New to the forum with a question:
Discussion in 'New Members' started by Sportsphreek, Dec 22, 2010.
  1. Dec 22, 2010 at 8:03 PM
    Sportsphreek
    Sportsphreek [OP] Active Member
    Virginia
    Double Cab TRD Off Road
    Bought my 2010 Tacoma Double Cab TRD Off-Road in early June of this year. Absolutely love it, but I have a few question regarding some problems that I am having with it.
    The engine seems to have a bit of a knock to it. It just doesn't sound smooth. Seems to be more pronounced when the engine is under load (ie: Doesn't exhibit problem when revving in Neutral). (Edit: This may be the Tacoma Engine Tick everyone talks about)
    The transmission forgets to shift sometime. Most of the time it is going downhill, but after accelerating it just doesn't shift. I'm just stuck in whatever gear it happens to be in until it decides to shift (Typically around the 3000RPM range)
    There is a rattling/ringing/jingling coming from somewhere on the under carriage. Occurs at all times but is most noticeable when coasting at low speeds.
    The vent fan has started squeaking when running.
    Additionally, I got the notice that my truck was eligible for that gas pedal override. I didn't end up getting it yet, but was wondering if there was any point in doing it.
    Thanks so much!
    -Kevin
  2. Jan 2, 2011 at 11:06 AM
    mac360
    mac360 Well-Known Member
    Long Beach, Ca
    2017 Tacoma OR DC LB
    All they did on mine was shave the corners.. Kinda pointless, but I guess it was needed..
  3. Jan 2, 2011 at 11:20 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    The engine ticking is normal. You will get to the point where you wont hear it.
    The engine doesn't shift when you go downhill is also normal. This makes it so you don't have to stay on the brakes the entire time.
    Cant help you with the noise underneath (I would have Toyota check it out under warranty)
    The gas pedal recall also comes with a computer re-flash. You won't notice anything different with your truck. The only reason not to do this is if you plan on Supercharging your truck in the future.
    Good luck with your new truck! And Welcome!
  4. Jan 3, 2011 at 2:27 AM
    Sportsphreek
    Virginia
    Awesome! Thank You!
    I got the Gas Pedal flash (More importantly the ECU reflash) and I got the Rear Spring TSB. The back is probably about 1"-1.5" higher right now. Now I have to go the rest of the way and raise it =)
    Thanks Ya'll!
