New to the Taco World
Discussion in 'New Members' started by Taco-MT, Jan 31, 2024.
  1. Jan 31, 2024 at 11:59 AM
    Taco-MT
    Taco-MT [OP] New Member
    Toronto, Canada
    2023 Tacoma TRD Sport 4x4
    Hey,
    My name is Steve, I just recently purchased a 2023 Tacoma TRD Sport 4x4. I finally got the truck I've been wanting for years. I'm very new to this world so I'm trying to do as much research as possible and learn a thing or two from everyone. I've started a list of mods I want to gradually do to my truck. First off are suspension, wheels, and tires. I plan on hitting some trails but this is also my daily driver, so I don't want to get too crazy on the mods. After that, it would be cosmetic things like headlights, tail lights, and fog lights. Next would be a rock slider and skid plate. I also plan on doing some camping with my truck so I will start looking into camping gear. Not sure what I want to go with, either a rooftop tent or a truck bed tent. I'm super excited to start building up my truck. I welcome any suggestions as I said, I'm green to this and I want to learn as much as I can.
  2. Jan 31, 2024 at 12:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    Suggest you don't change anything until you recognize that the change will 'fix' something the truck won't do stock.
    Use it as is first.
    A good set of tires and driving skills will take you plenty of places. Suspensions are 'sometimes' needed and useful, but your lowest ground clearance, axle lines, is not raised by anything but tire diameter.
    Williston and HondaGM like this.
  3. Jan 31, 2024 at 12:15 PM
    Taco-MT
    Toronto, Canada
    Thanks for the info! Good to know. I don't plan on rushing into these mods, want to feel comfortable with the truck first. Would you recommend maybe going with wheels and tire upgrade first? I've been looking around and I would like to go with a 285/75R17. It seems to be the common go-to.
    HondaGM likes this.
  4. Jan 31, 2024 at 12:31 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    HondaGM and Taco-MT[OP] like this.
  5. Jan 31, 2024 at 12:31 PM
    KneeDeepInTacos
    KneeDeepInTacos Active Member
    SoCal
    2013 DCSB 4x4
    Welcome to TW!
    Taco-MT[OP] and HondaGM like this.
  6. Jan 31, 2024 at 12:34 PM
    Taco-MT
    Toronto, Canada
    Thanks for the warm welcome!
    HondaGM likes this.
  7. Feb 4, 2024 at 6:24 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
  8. Feb 4, 2024 at 6:25 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
    Taco-MT[OP] likes this.
  9. Feb 4, 2024 at 7:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    Tires, yes. Wheels, what's to 'upgrade'? Looks, maybe. Otherwise they fit eveything and clear everything as they should, right?
    Why? It's always good to know 'why' you want to do something, other than that's the cool kid trend. For example, a 265 would work very well, isn't significantly less width, and clears everything (on OE wheels). And consider how the truck will be used 90% of the time, and select what works well for those conditions, allowing 'looks' to be a secondary element of your choice.
    For example 'I want to look aggressive' doesn't do squat for a pavement pounder, other than wear out faster and have less grip.
  10. Feb 4, 2024 at 7:44 AM
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Welcome to TacomaWorld! Spend a few months or so driving your stock truck. You'll learn what (if anything) bugs you about it and that will lead you towards what might be worthwhile upgrading. I take my truck off-road mostly on Forest Service roads and Jeep trails (some a little challenging) leading/getting to the good remote fly-fishing spots. My truck is completely stock and easily handles everything I've encountered so far. Only thing I would seriously consider upgrading is the rear shocks to cure the tire-hopping chatter on washboard dirt roads and true/better M&S rated tires (Michelin). Read as much as you can here and ask questions.
    There is a ton of information in here from people who have done just about every mod you can name and what was good, bad about what they did, even including some that regret what they did and went back to stock.
    Enjoy your new truck! Acquiring a last-year of production Tacoma generation is seldom a bad thing. :thumbsup:
  11. Feb 6, 2024 at 6:05 AM
    BuiltRight Industries
    BuiltRight Industries BuiltRight Industries
    New Milford, CT
    2020 TRD OffRoad
    Second this. I was able to do a ton of trails in a stock '16. I ended up upgrading only because the trails I wanted to do required bigger tires that I couldn't fit them with the stock suspension. Then went down the rabbit hole of adding bumpers, sliders, and a topper.
    Another thing, since this is your daily driver. Think about how much you commute. Mine was a daily driver and I commuted about 80 miles a day (roundtrip). My truck after all the mods got around 15 mpg...I was coughing up a ton of money in gas. Also, the heavier the truck is, the heavier you have to hit the accelerator and for daily driving that can get annoying as well, especially if you live in a hilly area.
    Welcome to the community!
  12. Feb 6, 2024 at 7:33 AM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Welcome to TW! I agree with waiting.
  13. Feb 6, 2024 at 9:10 AM
    iversonhof
    iversonhof Well-Known Member
    Nick
    Florence, KY
    2020 Toyota Tacoma Quad Cab
    Nothing yet. Just bought a new truck.
    Welcome!
  14. Feb 9, 2024 at 8:45 AM
    Taco-MT
    Toronto, Canada
    Thank you for the advice! Part of the upgrade is to look cool, I won't lie. Lol! But I also want to keep it minimal as car thefts are rampant where I live. I also would like to hit some trails and do some camping out of the truck. But I will take your advice and test out the needs first and then make a decision.
  15. Feb 9, 2024 at 8:48 AM
    Taco-MT
    Toronto, Canada
    Thank you so much for your input and advice. I'm taking my time to do anything to the truck for now. Just trying to learn as much as I can and get to know my truck. I love this community!
    Williston[QUOTED] likes this.
  16. Feb 9, 2024 at 8:49 AM
    Taco-MT
    Toronto, Canada
    Thanks for the advice! Put some things into perspective for me. Thankful for this community!!!
