New to the Tacoma world
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Oct 18, 2020.
  1. Oct 18, 2020 at 6:06 PM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I just bought my first Tacoma yesterday (Black 2013 Double Cab TRD Off-Road) and I absolutely love this truck. It only has 80k miles on it and is very clean. I have a dumb question though, actually several questions. The steering seems a little bit tough as low speed and making turns when I'm in "D" gear. Tonight when I left the store, I slid the shift lever to "4" and noticed the truck seemed to steer much easier. Now I understand this is pretty much just a limiter in how many gears the truck will allow itself to shift up to, but that doesn't explain the better steering and what seemed to be better acceleration too. Please help a new guy out! Thanks!
    po35042 likes this.
  2. Oct 18, 2020 at 6:07 PM
    tcjacado
    tcjacado Well-Known Member
  3. Oct 18, 2020 at 6:44 PM
    Invalid620
    Invalid620 Member
    2007 Black Tacoma TRD Sport
    Welcome to TacomaWorld! The "4" option means it limits the truck to just 4 gears. That's why the truck has better acceleration. I only use this option for when I am traveling up a hill or pulling a trailer. I don't think it should be used all the time but I could be wrong. My truck certainly has more power when using it.
    po35042 and Tacoma13_NC[OP] like this.
  4. Oct 18, 2020 at 6:47 PM
    Tacoma13_NC
    Thanks for the reply. If it won't hurt anything, I might just continue to do in=town driving while in "4" because of the better steering and acceleration. Obviously on highway I would run in "D". I guess what has me perplexed is the steering. How could it make it easier to steer?
  5. Oct 18, 2020 at 6:47 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Welcome welcome!
    It’s probably time to change and flush your power steering system, possibly change your serpentine belt too, your power steering seems better in 4 as your trans controller limits to lower gears for higher torque so your RPM’s and thus pump speed and thus pressure goes up.
  6. Oct 18, 2020 at 6:50 PM
    Tacoma13_NC
    Well that makes sense. Thanks!
    Key-Rei[QUOTED] likes this.
  7. Oct 18, 2020 at 6:54 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    Welcome Ryan, nice score on the truck.
    Not sure what to offer on the steering, it's not stuck in 4wd is it?
    Tacoma13_NC[OP] likes this.
  8. Oct 18, 2020 at 6:57 PM
    Tacoma13_NC
    I was literally just telling my wife that it almost felt like it was driving in four wheel drive, however the dial is on H2 and no indicator lights were on. I can't really explain the feeling other than it felt a lot like it came out of four wheel drive into two wheel. That is concerning to me if that's the case though.
    Island Cruiser likes this.
  9. Oct 18, 2020 at 7:03 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  10. Oct 18, 2020 at 7:07 PM
    po35042
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    Hopefully it just needed to be limbered up after sitting on the car lot a while. Everybody wants to try the 4wd on the test drive and maybe something didn't fully disengage. I know mine is kinda finicky about coming out of lock from time to time.
    Steadfast and Tacoma13_NC[OP] like this.
  11. Oct 18, 2020 at 7:10 PM
    Tacoma13_NC
    Hopefully that's all it was. I'll have to investigate it a little further tomorrow. Maybe something to do with the transmission jarred it loose from being locked like you said. Maybe it's just the RPM's running higher in "4". Who knows, but I really appreciate all of your help on this! I'm excited to be a Tacoma owner now!
  12. Oct 18, 2020 at 7:11 PM
    Key-Rei
    Key
    Florida
    You should get a beeping or flashing light if something was stuck engaged from 4WD.
    in 4WD you have a transfer case switch in and the ADD front sleeve slide over. (Automatic Disconnecting [FRONT] Differential) if your transfer case was stuck you should have the green 4WD light flashing on the dash, if you ADD got stuck I’m not sure if it would report an error but I suspect it would.
    Something you can try is finding some grass and engaging 4WD then slowly reverse while gently sawing the wheel back and forth and disengage 4WD that may help get anything that could possibly be hung up to let go.
    The 4WD system should be activated and “exercised” a few times a month even if you don’t use 4WD often; this is just to keep things lubricated so they don’t hang up when you need them.
    Also check the front differential there should be a plastic roughly D shaped box attached to the longer side (shaft extension housing) with a nipple on it and a long rubber hose leading up into the engine bay see if that’s connected and then fallow it up to about halfway into the engine bay it should be attacked with a clip and terminate in a small plastic or aluminum cylinder, this is as breather pull that off and try to blow through it it should allow a small amount of air to pass through it, if that’s plugged up I could potentially see it causing a pressure in the ADD motor and hanging something up or causing condensate to corrode it and not disconnecting the engagement sleeve if the hose is disconnected or broken off.
  13. Oct 18, 2020 at 7:19 PM
    Tacoma13_NC
    Wow, thanks for the great advice! It's quite possible that the four wheel drive system was not activated for quite some time prior to me picking it up. I bought it from a very reputable dealership and maybe it got stuck when they tested the system. Anyways, I'll let yall know something tomorrow hopefully on how it's doing. Fortunately I signed up for the extended dealer warrant that covers most everything, but hopefully I won't have to use. I have a good feeling about this truck, and I believe it will be a learning process for me too.
    po35042 and Key-Rei[QUOTED] like this.
  14. Oct 19, 2020 at 4:14 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    So, did you test drive it before you bought it? I would think you would’ve noticed that something was wrong then...
  15. Oct 19, 2020 at 5:22 AM
    Tacoma13_NC
    Yes I did, and I didn't really notice anything that seemed out if the ordinary, I just figured the steering was a little tougher because it was a truck. I might just be looking to far into this. Everything about the truck is great and I'm very glad I bought it.
  16. Oct 19, 2020 at 11:46 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    So no thoughts on my above comments?
  17. Oct 20, 2020 at 2:25 AM
    Tacoma13_NC
    ??????? I don't see where you commented on this post.
  18. Oct 20, 2020 at 4:40 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I have to agree with this as there was a period I did not drive my truck and the steering became stiffer.
  19. Oct 20, 2020 at 4:50 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Go out and mess around with the transfer case shifting, put it in 4h, see how it drives, take it out of 4 wheel drive high, notice how it does this, smoothly? Stop the truck, put it in neutral, shift into 4low, see how it drives, should be reving up high and shifting real quick. Take it out of 4low, how does that go? Learn the characteristics of the drive system, and go 4 wheeling.
  20. Oct 20, 2020 at 10:28 PM
    wiggler
    HILO
    Whoops wrong thread
