New to trucks, need rim/tire sizing help!
Discussion in '5 Lug' started by regcab2wd2014, Sep 22, 2018.
  1. Sep 22, 2018 at 8:56 AM
    regcab2wd2014
    regcab2wd2014 [OP] Member
    Hi, everyone. I recently purchased a 2014 2wd Regular Cab Tacoma. I do not like the stock rims and tires that are currently on it. The rims are 15x6j, bolt pattern is 5x114.3, and the tires are 215/70r15. I would like to know exactly what size tires and rims I could go up to (preferably 16/17 inch rims) without modifying the truck or scrubbing in any way. I would like to have all terrain or off road tires simply for aesthetic purposes. As I said previously, I am extremely new to trucks, and I would appreciate any help.
  2. Sep 22, 2018 at 10:51 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I would say 16”rim max (15” rims will give more options) and possibly only going max 1” greater in diameter is as you can really do with 0 modification. If you remove the black box you can go slightly larger
  3. Sep 22, 2018 at 10:57 AM
    regcab2wd2014
    Is there somewhere I could look to find out what size tires would fit? Say I get 16" rims, how would I know which tires could fit in there?
  4. Sep 22, 2018 at 11:01 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You can compare tire sizes and see what on a 15 is the the same as a 16” and go up a little from that. Usally rule of thumb is you can go 1” bigger in tire size on stock suspension
  5. Sep 22, 2018 at 11:03 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    For example
    Stock
    Possible new size
  6. Sep 22, 2018 at 11:15 AM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I'd go with 16" rims and either 265-70-16 or 265-75-16.
    265-75 is the biggest you can go on 16" rims without rubbing or cutting (generally).
  7. Sep 22, 2018 at 11:16 AM
    NMTrailRider
    New Mexico
    If you have the 4cyl I'd do 265-70-16. Just one opinion of many.
  8. Sep 22, 2018 at 11:17 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    He is a 5lug
    NMTrailRider[QUOTED] likes this.
  9. Sep 22, 2018 at 11:18 AM
    NMTrailRider
    New Mexico
    Ah. My bad. Sorry.
    Sperrunner[QUOTED] likes this.
  10. Sep 22, 2018 at 11:21 AM
    regcab2wd2014
    I found some 235/75/15 tires that I like. I heard that these fit very well in my truck with no lift. Now the question of my rims... the stock ones are 6jx15 with 35 offset. I know I need to keep the rims at 15 and stay close to the stock offset. But what does the 6J stand for and how far can I stray from that?
  11. Sep 22, 2018 at 11:24 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    6j is the width of the rim
    Max you probably wanna go is 8” wide and keeping the same offset
    But nothing is wrong with 6” you can run those tires in the stock wheels.
  12. Sep 22, 2018 at 11:41 AM
    regcab2wd2014
    I'm having a pretty hard time finding rims that are 15x6-8 5x114.3 with 35 offset. :annoyed:
  13. Sep 22, 2018 at 11:47 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I think they are like 3.5” bs right?
    Also remember they have to have a hub bore of 60.1 to be hub centric or bigger
  14. Sep 22, 2018 at 11:53 AM
    regcab2wd2014
    where do I find my stock backspacing? I am REALLY new to all of this
  15. Sep 22, 2018 at 11:54 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You can measure it yourself if you have a wheel off
    Its from the mounting surface to the lip of the rim
  16. Sep 22, 2018 at 11:55 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You can also look for rim in 5x4.5 because its the same as 5x114.3
  17. Sep 22, 2018 at 12:03 PM
    regcab2wd2014
    Okay. Not purchasing these for sure, but if I did, wouldn't they fit?
  18. Sep 22, 2018 at 12:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yes they would fit
    Idk about the bs. 5 seems alot but idk what the stock bs is
  19. Sep 22, 2018 at 12:10 PM
    regcab2wd2014
    This website says that the hub bore for the wheels is smaller than the bore for my truck, I'm confused!
  20. Sep 22, 2018 at 12:12 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    That hub bore is much larger.
    It will fit but you either need adapters to make hub centric or use cone style lugnuts to center the wheel
