New to TW and buying a 2018 TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Huntgoddess, Apr 28, 2021.
  1. Apr 28, 2021 at 8:17 AM
    Huntgoddess
    Huntgoddess [OP] New Member
    Is there anything I should be on the look out for when buying a 2018 Tacoma TRD Sport with a manual transmission. I’m smitten with the truck, but should I get a reality check?
    Junkhead likes this.
  2. Apr 28, 2021 at 8:57 AM
    Ydog32
    Ydog32 Well-Known Member
    Wyatt
    2021 MGM DCLB TRD Sport 4x4
    OEM lift 2” front 1.5” rear, Black TRD Pro Grill,275/70 R17 KO2 Tires, Backflip Bak 4x Tonneau Cover, Mountain Hitch Tailgate Insert, Tint, 17" FN f(x) wheels.
    I have a 2021 sport, I love it and would have gone MT if my wife knew how to drive stick. I sometimes wish I went with the Offroad though.
  3. Apr 28, 2021 at 8:59 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    timing cover, it's a topic beat to death. Not every truck will experience that, poorly maintained ones tend to suffer from it.
    take a look and if it's leaking. If leaking, try to get it fix under warranty.
    another note, test drive see if you like the manual transmission. It is weird if you aren't used to accumulator/dampened clutch.
  4. Apr 28, 2021 at 8:59 AM
    kyledamon
    kyledamon Well-Known Member
    Colchester, VT
    2016 AC TRD OR
    What do you like about the Sport Vs the Off-road? They’re both amazing trucks either way but the Manual only comes in the Sport trim
  5. Apr 28, 2021 at 9:31 AM
    BRBNNEAT
    BRBNNEAT Well-Known Member
    Madison, WI
    2021 TRD Offroad-6 speed
    I have an off road manual... all of the TRD's you can get in a manual.
    Spare Parts likes this.
  6. Apr 28, 2021 at 10:16 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    18 sport auto here, no problems at all.
  7. Apr 28, 2021 at 10:35 AM
    tacobelletx
    tacobelletx Well-Known Member
    TX
    '18 Sport ACLB
    Going off @kyledamon's photo/trucks listed - he probably commented that you can't get a manual off road because he has an access cab. You can in double cab though.
    kyledamon likes this.
  8. Apr 28, 2021 at 10:51 AM
    Doctor_Bear
    Doctor_Bear トヨタ
    WA state
    '18 MGM Sport AC MT
    MESO mods: Total tail stage 1, Dome Map LEDs, Puddle Pods w/ Switc, MGM vent + 4x4 rings, Gashole, smoked mirror turn signal LEDs Other Mods: '21 TRD Grill, LED foglights, Kenwood 10" carplay Stereo, CV 10" underseat Subwoofer, blackout vinyl on sport wheels, custom vinyl TSS cover
    18 sport manual here.. Love this truck! Just finished up the toyotacare maintenance plan but did not have any non-standard maintenance events yet with this truck.
    Huntgoddess[OP] and Junkhead like this.
  9. Apr 28, 2021 at 11:00 AM
    18trdsport
    18trdsport Well-Known Member
    Bay Area, CA
    2018 TRD Sport ACLB MT
    I have a manual sport. No problems with how it drives. What are your concerns?
  10. Apr 28, 2021 at 11:16 AM
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    had a 16 sport that had some minor issues. Leaking 3rd brake light, water-filled license plate lights, low transmission fluid from the factory, and a squeaky belt at around 45k miles.
    I have a 21 sport now and had vibrations on decel from 30-10. It was fixed under the TSB. They replaced my leaf springs, added a steering damper and checked the diff angle
    I believe they got the majority of the kinks worked out by the 18 model year. If it has a lift I would see if it has the vibrations in it in 2WD to see if the needle bearing needs replaced with the ECGS one. If its stock shouldn't be an issue.
  11. Apr 28, 2021 at 11:19 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Fuel pump recall and 3rd brake light leak
  12. Apr 28, 2021 at 11:26 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    2018 sport manual here. Excellent machine, none of the TW issues. Love driving this thing! Will keep her till wheels fall off.
  13. Apr 28, 2021 at 11:38 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    When you're smitten you should ALWAYS get a reality check.
  14. Apr 28, 2021 at 3:05 PM
    kyledamon
    Colchester, VT
    2016 AC TRD OR
    Spot on! Haha.
    tacobelletx[QUOTED] likes this.
  15. Apr 28, 2021 at 4:20 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    I'll second the third brake light leak, mine was in the cab and starting to cause some light mildew before I noticed (2016). I've heard it was fixed mid year 2018 so it may or may not have an issue but it's something to keep an eye on. Automated carwash or a hose around the light makes it pretty obvious or just checking behind the back seats for water streaks in the dust, that's how I first found mine.
    MT should save you the headache of the AT shifting nonsense, at least sans tune. If you do purchase, I'd highly recommend checking out the community tunes here. I'm unable to flash until a new tool is released but I hear rave reviews of the hard work members have put in tuning this truck here.
    I'm 78,000 miles in so far and no real mechanical issues, just lots of small stuff but mine is a 10/2015 build so I'd bet by 2018 you're getting one with most of the kinks worked out. Enjoy the truck!
  16. Apr 28, 2021 at 5:39 PM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    I have an '18 manual Sport, it's a great truck. Only issue has been squeaky clutch pedal, replaced twice under 2 tsb's, so far so good on this one.
    Oh, there was a fuel pump recall, but I didn't notice any issues before it was replaced. Check to see if that was done.
    If you have a trusted mechanic, get it checked out before you buy it.
  17. May 4, 2021 at 10:59 PM
    dennguy08
    dennguy08 Well-Known Member
    2018 Cement Tacoma TRD OR
    If you don't need the locker on the OR, the sport is an awesome truck. Don't really care for the other features on the OR.
  18. May 5, 2021 at 2:23 AM
    garander
    garander Well-Known Member
    2019 trd sport dcsb mt
    2019 manual sport 32 k miles , daily driver . Enjoying every ride .
    The 4.30 rear is a bonus . Only issue was the squeaky clutch pedal ,
    Replaced by tsb . No off roading but i work the taco hard .
