new to towing large items.
Discussion in 'Towing' started by colby8100, Sep 23, 2013.
Thread Status:
Not open for further replies.
  1. Sep 23, 2013 at 5:28 PM
    colby8100
    colby8100 [OP] Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    First the search doesn't work on my phone. I tried on google before posting. I use to tow 3000lb boat with my 01 2.4l (now 2jz) standard cab straight drive but I decated it to drag racing. So I bought a 13 4door sr5 pre runner its was supposed to be a v6 but thet messed up and got me a 2 7 but with more luxury option. My 01 weighs around 2000lbs with 1100hp so add tools and passengers probably 3000lbs I haven't gotten a trailer yet but just a 1 car hauler I'm assuming around 2000lbs? My question is will it tow it safely. I don't know if it has a trans cooler but I can add one and it doesn't have tow package. It says like 6400lb capable with 2.7 I know its strong enough I'm just worried bout trans.
  2. Sep 23, 2013 at 5:31 PM
    colby8100
    Colby
    South carolin
    I'm going to order a stant hitch with the tail light plugs I don't think I need a brake controller but I want to go from sc to tx for tx2k and I want to be ready
  3. Sep 23, 2013 at 6:07 PM
    smd3
    smd3 Well-Known Member
    Take the 2.7 back for a 4.0 and maybe.
    The 2.7 isn't rated for 6400lb. All the weights and capacities are in your manual.
    Get trailer brakes and a controller, everyone else on the road will thank you.
  4. Sep 23, 2013 at 6:22 PM
    colby8100
    Colby
    South carolin
    It should be fine according to the book. The motor isn't the issue its the trans and suspension. Its says 7500gvtw and 3500 tw.
  5. Sep 24, 2013 at 4:15 AM
    smd3
    5000lb is fine for the 2.7 according to the book?
    OP's saying 3k for the truck he wants to tow, including tools and such. And he figures 2k for the trailer.
  6. Sep 24, 2013 at 11:30 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    13 Access 4x4 TRD Offroad
    Empty gas tank mod
    Yes, it says that, which means he can tow 3500lbs. However, I don't understand that, my gen 1 2.7L was rated for 5000. Mine was a 4x4... maybe the 2WD is 3500?
    Trust me, I tow a lot... do not exceed the capacity your vehicle is rated for. It's damn dangerous.
  7. Sep 24, 2013 at 11:35 AM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    X2. And scary with a 9000lb camper at night :anonymous:
  8. Sep 24, 2013 at 5:12 PM
    colby8100
    Colby
    South carolin
    I'm gonna put a trans cooler it'll be fine. My 01 after I put a 1jz in it with an a341e it had 280hp but I towed a 3500lb boat at 90mph for 30+ miles so a 150hp truck should tow 5000lbs 40ish miles. Now the texas trip may just use my cousin and his dmax
  9. Sep 24, 2013 at 5:13 PM
    169.254.255.201 Well-Known Member
    Interwebs
    Don't
  10. Sep 24, 2013 at 5:14 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I'm so confused
  11. Sep 24, 2013 at 5:22 PM
    rev25sharp
    rev25sharp Well-Known Member
    Al
    jacksonville fl
    thats not very smart
  12. Sep 24, 2013 at 5:24 PM
    colby8100
    Colby
    South carolin
    You got to remember they're all the same frames and 6lug axles just different ratios. The body is the sane strength on all now the motor is different about 100hp. Now a v8 even in some 90s models only had 200hp. The only thing that would damage it would be the constant down shift but the road is mostly flat. Si if I add a large cooler it'll compensate temps. Now factory tow package is super small. I know I just put an apron, upper rail, and radiator support in a 12 today. My concern is pulling 5000 lbs around 50-60 mph not flying has anyone else done it with a 2.7 and what problems occured. Swaying, over heating, ect...
  13. Sep 24, 2013 at 5:29 PM
    Interwebs
    Confused with how adding a trans cooler will make it safer..
    Any one else?
  14. Sep 24, 2013 at 5:39 PM
    colby8100
    Colby
    South carolin
    Its common sense obviously the planetary gears aren't going to explode from that much weight I'm assuming the trans are the same Toyota usually uses the same one on all models. Example a340e on first gen taco, supra, v6 runners then a341e on v8s with exception of some lexus over seas. Now the constant down shifting (if occurs) could heat trans up due to constant pressure increases. Now larger cooler keeps temps down and 150hp is plenty for 5000lbs. Now I needs someone with mechanical knowledge to explain to me why it wouldn't work. Braking should be close to v6 model the only difference is hp and torque.
  15. Sep 24, 2013 at 5:53 PM
    AWalker
    AWalker Well-Known Member
    Adam
    Tacoma Washington
    08 DC LB SR5
    O.M.E 885 Dakars nitros Snugtop allpro skids allpro bumper 4X inovations sliders Jayco pop up camper Torklift tiedowns
    I just towed 2k lb of wood pellets in a 1k lb trailer with hydrolic brakes with my 08 double cab v6 with tow package and Dakar springs. Even with only around 3k you definitely feel it behind you up hill, lots of hills where I live, but don't notice it much on flat. My travel trailer loaded weighs close to 5k. I have electric brakes, sway bar and weight distribution hitch and feel that 5k is realistically what I am comfortable towing with this truck. Just because you think you can doesn't mean you should.
  16. Sep 24, 2013 at 6:00 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Port Arthur/Lubbock, Tx
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    ^^^^^^This, I tow a 12'enclosed and a 16' lowboy, each with more than 6500lbs with my v6. You have an I4, the weight that you want to tow is not safe for you or your truck. But hey, we can't stop you.
  17. Sep 24, 2013 at 6:01 PM
    User Name01
    Bolbi Stroganovsky
    I was reffering to OP in last post, just making it clear.
  18. Sep 24, 2013 at 6:05 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Wow what I derp thread this is turning out to be . I suggest you look up your states vehicle code in regards to what weight is required for trailer brakes. But besides that ...you will need trailer brakes!! I can almost guarantee that you are over the limit for your little 4 banger by what what you are describing anyways :facepalm:
    This is what I tow so I know first hand about the braking capabilities ..
  19. Sep 24, 2013 at 6:10 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    I towed our rhino and an ATV in the bed without trailer brakes and I will say, even that size of a load needed brakes. It felt like I had barely any brakes and I had to brake way before I regularly have to.
  20. Sep 24, 2013 at 6:46 PM
    rickcrna
    rickcrna Well-Known Member
    Rick
    Vancouver, WA
    '13 AC SR5 4WD I4 Auto MGM
    OP is from South Carolina....you are not going to talk sense to him. Like arguing with a post. I hope he doesn't take out some innocent people trying to foolishly tow something he shouldn't.
Thread Status:
