SR5
    Truckoma SR5 [OP] New Member
    2001 Tacoma SR5
    Hello eveyone, I own a 2001 SR5 2.7 L 4wd 198K, my question deals with radiator loseing all of it's coolant due to transmission line rotting out, noticed the engine light come on and then the temp gauge into the H level. Pulled truck over had it towed installed a new radiator, parked at a angle to fill the radiator. Pressure tested the system to make sure the head gasket was not blown it held steady. When I start it, it slowly warms up at idle and the heat works. When I drive it about a mile the heats stops and the temp goes into the H zone. Bought a new thermostat have not installed yet. I poured about 2 1/2 gallons to refill when it goes into the hot zone it fills the overflow coolant tank. Perhaps the extreme heat ruined the thermostat? I know I had to retigjhten my oil filter after that onslaught of heat. Thanks for any help ...
    Mark
  2. Nov 22, 2022 at 4:21 PM
    Clearwater Bill
    Billy
    Largo Florida
    Transmission line won't dump coolant. It only carries trans fluid. Has your trans been topped back up?
    Is the fan clutch working?
    And I suspect there is still an air bubble messing with you.
    Put the new t stat in and start over with the burping process.
  3. Nov 22, 2022 at 4:29 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Did you replace the radiator cap with the new radiator?
    buckhuntin-tacoma likes this.
  4. Nov 22, 2022 at 6:34 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  5. Nov 26, 2022 at 1:50 PM
    70guitarman
    70guitarman Member
    Eltee
    Tucson
    2005 Tacoma sr5 trd double cab
    3inch lift duel flowmaster set up
    Welcome to TW. Replace cap after new radiator new thermostat. You should be ok.
  6. Nov 26, 2022 at 2:18 PM
    rotorblade
    rotorblade Well-Known Member
    Al
    Valdez, AK
    Lunar TRD Off Road
    Welcome to TW!
