New Toyo Open Country A/T III tire
Discussion in 'Wheels & Tires' started by Drifter001, Feb 29, 2020.
  1. Sep 5, 2020 at 7:09 AM
    #481
    woodshampoo
    woodshampoo Well-Known Member
    VA
    2018 DC OR 4x4
    Getting a set... Finally decided... 265/75r16... 165 installed and 60 for alignment
    opteron likes this.
  2. Sep 5, 2020 at 7:12 AM
    #482
    IdeaMan
    IdeaMan Well-Known Member
    Jim
    Fresno, CA
    Barcelona Red 2018 Toyota Tacoma SR DCSB 4x4
    Eibach Pro Truck Lift, Icon RXT Leaf Springs, LT255/80R17 Toyo ATIII, Body Armor Hiline Bumper w/OZ LED Light bar and Smittybuilt X20 Synthetic Winch, TRD Pro Skid plate, Shrockworks Sliders/steps, bed mat, some interior storage accessories, cell phone mount, and blacked out emblems.
    I went into Discount Tire (America’s Tire here) and showed them 4WheelParts.com had the Toyo A/T III LT255/80R17 for about $1 less, and they had a 10% off Labor Day coupon code so I was given $110 off ($22 per tire x 5) no questions asked. Tires are on order, still waiting for them and crossing my fingers about no rub with 4Runner Pro/SEMA wheels I’ve got sitting here in the box.
    TACO TM and deusxanime like this.
  3. Sep 6, 2020 at 5:41 PM
    #483
    TRDOFFRD510
    TRDOFFRD510 Well-Known Member
    NNNNNNNNNN
    @Discount Tire can i get the same offer for 285 75 16? Thanks
  4. Sep 8, 2020 at 6:48 AM
    #484
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    We appreciate the opportunity at your business @TRDOFFRD510!
    We're happy to look into this for you. If you would, please shoot us a PM with your zip code and the link to the competitor :thumbsup:
    Chukwithak, Biscuits and Thatbassguy like this.
  5. Sep 8, 2020 at 8:06 AM
    #485
    TRDOFFRD510
    NNNNNNNNNN
    Pm sent
  6. Sep 12, 2020 at 8:09 AM
    #486
    woodshampoo
    VA
    2018 DC OR 4x4
    Finally.... New shoes...
    9mmMike and Brownie_Man like this.
  7. Sep 13, 2020 at 1:44 PM
    #487
    5e11even
    5e11even Member
    Oahu, Hawaii
    2018 Tacoma TRD Sport 4x4
    Just got them installed after riding on the stock Toyo A30s for so long. So much better.
    265/70r17 on the TRD Sema wheels on stock TRD Sport suspension. I think there is a slight rub on the left rear side fender which I think is from full lock reversing but I need to check more as I drive.
  8. Sep 13, 2020 at 4:57 PM
    #488
    woodshampoo
    VA
    2018 DC OR 4x4
    Just to add to this... Yes even the p series has a more aggressive side. As noted it includes the line in the sidewall. Does change the look. Mine had a yellow dot on the sidewall that was more aggressive.
    And there were also blue and yellow lines on the tread. Blue line was closest to the more aggressive sidewall.
    Last thing... Still figuring out best pressure but the shop put them at 38 cold... That felt like a bit much.
    Starman2112 likes this.
  9. Sep 13, 2020 at 10:01 PM
    #489
    Silver'16TRDSportDCLB
    Silver'16TRDSportDCLB Well-Unknown Member
    Nate
    South-Eastern PA
    2016 Silver Tacoma 4x4 Sport DCLB
    Lights, stickers, audio, and a grille…
    Does anyone know why the OWL version weighs 3lbs per tire heavier then the standard black sidewalls? My dad was old school and always ran with the OWL facing out, so as an homage to him I try and buy OWL when available. Toyo sells this tire in the size and load range I'm looking for, but lists the OWL version at 3lbs heavier. You guys think it's a typo, or am I missing something here?
  10. Sep 14, 2020 at 6:29 AM
    #490
    huntercole
    huntercole Active Member
    Hunter
    2015 TRD Off Road DCSB
    It's also slightly taller on the 265/75r16 size. I think someone posted earlier that Toyo said it had an extra layer of rubber or something that added the extra weight.
  11. Sep 14, 2020 at 6:43 AM
    #491
    huntercole
    Hunter
    https://www.tacomaworld.com/threads/new-toyo-open-country-a-t-iii-tire.655094/page-13#post-23406060
    Brownie_Man and boostedka like this.
  12. Sep 14, 2020 at 7:38 AM
    #492
    Nate
    South-Eastern PA
    Ok, got it. So both black sidewalls, and the OWL in that size must be produced in Japan, hence the OWL weighing 3lbs more due to an additional layer of rubber in the sidewall. This is why I love this forum, I got an answer from you guys faster then I did from Toyo.
    Thanks for the help,
    Nate.
    Archangel likes this.
  13. Sep 14, 2020 at 7:46 AM
    #493
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    5k on my Toyos so far.... smooth, quiet, and holding up well!
    Yodapwnedjoo and RPVTaco like this.
  14. Sep 14, 2020 at 12:01 PM
    #494
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    The question should be. That weight difference is not consistent across sizes and why is a C load rating only one pound lighter than an E load rating? That is the case in the 285/75-17 BSW but in the case of the the 285/70-17 the C load rated BSW is 2 pounds heavier than the E load rated OWL. I had the question for Toyo USA why no C load rating in 16" but there were in 17". But with only a pound difference maybe C's are not needed. I would like to see how the C's vs the E's do when aired down. So many questions.
  15. Sep 17, 2020 at 7:40 PM
    #495
    Nate
    South-Eastern PA
    Got me some SL 265/70R17 OWL going on Saturday morning! Pics to follow!:D:cool:
  16. Sep 18, 2020 at 11:01 AM
    #496
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Is the tread different between BSW vs OWL in SL rating? Pictures of the BSW show the extra syping where all of the pictures of OWL I've seen show the same tread as the LT version.
    265/75/16
  17. Sep 18, 2020 at 11:48 AM
    #497
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I thought the difference was between the SL vs. the E rated tires. It might just be that BSW/OWL is different between those ratings on the tires, so I guess that might also be technically true also.
  18. Sep 19, 2020 at 5:45 PM
    #498
    Nate
    South-Eastern PA
    Sorry, busy day. Here they are.
  19. Sep 19, 2020 at 5:49 PM
    #499
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    I sent you a PM!
  20. Sep 19, 2020 at 7:36 PM
    #500
    SoCali_Guy
    SoCali_Guy Well-Known Member
    California
    TRD OFF ROAD
    did you go with SL or E rated?
