new to the site and im looking to lift my truck
Discussion in 'Suspension' started by gearhead06, Feb 18, 2010.
  1. Feb 18, 2010 at 9:04 AM
    gearhead06
    gearhead06 [OP] Active Member
    josh
    columbus
    07 Tacoma v6 4x4
    I have a 3" lift from suspensionconnection.com... I have 4.88 gears Front and Rear with 2 Arb Lockers.. Im running on some 315/75R16 FIERCE ATTITUDE M/T...
    I have a 2007 tacoma v6 4x4 im looking to lift and put bigger tires on and i dont know what all i need to do befor I put on my 3" lift from....
    http://www.suspensionconnection.com/cgi-bin/suscon/52907.html
    and some bfgoodrich mud-terrain t a km2 285/75r16
    http://www.bfgoodrichtires.com/overview/mud-terrain-t-a-km2/3930.html
    someone was saying i might have to new brake lines and front drive axles
    and i wanted to know if anyone knows if thats true or not or if its something that can wait?????
    IF you know PLZ let me know
  2. Feb 18, 2010 at 10:01 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Don't need axles or brake lines. You may need to get a diff drop kit to help with CV angles. Check with toyteclifts.com. You may or may not need a shim or carrier bearing drop to get the rear drive line angles fixed and prevent vibes. You may also need UCAs to get your alignment perfect, but it seems to be hit or miss on this.
  3. Feb 18, 2010 at 10:03 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    1st you should read this:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/40469-lifting-you-truck-things-you-need-know.html
    then you should know about this:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/69937-3-rough-country-lift-help.html#post1321026
    You shouldn't buy a cheap lift to use on your truck. Invest in a good lift such as bilstein 5100s on all 4 corners, aals, and some new upper control arms. there's some other stuff, but if you search around, you'll find what you're looking for.
    Welcome to TW!
  4. Feb 18, 2010 at 10:07 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    x2 ... spend the money now so you won't regret it. like seth said, can't go wrong with toytec.com. their OME kit is affordable and is a very good lift
  5. Feb 18, 2010 at 10:15 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Welcome to TW
  6. Feb 19, 2010 at 2:52 AM
    gearhead06
    josh
    columbus
    07 Tacoma v6 4x4
    so is that something i need to look at befor i buy my lift or will i be fine to get my lift put on then look at all that????
  7. Feb 19, 2010 at 3:12 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Welcome!
