New to Tacomas, just bought a 2001, any advice/tips welcome
Discussion in '1st Gen. Tacomas (1995-2004)' started by dan188, Oct 1, 2015.
  1. Oct 1, 2015 at 10:17 AM
    dan188
    dan188 [OP] Active Member
    Dan
    2001 Tacoma Double Cab
    3" toytec lift
    Hi guys,
    I recently picked up a 2001 double cab that was for sale here on the forum. The truck is exceptionally clean and was very well maintained, but I was wondering if there is anything I should look out for maintenance wise or just in general. I am a typical back yard mechanic and came from the Jeep world. I had a TJ on built dana 44 axles, 35's, 4 linked, tons of armor - basically an off road-only trail rig, which I got rid of for the Tacoma. I don't have any desire to take the Tacoma off road since it is just too nice to beat up. The frame on the Tacoma was replaced by the dealer in 2012 and is in very nice shape, but I was wondering if there are any spots on the body that typically rust out? Last weekend I sprayed the inner rocker panels with an anti rust coating from Eastwood Co. and I'd like to clean up a few spots on the underside of the bed. Is there anything else I should be looking for? For example, on the Jeep 4.0 it is typical for the header to crack over time. Anything quirky like that with the Tacoma? From what I've read it sounds like Tacomas run forever, so I hope this truck lasts a while if I take care of it.
    thanks,
    Dan
    specs on the Tacoma are - 3" toytec lift and 285/70/17's
    Logger likes this.
  2. Oct 1, 2015 at 10:32 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    if it was a forum member here chances are they took good care of it knowing the truck. did they give you any maintenance records? if not then fluids would be a good start.
    moe2o4 and ODNAREM like this.
  3. Oct 1, 2015 at 10:37 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    X2.
  4. Oct 1, 2015 at 10:39 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    You could replace those fugly bro wheels :)
    moe2o4, EB Group and CrawfishTaco like this.
  5. Oct 1, 2015 at 10:47 AM
    dan188
    Dan
    3" toytec lift
    Ah yes, sorry I should have mentioned that the previous owner did all scheduled maintenance. The truck has 155,000 miles on it, major recent maintenance includes all fluids, timing belt, water pump, coolant flush, plugs/wires, and a few other small items. I also just replaced both front axles since the boots were leaking on both sides and I wasn't sure how long they had been like that.
  6. Oct 1, 2015 at 10:48 AM
    dan188
    Dan
    3" toytec lift
    I like my fugly bro wheels! :) .... altho I have to say the truck needs to be re-geared. These tires are way to big/heavy for stock gears on the highway.
  7. Oct 1, 2015 at 12:53 PM
    Spicktacular
    Spicktacular Active Member
    Any idea how much that is going to cost you to regear? I'm looking at a 2001 and it needs to be as well.
  8. Oct 1, 2015 at 5:16 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Nice truck, really clean. congrats!
    You have 4.10 gearing? Probably need to go to 4.88s with your auto trans to get the pep back. Also wondering how bad you are rubbing with the 285/70/17s ?.. I was considering running some SEMA 17s as my street wheels and trying to decide on tire size.
  9. Oct 2, 2015 at 7:43 AM
    dan188
    Dan
    3" toytec lift
    thanks! Yes, I'm pretty sure I have 4.10 gears and I was also thinking 4.88s. I don't have any rubbing issues with the 285/70's, but to be honest I don't know the specs on the wheels in terms of offset. I'm also not sure if the previous owner trimmed the flares or anything. The wheels are 17x9 Fuel Mavericks.
  10. Oct 2, 2015 at 7:55 AM
    dan188
    Dan
    3" toytec lift
    I asked a local shop and they gave me a rough quote of $1,000. The gear sets are about $250 per axle, so the whole job could be pretty expensive
  11. Oct 2, 2015 at 8:05 AM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    BALL JOINTS...... I'm not yelling but those are notoriously bad and fail. There was a recall years back
  12. Oct 2, 2015 at 8:09 AM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    When I got mine I cleaned the PCV out and did all the fluids. Seems like you're pretty good to go to me.
  13. Oct 2, 2015 at 8:59 AM
    dan188
    Dan
    3" toytec lift
    Thanks for the heads up! I will take a look at mine.
  14. Oct 2, 2015 at 1:15 PM
    Trukboy1
    Trukboy1 Member
    99 tacoma trd black, like new condition
    That is one beautiful truck. I bet the tires give you a rough ride on the highway.
  15. Oct 2, 2015 at 3:17 PM
    egebhardt
    egebhardt Well-Known Member
    Eric
    Rapid City, SD
    '99 4x4 Xcab 5spd V6
    None
    I bet you can get bigger tires. LOL
  16. Oct 2, 2015 at 3:25 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Common rust spots are above the rear wheels (under flares). Think the most problematic things on these trucks are the clock and non returning seatbelt ahaha.
  17. Oct 3, 2015 at 3:46 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    anyone else just notice the driver's side has the lower section painted/undercoat and the passenger side does not?
    any info on this or diff date pics?
  18. Oct 5, 2015 at 7:42 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Boy oh boy thats a beautiful truck. Working on getting mine looking like that.
  19. Oct 6, 2015 at 8:26 AM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Great looking truck, awesome color, nice stance. The wheels look good on the truck with the aggressive tread.
  20. Oct 8, 2015 at 6:48 AM
    dan188
    Dan
    3" toytec lift
    Good eye. The pics were taken a few days apart. I plastidipped the lower rocker panels to prevent stone chips since I don't have mud flaps.
