New to towing and confused.
Discussion in 'Towing' started by thebthomas, Apr 11, 2010.
  1. Apr 11, 2010 at 1:04 PM
    thebthomas
    thebthomas [OP] New Member
    Brett
    Austin, TX
    08 Double cab shortbed TRD Off-Road
    factory towing package
    I have an 08 Tacoma double cab TRD shortbed with the towing package. The manual and stickers say my ratings are:
    gross vehicle weight - 5350
    gross combined vehicle weight - 11,100
    gross rear axle weight - 3110
    gross front axle weight - 2770
    Max towing - 6500
    Max tounge - 650
    I recently went to the landfill and weighed my truck with a full tank of fuel and it was 4,040. I have been researching buying a travel trailer and want to get the best bang for my buck. Can anyone tell me what kind of towing range I have with these ratings? Is 5100 lbs loaded out of the question?
    Also, does anyone have a number for the leaf spring TSB or where can I find more information about it.
    Thanks for any help.
  2. Apr 11, 2010 at 1:38 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    6500lbs is your towing capacity. That's the max you should tow.
    If the travel trailer weighs 5100lbs (off the lot/without cargo), then you can add approximately 1300lbs of stuff inside or on the travel trailer = not to exceed 6500lbs total that you are towing.
    GCVWR = 11,100lbs
    GCVWR is the total amount of weight you can have in the entire package (truck, trailer, cargo, EVERYTHING).
    Say for instance, your travel trailer = 6,000lbs (loaded w/ cargo). Your total truck weight (including passengers, cargo, gas, everything!!) must not exceed 5100lbs for a total of 11,100lbs.
  3. Apr 11, 2010 at 1:50 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    The Janster said it all. With an '08, I would go with air bags. You can inflate them when you tow for a level ride. Search ride rite or air lift.
