New to the neighborhood
Discussion in 'New Members' started by WorkTaco, Apr 30, 2019.
  1. Apr 30, 2019 at 3:02 AM
    WorkTaco
    WorkTaco [OP] Member
    Nate
    Northwest Indiana
    2011 Green Tacoma
    4” pro comp lift, 35” trail grapplers
    Hey guys, thanks for letting me in on this. I’ve had my 11’ Tacoma v6 6 speed for 4 years now. Unfortunately I don’t get much time to take it off the road. It’s essentially a pavement pounder. That being said, I need to do some upgrades to improve fuel economy. I’m currently getting about 11.5 mpg. Muffler split open last week so I was looking for some advice on exhaust systems. Any upgrades I can make in the exhaust that will boost my fuel economy? Thanks in advance.
  2. Apr 30, 2019 at 3:06 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    When is the last time the spark plugs and air filter were changed? What size tires are you running? Do you drive it like a sports car? These are the biggest contributors to poor fuel economy.
  3. Apr 30, 2019 at 3:34 AM
    Harry2015
    Harry2015 Well-Known Member
    Harry
    N.E. PA
    Welcome from N.E.PA!
    CS_AR, Bigdaddy4760, lynyrd3 and 2 others like this.
  4. Apr 30, 2019 at 5:10 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip:
  5. Apr 30, 2019 at 5:57 AM
    WorkTaco
    Nate
    Northwest Indiana
    2011 Green Tacoma
    I put E3 diamond fire plugs in about 12k ago and a new K&N air filter at the same time. I’m running 35” Nitto Trail Grapplers under a 4” pro comp suspension lift.
    CS_AR and Bigdaddy4760 like this.
  6. Apr 30, 2019 at 5:59 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  7. Apr 30, 2019 at 6:00 AM
    GA_Goat
    GA_Goat Well-Known Member
    Bill
    Georgia
    2018 TRD Pro
  8. Apr 30, 2019 at 6:00 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  9. Apr 30, 2019 at 6:14 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    Well the E3 plugs aren’t doing you any favors. You should run the OEM Denso plugs for best performance.
    Are you factoring in the increased tire size when calculating fuel economy? If not, you might be getting a little better mileage than you think.
    But I’m going to go out on a limb here and say that the biggest thing hurting your fuel economy is the 35’s. That is a way oversized tire, and Nitto’s are on the heavy side at that.
  10. Apr 30, 2019 at 6:37 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  11. Apr 30, 2019 at 1:04 PM
    WorkTaco
    Nate
    Northwest Indiana
    2011 Green Tacoma
    There’s no doubt the tires are hurting me there. You’re right. I’ll try swapping the plugs and see if that helps. Thanks for your input!
  12. Apr 30, 2019 at 1:39 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    welcome
    CS_AR, Taco critter and irayfz6 like this.
  13. Apr 30, 2019 at 5:00 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  14. May 1, 2019 at 10:15 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
  15. May 2, 2019 at 7:33 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! Sadly there really aren't any add-ons that will improve your fuel economy. That being said try these:
    • new engine air filter
    • clean your MAF sensor
    • new spark plugs
    • clean throttle body
    • drive like an old man
    CS_AR, ODNAREM and irayfz6 like this.
  16. May 2, 2019 at 8:22 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
