New to the Forum need advice
Discussion in 'New Members' started by hoppy269, Jun 23, 2013.
  1. Jun 23, 2013 at 3:14 PM
    hoppy269
    hoppy269 [OP] New Member
    Bentonville,AR
    Looking at Tacoma
    Looking at the Tacoma v6 model to tow a 22' Hurricane deck boat with 150 engine and tandem axle trailer, all less than 4500 pounds. I would only tow to and from the lake on weekends 15 minutes one way couple hills. I was looking for advice if the Tacoma could handle without a problem. I really don't want a 12-19 mile full size but if I have to so be it. Need your expert feedback thanks in advance.
  2. Jun 23, 2013 at 4:12 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    It wouldn't have any trouble, especially for that little distance. I towed a 7000lb project vehicle/trailer combo 500 miles with mine. The truck would dance a little above 65mph in a bad crosswind, but I just slowed down a bit and it came right back in line
  3. Jun 23, 2013 at 4:36 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Welcome
  4. Jun 24, 2013 at 3:25 AM
    hoppy269
    Bentonville,AR
    Looking at Tacoma
    Thanks, looking forward to the forum. I am looking at a 2WD 2013 with the TSS sport serier suspension and bilstein shocks. Is the towing the capacity the same as the 4WD.
  5. Jun 24, 2013 at 2:12 PM
    WHPLSH3
    Vance
    Alberta
    These trucks have 3 different towing capacities:
    3500lbs- 4 cyl trucks/X-Runner
    6500lbs- V6 Access Cab/Double Cab Short Bed (same wheelbase)
    6400lbs- V6 Double Cab Longbed
    4x4/2wd makes no difference in towing capacity if it's a Prerunner.
    The 100lb difference from dcsb to dclb must be Toyota's calculation that the longer truck weighs that much more
  6. Jun 24, 2013 at 2:27 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    On such a short trip,you should not have difficulty.
    I DO RECOMMEND electric trailer brakes-they will make life easier and safer.
    It is relatively cheap and an easy modifacation.
    With the $$$ spent on boat fuel-it will only cost a couple tankfuls!
    It makes a HUGE DIFFERENCE!
  7. Jun 24, 2013 at 4:26 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Added note-the 4x4 is helpful when launching and hauling out the boat-especially if the launch is gravel.
    The 4x4low is great. FYI
  8. Jun 24, 2013 at 4:41 PM
    hoppy269
    Bentonville,AR
    Looking at Tacoma
    Thanks for all the helpful information everyone
  9. Jun 24, 2013 at 5:06 PM
    ConnorLeech
    ConnorLeech Member
    Connor
    Arkansas
    Are you going from Bentonville to Beaver Lake? If so, the 2WD TSS will be 100% fine. I'd definitely suggest 4WD for the winters and launch/haul
  10. Jun 25, 2013 at 2:49 AM
    hoppy269
    Bentonville,AR
    Looking at Tacoma
    Yes, Bentonville to Beaver and Bentonville to Windsor.
  11. Jun 25, 2013 at 8:40 AM
    ConnorLeech
    ConnorLeech Member
    Connor
    Arkansas
    Get yourself a 4WD and we can go wheeling!
