New to Tacomas any advice?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rockin302, Dec 25, 2006.
  1. Dec 25, 2006 at 1:45 AM
    rockin302
    rockin302 [OP] Member
    Hello all,
    Not an owner of a tacoma but I'm looking to get one and becoming one of the many posters on this board as well as a first time truck owner.
    I'm interested in the extra-cab versions of the 4x4 or 4x2 in an automatic from 1995-1999. Is there a particular year I should be weary of and is there anything specific that I should check (both the V6 and the 4 cylinder) before making a purchase. Stuff like transmission issues, engine problems (head gaskets etc.), electrical, etc..I plan on getting one from a private party.
    Thanks for any help in advance!!
    Frank
  2. Dec 26, 2006 at 8:01 PM
    Jim Mann
    Jim Mann Well-Known Member
    I am by no means an expert, having just gotten my 96 Tacoma extended cab 4x4 5 speed about 3 months ago or so. The mechanics that I talked to all shared one opinion, do not get the V6 3 Liter. Get the 3.4L v6, or the 4cyl. Most seemed to think the 3.0L V6 was a dog.
    My truck had 160,000 miles that we know of, and a bent frame. The truck had never been wrecked, supposedly, but had hit something hard enough with the front right tire to knock it back 8 mm and up slightly. The frame had to be straightened out before I could get the front end aligned.
    Watch out for trucks with kift kits. Don't avoid them, just watch out. If the kit was installed without proper additional support, it can poke up through the bottom/back of the cab, as mine was beginning to do.
    Good luck with your search, JIm
  3. Dec 28, 2006 at 1:51 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    the 3.0 isn't offered in tacomas, only the pre-tacoma trucks. they are known for having headgasket issues. anything from 95.5-00 should be fine.
    GQ7227 likes this.
  4. Dec 31, 2006 at 6:51 PM
    rockin302
    How about the Automatic transmissions? How have they held up?
    Thanks!
  5. Jan 2, 2007 at 2:00 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Autos hold up fine.
    If you are going to look at a 3.4L V-6 check the mileage and ask if and when the timing belt was replaced.
    GQ7227 likes this.
  6. Jan 2, 2007 at 6:24 PM
    rockin302
    Cool. Will do thanks!
  7. Mar 30, 2020 at 9:16 AM
    amazonian girl
    amazonian girl New Member
    2001 Tacoma Pre- Runner
    Tacomas are notorious for rain water finding it's way into the cabin floorboards. Make sure you check that out when choosing your new baby. SC
  8. Mar 30, 2020 at 9:33 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    FRAME RUST, FRAME RUST, FRAME RUST, is the number one killer of these trucks. take a very long and good look at the frame. use a ball peen hammer and look everywhere, tap, tap, tap all over that bad boy. If is has some kind of coating over the frame, look even harder. as for the engine combo's I'd suggest the 3.4l V6 Auto transmission, love mine. I'm sure I'll be beaten to death by the manual transmission guys, but, remember this, an automatic will haul more weight than a stick. The only really good part about a stick, is it's the newest form of theft prevention since most people today can't drive one.:thumbsup:
    GQ7227 likes this.
  9. Mar 30, 2020 at 9:48 AM
    rj15tacoma
    rj15tacoma Well-Known Member
    ask when the lower ball joints were replaced, as they are very important to get replaced on time. Definitely check the frame. I have a 01 prerunner that i purchased in 2016 and it has been great. It is the 3.4l with no leaks, auto tranny, and 210k on the clock.
  10. Mar 30, 2020 at 9:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    0xDEADBEEF likes this.
  11. Mar 30, 2020 at 10:06 AM
    rj15tacoma
    Haha i just noticed im posting to a ghost :)
  12. Mar 30, 2020 at 12:32 PM
    MountainPassing
    MountainPassing Well-Known Member
    01reg.cab 2.7 stick, 97 80-series 40th anniversary model
    Toyota designs engines based on some parameters. My 80 series ,for example, was designed to go 500,000 miles in the jungles of africa with basic maintenance.
    I looked up the 1st gen tacoma predictions before buying and the "design" for the 6 is 200,000 and the 4 (3rz) is 250,000.
    Oh man!!! stinkin zombie thread!! should i press post reply?? meh someone will use the info.
  13. Mar 30, 2020 at 12:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  14. Mar 30, 2020 at 1:30 PM
    MountainPassing
    that avatar is hilarious.haha cracking me up real good..nice one
    your name avatar i mean lol
    Kwikvette[QUOTED] likes this.
  15. Mar 30, 2020 at 1:46 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Yep, I just noticed the date, my bad. kinda like beating a dead horse, you can't revive it, or this thread.
    Clearwater Bill likes this.
