New Toyo Open Country A/T III tire
Discussion in 'Wheels & Tires' started by Drifter001, Feb 29, 2020.
  1. Nov 8, 2020 at 9:15 PM
    #701
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I've run the KO2s for the past 7 years, they have been fine in the winter. All AT tires will suck on actual ice.
    I do have winter tires Blizzack DMV2 to put on as well but last year I didn't bother putting them on.
    Lots of guys run the Duratracs, @friendlywithbears and I think @WormSquirts have run them for quite a while. Those guys are out in the bush lots.
    I do think the Toyo look better than the Falken.
  2. Nov 8, 2020 at 10:50 PM
    #702
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Fixed.
  3. Nov 9, 2020 at 1:40 PM
    #703
    huntercole
    huntercole Active Member
    Hunter
    2015 TRD Off Road DCSB
    As of now all LT 265/75/R16 are made in Japan and have the less aggressive sidewall. After I called Toyo they called me back and asked if they could forward my number on to someone else for me to talk to. It ended up being the designer of the tire. He confirmed that this size is made in Japan and that the molds (sidewalls) are different. The sizes that are made in Japan are specific sizes and not all of one wheel size is made in one place or the other. He said they are trying to get the molds updated so that all the tires have the same sidewall. I actually talked to him for quite a while and he was really straightforward and understanding on this issue. He's a Toyota guy as well.
    I think your best bet is to call toyo direct to see where the specific tire you want is made if it hasn't already been confirmed on here somewhere.
  4. Nov 9, 2020 at 2:47 PM
    #704
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Wow cool, thanks for the update!
  5. Nov 9, 2020 at 2:52 PM
    #705
    huntercole
    Hunter
    By all tires having the same sidewall after the molds are updated, I mean the black sidewall LT tires. I'd assume the SL would still be the less aggressive version. Not sure on the OWL LT tires.
  6. Nov 9, 2020 at 9:05 PM
    #706
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    We need to continue to try and use the correct terms in order to avoid continued confusion. On ALL loads and sizes (regardless of manufacture origin), Toyo makes a "less aggressive" and "more aggressive" sidewall pattern distinguished by an extra line down the middle of sidewall pattern and outer tread blocks.
    What Toyo needs to do is change the molds so that ALL loads and sizes (regardless of USA or Japan manufacture origin), have the same sidewall pattern Thickness AKA = To All USA Made Tires!
    huntercole[QUOTED] likes this.
  7. Nov 13, 2020 at 8:17 AM
    #707
    Josh-L
    Josh-L Well-Known Member
    2021 Silver SR DCSB V6 4x4
    Thoughts on these in a 265/60R18 for a daily driver? They're the same diameter as the stock setup that came on my SR just wider. Curious if they would ride any better on the road or how it would affect MPGs. I'm also assuming no rubbing issues since these come stock on the Limited but not sure if the Limited has different suspension than the SR.
  8. Nov 15, 2020 at 6:07 PM
    #708
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Another trip up to the hill and another snow storm to test out winter performance on my SLs. I'm still really impressed with their grip on both plowed/compact roads and 1.5ft of loose/fresh powder!
  9. Nov 20, 2020 at 11:57 AM
    #709
    CCinABQ
    CCinABQ Active Member
    Carl
    2021 TRD OR
    IMG_20201120_122654.jpg IMG_20201120_122706.jpg IMG_20201120_122727.jpg IMG_20201120_122736.jpg IMG_20201120_122751.jpg IMG_20201120_122801.jpg IMG_20201120_122828.jpg IMG_20201120_123038.jpg IMG_20201120_123046.jpg IMG_20201120_123055.jpg IMG_20201120_123127.jpg IMG_20201120_123135.jpg IMG_20201120_123423.jpg IMG_20201120_123427.jpg IMG_20201120_123435.jpg IMG_20201120_123504.jpg IMG_20201120_123005~2.jpg Okay guys... Here is my 2021 TRD OR w/ TRD Pro Wheels (16x7et13), Stock/OE Suspension, and P265/70r16 Toyo's.... I am loving them... here is way too many pics!
  10. Nov 20, 2020 at 12:31 PM
    #710
    littleblue81
    littleblue81 Well-Known Member
    Played around in a little snow last weekend. Here is a short and relatively useless clip. lol
    They did perform pretty well. Drove on some hard pack/ice over cement too.
    Superhulk LB and 9mmMike like this.
  11. Nov 20, 2020 at 12:47 PM
    #711
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    Wow, after reading through this thread and shopping around for tires I’m going to stay away from these due to the inconsistency and insufficiency from Toyo. I do like this tire but don’t feel like going through the hassle trying to get the right tire. Toyo really does need to work on this.
    TacX2 and huntercole like this.
  12. Nov 20, 2020 at 12:58 PM
    #712
    3GTNATE
    3GTNATE Well-Known Member
    Central Coast, CA
    2021 Cement TRD Off-Road 4x4 DCSB
    Just send it and get LT size, it’ll be what you want
  13. Nov 20, 2020 at 1:24 PM
    #713
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
  14. Nov 20, 2020 at 1:26 PM
    #714
    9mmMike
    9mmMike Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    Nice 1st post!
    CCinABQ[QUOTED] likes this.
  15. Nov 20, 2020 at 1:36 PM
    #715
    huntercole
    Hunter
    Unless its LT265/75R16 or LT285/75R16
    TACO TM likes this.
  16. Nov 20, 2020 at 1:43 PM
    #716
    BroID
    The Gem State
    I want this tire in a 295/75r16. No information that I can find on what I might get with that tire from Toyo.
  17. Nov 20, 2020 at 2:05 PM
    #717
    huntercole
    Hunter
    Probably just have to call them and ask where that specific tire is made. Being a black side wall LT you would assume USA and have the deeper sidewall tread, but that's not the case for the LT265/75R16 or LT285/75R16. If you do call and they say Japan(shallower sidewall tread) maybe let them know if that influences your buying decision or not.
  18. Nov 20, 2020 at 2:11 PM
    #718
    3GTNATE
    Central Coast, CA
    Most places won’t have them in stock, they’ll have to order. No way of knowing where they’re made until visually inspecting in person. For me at least, I didn’t have to put down any kind of deposit to order these tires from DD because I raised this concern and they were cool with it. Possibly worth the shot if you’re stuck on these?
  19. Nov 20, 2020 at 3:57 PM
    #719
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Very nice! I like the looks of them .. are these the same as SL-load ?
  20. Nov 20, 2020 at 6:57 PM
    #720
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    well, i found the limits of these tires. hard boost at 50+ rise in the road had me drifting back and fourth 5 zags. drove out of it thankfully. dont expect these to be high performance tires. quite frighnening really.
