New to this community with my just acquired 2008 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VDM1560, Aug 17, 2024.
  1. Aug 17, 2024 at 12:22 PM
    VDM1560
    VDM1560 [OP] New Member
    2008 Blue Tacoma Access cab SR5 TRD OffRoad
    none
    Thanks for being part of this Community
    Just join this community after having bought a 2008 Tacoma Access cab TRD Off Road. Lets say it had no maintenance history so to have a baseline, did a good tune up, changed spark plugs (original were in at 180,000 kms) Oil change, replace engine and cabin filters., Also install Apple carplay console with back up camera, great addition! Now have to replace fan control chip as it is defective, got the part from Amazon after reading on this site , Will also be replacing serpentine belt as it looks it is probably the original one. No squealing noise from any pulley yet. Complete front break job also done.
    I read gates pulleys for replacement #1 Idler - 36174
    Idler #2 - 36173, If needed will only replace Tensioner pulley at the assembly is quiet a job to do, not sure after reading a post if the pulley for the tensioner is also a Gates 36174???
    Will have to read more on this one.
    Williston and Sprig like this.
  2. Aug 17, 2024 at 1:07 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Welcome fellow 2008 TRD owner!
  3. Aug 17, 2024 at 1:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Don't forget ALL the other fluids, since you have no history. Brake, trans, diff(s) coolant
    Smart man to do a baseline!
    Welcome
    GilbertOz likes this.
  4. Aug 17, 2024 at 1:24 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Welcome aboard.
    Negative on the 36174 pulley for the tensioner. It will fit but due to the center offset, you lose too much thread engagement. It is better to replace the bearing in the pulley - 5203-2NS, 5203-2NSL, 5203-2RS (size 17X40X17.5). Or, Febest pulley/bearing # 0187-GRJ200 (China parts).
    Consider an ATF flush and diff/transfer case fluid change.
  5. Aug 17, 2024 at 2:19 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Welcome to TW. You’re doing it right, replacing/changing the things you should. Clean the MAF, people often overlook that. Also at a little over 100000 miles is when the water pump often starts to go. Carefully inspect make sure no weeping or seeping. Check your shocks, may be the originals. If the are originals they are shot.
    Check your spare tire, make sure there’s air in it. And has already been said replace the fluids.
    Post some pics.
    Williston likes this.
  6. Aug 17, 2024 at 3:38 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Welcome to TW.
    If you are replacing the blower motor resistor, I would recommend that you go OEM. I too went cheap and bought the Amazon one.
    It only lasted 4 months.
    Installed the OEM one from Toyota with the new different pigtail and it works so far, 8 months and counting.
    But most importantly. PICS! show us your new wheels!
    GilbertOz and Williston like this.
  7. Aug 18, 2024 at 8:32 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    ^^^This^^^
    Don't forget the transmission fluid. Mine had 104k on it when I got it. After weighing all of the input here, I decided to do a flush and fill on mine at 120k based on an early (good) service history of the truck and some signs on the drain and fill-plug that it had been done before. It has been fine sense. (now at 134,00k but I may do the drain-and change the next time.) Coolant is also very important and it gets old and acidic over time. I would do that next.
    I have a baseline now for everything and going forward, will follow the manual.
    Do the diffs and xfer-case next if its a 4x4.
    Mine all showed evidence that they had been opened before and I did them last spring @124k. The plugs had 115,000 on them. (Denso) The truck ran fine before and after I changed them, but it gets a little better gas mileage now.
    Keep us posted, and Welcome to TacomaWorld.
    :proposetoast:
    GilbertOz and Sprig like this.
