New to the taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kylestaco132, Nov 11, 2019.
  1. Nov 11, 2019 at 10:02 PM
    Kylestaco132
    Kylestaco132 [OP] Member
    Kyle
    2000 White Tacoma SR5 Prerunner
    Stock as heck atm
    Hello I wanted to know any common problems with the first gen Tacoma’s because I just bought a 2000 today with 147k miles on it and I’ve never owned a Tacoma before, and any suggestions on upgrades?
  2. Nov 11, 2019 at 10:33 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Lower ball joints
    Tranny service and install cooler
    Tundra brake upgrade
    Kylestaco132[OP] likes this.
  3. Nov 11, 2019 at 10:54 PM
    BuelltonTacoma
    BuelltonTacoma Well-Known Member
    2000 Tacoma 4x4 V6 3.4L MT
    Grab some all terrain tires, remember to change the oil on schedule, wash the outside, vacuum the inside and enjoy the ride.
  4. Nov 12, 2019 at 8:56 AM
    Kylestaco132
    Kyle
    Stock as heck atm
    I have all terrains on it but I’m buying new ones in a few days going with some generals
  5. Nov 12, 2019 at 2:49 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Post some pics, which engine does it have, also if you don't know the repair history, if it's a 3.4L, you might want to change the fan bearing. Don't be cheap on the lower ball joints, buy Genuine Toyota parts for this. Also a 3.4L needs the timing belt and water pump changed every 90k miles. Buy a good kit with the idler pulleys and tensioners included. If it's a 4x4 change the diff gear oil, transfer case and the rear end oil also. Welcome to TW, the only thing you need here are deep pockets and the willingness to keep your truck running good.
