New to the Yota gang and need some help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pat_medown, Dec 27, 2017.
  1. Dec 27, 2017 at 8:33 AM
    pat_medown
    pat_medown [OP] Member
    Hey guys!
    I just bought a 2015 Toyota Tacoma 2WD about 6 months ago. This is my first time owning a truck and been trying to do a lot of research on modifications for the truck.. There are so many acronyms that I feel like I'm reading a different language, so I was hoping you guys could help. I've saved up some money to get my truck lifted (3" desired) and looking for wheels and tires. Can someone help me out with some suggestions for what kind of lift I should get (do not off road often), and what size wheels and tires would fit nicely. If you could provide pictures and links to sites you buy from it would be greatly appreciated!
  2. Dec 27, 2017 at 8:41 AM
    Pigpen
    Dan
    Northwest Montana
    With a 2wd, get Maxtrac spindles for the front. @ChadsPride has a nice 2x4 build. You can even buy the Chadspride lift kit from @HeadStrong Off-Road, just talk to Marie.
  3. Dec 27, 2017 at 8:42 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Welcome to TW and congrats on the truck! If I had a 2wd, I'd look in to spindle lift ( keeps Cv axle geometry?) and a new leaf pack(Dakars). Matched with Bilstein, you woyhave a nice lift .
    Talk with Marie @HeadStrong Off-Road, she can help you out!!
  4. Dec 27, 2017 at 9:00 AM
    pat_medown
    Thank you guys!
