New to this - will these wheels fit?
Discussion in 'Toytec Lifts' started by rodp, Sep 14, 2009.
  1. Sep 14, 2009 at 9:17 PM
    rodp
    rodp [OP] Member
    Rod
    Alberta, Canada
    2009 SR5 V6 4x4
    Bilstein 5100s set at 2.5 front Bilstein 5100s rear Alcan 2" AAL Light Racing UCAs Toytec differential drop kit Toytec axle shims Undercover Tonneau
    Hi all, I just purchased a Toytec 3" lift for my 2009 Tacoma. The one for $299 with the 885 springs and the AALs. I also purchased the diff drop and the shims as suggested. Now I am looking at purchasing 20" KMC Hoss wheels 20x9 with 18 backspacing. This is the only backspacing option for this wheel from the retailer. Two questions - Will these wheels fit the tacoma with and without the 3" lift and will they stick out over the side of the truck? Any input is appreciated. Thanks!
  2. Sep 14, 2009 at 9:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    "18" isnt a back space im familliar with, so I cant help ya.
  3. Sep 14, 2009 at 9:20 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    and if chris doesnt know its not a good chance anyone else will
    oh and welcome! :thumbsup:
  4. Sep 14, 2009 at 9:21 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    do you plan to offroad at all?
  5. Sep 14, 2009 at 10:16 PM
    rodp
    rodp [OP] Member
    Rod
    Alberta, Canada
    2009 SR5 V6 4x4
    sorry... I meant offset. I am unsure of the back spacing.
  6. Sep 14, 2009 at 10:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    +18 or -18?
  7. Sep 14, 2009 at 10:17 PM
    rodp
    rodp [OP] Member
    Rod
    Alberta, Canada
    2009 SR5 V6 4x4
    I may offroad a few times a year.
  8. Sep 14, 2009 at 10:18 PM
    rodp
    rodp [OP] Member
    Rod
    Alberta, Canada
    2009 SR5 V6 4x4
    It is +18 offset.
  9. Sep 14, 2009 at 10:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depending on the back space, you should be ok.
  10. Sep 14, 2009 at 10:23 PM
    rodp
    rodp [OP] Member
    Rod
    Alberta, Canada
    2009 SR5 V6 4x4
    thanks Chris... I will find out and let you know.
  11. Sep 14, 2009 at 10:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  12. Sep 16, 2009 at 2:50 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    thanks for the help Chris!
  13. Oct 15, 2009 at 10:22 PM
    rodp
    rodp [OP] Member
    Rod
    Alberta, Canada
    2009 SR5 V6 4x4
    Chris, the backspace is 5.71. Can you tell me if these will fit. They are on backorder so I can still change my mind.
