New Toyo Open Country A/T III tire
Discussion in 'Wheels & Tires' started by Drifter001, Feb 29, 2020.
  1. Nov 2, 2020 at 10:43 AM
    #661
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
  2. Nov 2, 2020 at 11:02 AM
    #662
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Wow, solid. Those look great. That's the 35/11.5/17 size?
    What did you have to do to fit them? I see you lost the mudflaps. Anything else in terms of cutting?
  3. Nov 2, 2020 at 11:02 AM
    #663
    ItalynStylion
    Steven
    DFW, Tx.
    PS: I got a call back from Discount Tire. There is indeed a national backorder so typical places can't get them right now. No big deal for me since I'm not in a hurry.
  4. Nov 2, 2020 at 11:20 AM
    #664
    Jesse
    Poulsbo
    15' DCSB OR S/C
    none. truck never came with flaps. final clearence check to be done in a week. for street use a 6" bracket lift clears fine. correct on the tire size.
  5. Nov 2, 2020 at 11:38 AM
    #665
    zw470
    zw470 Well-Known Member
    Marty
    I'll go ahead and speak for everyone and say we want pics regardless of what vehicle they're on.
  6. Nov 2, 2020 at 11:47 AM
    #666
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    PM on the way, we may be able to assist with this.
    Thank you for the opportunity to earn your business. If we can be of any assistance on our end feel free to reach out, we will make sure you are taken care of.
    Thatbassguy likes this.
  7. Nov 2, 2020 at 12:00 PM
    #667
    Jesse
    Poulsbo
    15' DCSB OR S/C
    discount helped me out with a last minute mount and balance friday. the other shop i scheduled with said i had to bring the weights myself, once i showed up. rat bastards. thank you discount tire!
  8. Nov 2, 2020 at 12:07 PM
    #668
    ItalynStylion
    Steven
    DFW, Tx.
  9. Nov 2, 2020 at 12:08 PM
    #669
    ItalynStylion
    Steven
    DFW, Tx.
    Bring your own weights? Really? WTF is that about? I bet they wanted you to bring your own balance machine too?
    deusxanime likes this.
  10. Nov 2, 2020 at 12:13 PM
    #670
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yeah. just stupid. i wont be going there ever. ill do my own alignment before they touch my truck.
  11. Nov 2, 2020 at 12:30 PM
    #671
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Here you go. Mounted and unloaded at 38 PSI, just shy of 36.25”
    Edit: Didn't account for ruler height, actual is 34.25".
  12. Nov 2, 2020 at 12:30 PM
    #672
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Any body have first hand experience with Toyo AT3 E-load rating sidewall durability compared to Cooper ST Max and STT Pro Armor-Tek3? Is the Toyo AT3 load rating E sidewall 2 or 3 ply?
  13. Nov 2, 2020 at 1:04 PM
    #673
    ItalynStylion
    Steven
    DFW, Tx.
    Holy damn....really? Toyo claims them to be 34.5" for the ones that are 35/11.5/17, right? Nearly two inches bigger is unexpected...
  14. Nov 2, 2020 at 1:27 PM
    #674
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Wow. Rookie mistake on my part, as that includes the width of the ruler which is exactly 2", so actual measured distance is 34.25".
  15. Nov 2, 2020 at 1:28 PM
    #675
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    ATIIIs in 35/11.5r17 C-load weigh the same as the stock 285/70r17 C-load Wildpeaks they replaced, 63lbs.
  16. Nov 2, 2020 at 1:29 PM
    #676
    zw470
    Marty
    :thumbsup:
    Do the sidewalls look any more "aggressive" than the LT sidewalls that have been previously posted?
  17. Nov 2, 2020 at 1:35 PM
    #677
    BennyBen
    BennyBen Well-Known Member
    Ben
    2019 SR5 4X4
    You get a pass, good sir.
  18. Nov 2, 2020 at 1:42 PM
    #678
    ItalynStylion
    Steven
    DFW, Tx.
    The fact that he put his vehicle in the air and took measurements is deserving of more than one pass haha. Thanks again for measuring. Good to know the manufacturers specs are actually pretty accurate in this case!
    PS: They look good on the truck, even if it IS a Jeep! :D
  19. Nov 2, 2020 at 3:36 PM
    #679
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can be the judge. Interestingly the sidewall lugs are ramped a bit, that is on the leading edge the lip is small but on the trailing edge the lip is large, so the aggressiveness may appear slightly different on the same tire depending on which direction you are looking at them. They are less aggressive than the KO2s and Wildpeaks for sure.
    Didn’t have to go that far. I haven’t mounted the full size spare under the bed yet, so I had easy access to an unloaded tire. :)
  20. Nov 2, 2020 at 3:45 PM
    #680
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i suppose a slightly more tame side bite has to do with the effort of weight savings. i do agree with @crashnburn80 about the road noise. it is more than my previous K02's. but nowhere near a dedicated m/t like ive had in the past. i think im most impressed with the size. just perfect. i may not even need a cmc at all.
    crashnburn80 likes this.
