New To Tacoma's
Discussion in '4th Gen. Tacomas (2024+)' started by meeker 80, Sep 2, 2024.
  1. Sep 2, 2024 at 7:22 AM
    meeker 80
    meeker 80 [OP] New Member
    Tomik
    2024 Tacoma 6 spd
    Hello I'm new here. I just bought my very first truck ever, and so far, I love it. I have a couple concern. I recently noticed when I turn off the truck, about 5 minutes later, the truck makes a loud squeaking noise. Also, I travel allot with my dogs, I can't figure out a way to lock the truck when it is still running. Why is this a issue? If I have the key fob, I should be able to lock it.
  2. Sep 2, 2024 at 7:34 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    No idea on the 4th gen, but the older models have an air injection pump that runs after stopping, or it could also be the fuel pump. On the push button start models the fuel pump runs occasionally (again on older generations, I'm just guessing on the 4th gen).
    The truck is smarter than that, and thinks you forgot the truck is running. I think the best option is to lock all doors except the driver's door, get out and close the door, then use the physical key to lock the driver's door (hidden in the key fob).
    Just remember that someone can break into and steal your truck pretty easily this way.
  3. Sep 2, 2024 at 7:39 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Depends on the kind of dogs OP has
    turkeyslayer66 likes this.
  4. Sep 2, 2024 at 8:17 AM
    meeker 80
    Tomik
    2024 Tacoma 6 spd
    If I have the keys, trucks running, and if someone managed to steal my truck, how far could they go without the key?
  5. Sep 2, 2024 at 8:33 AM
    spdkilz911
    spdkilz911 Member
    2024 Tacoma
    Until they run out of gas or get where they are going. The fob is needed to start the truck, that's all.
  6. Sep 2, 2024 at 9:51 AM
    meeker 80
    Tomik
    2024 Tacoma 6 spd
  7. Sep 2, 2024 at 9:53 AM
    meeker 80
    Tomik
    2024 Tacoma 6 spd
    That's a terrible concept. It should be a radius from the keys. What's the point of having the truck on keeping it cool if anyone can just steal it?
  8. Sep 2, 2024 at 10:21 AM
    spdkilz911
    spdkilz911 Member
    2024 Tacoma
    If they did that and the battery died in the fob or had a connection problem the truck would die. Remote start will do what you are trying to do if you have that.
  9. Sep 2, 2024 at 10:22 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
    boston23 likes this.
  10. Sep 2, 2024 at 10:30 AM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Honestly i just crack the windows for my dog and put up a shade in the windshield
  11. Sep 2, 2024 at 10:51 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I assume you probably leave your truck running and a/c on, on hot days because your pets are in the truck. However leaving your truck running with your pets inside is a very very very bad idea. A thief or some nut job could break your window and be gone with your truck and dogs in 20 seconds. In which case you may never see your truck or dogs again.
    If it’s a hot day and you have to make a stop for more than a couple minutes, don’t take your dogs with you. Even with windows down a little, dogs can die from the heat in a very short time. It’s happens hundreds of times a year. Get a better plan.
  12. Sep 3, 2024 at 12:11 PM
    thedudeabides22
    thedudeabides22 Well-Known Member
    2024 Tacoma 4x4 TRD Offroad
    Are you referring the noise when the auto-parking break engages after shutting off? It will periodically make a funny sound to hold pressure randomly since they are disk brakes now.
