new total chaos lower control arm
Discussion in 'Suspension' started by straycat241, Mar 22, 2010.
  1. Sep 18, 2011 at 8:37 PM
    #101
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    see how mine turns out....could change your mind....or give you reason to make fun of me. we'll see.
  2. Sep 18, 2011 at 8:38 PM
    #102
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    is that in your build and if you want help and input on it i can help some you aint far away
  3. Sep 18, 2011 at 9:04 PM
    #103
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i want to get shocks and springs before i start the the cage so i can use actualy parts to build it around instead of just measurements
  4. Sep 18, 2011 at 10:28 PM
    #104
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Yo Paul! You going to Pismo? Brandon and I hope to see you up there!
    Oh yeah, this is a thread about TC Lower Control Arms. I picked mine up from the guys at Down South Motor Sports - great guys. The problem is that these are not compatable with the Camburg UCAs - bummer too cause I like them. In your case they maybe cause aren't you running Camburg spindles too? I hope to swap my Camburg UCAs with some TCs so I can stop some of the wondering!
  5. Sep 20, 2011 at 7:21 PM
    #105
    johnw
    john
    orlando florida
  6. Sep 20, 2011 at 7:31 PM
    #106
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    How aren't compatible with the Camburg UCA's?!:confused: only problem I see is that the UCA will out cycle the LCA (bigger Uniball) but the CV's will bind before that would happen (I think).
    Edit: Are you going to be adding a 2nd Shock up from?!
  7. Sep 20, 2011 at 8:00 PM
    #107
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I was wondering the same
