New Toyo Open Country A/T III tire
Discussion in 'Wheels & Tires' started by Drifter001, Feb 29, 2020.
  1. Jan 15, 2021 at 11:43 AM
    #841
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Can confirm. Mine state made in USA.
    TACO TM[QUOTED] likes this.
  2. Jan 16, 2021 at 2:50 PM
    #842
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Keep us posted on how they ride and what you are comparing them too.
  3. Jan 16, 2021 at 3:32 PM
    #843
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    I’m torn between these and the Cooper at3 xlt.
  4. Jan 16, 2021 at 3:41 PM
    #844
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    I'm dying to see these in a C load.
    I'm worried the sidewalls will look like the SL.
    35x11.5x17 C loads are also very similar and on the table.
    Need some new shoes for my FN FX Pros.
  5. Jan 16, 2021 at 5:42 PM
    #845
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Aren't the XLT's meant for like one ton/superduty size trucks?
  6. Jan 16, 2021 at 7:23 PM
    #846
    TACO TM
    TACO TM Well-Known Member
    2021 Pro
    Toyo has the 3PMSF rating which might come in handy depending on what you drive though.
  7. Jan 16, 2021 at 7:28 PM
    #847
    TACO TM
    2021 Pro
    I think that could be said for many E rated tires that find their way onto our rigs.
  8. Jan 17, 2021 at 2:47 PM
    #848
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Ya, those XLT's are designed for hauling/towing heavy loads and only come in larger sizes...
  9. Jan 17, 2021 at 4:35 PM
    #849
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    C load have the same sidewall as the other LT versions. Mine are LT285/70/17 load range C and have the deeper sidewall.
  10. Jan 18, 2021 at 4:54 PM
    #850
    svendough
    svendough Well-Known Member
    Colorado
    2020 Cement DCSB OR
    Skinny rubber, Bilstein lift, iKamper
    Just ordered a set from my local Discount Tire—pics once they're installed.
    I only wanted to say two things. First, thanks for all the info, and more importantly, photos in this thread. Second, when I was talking with the sales rep I mentioned that I was waffling between these and the Wildpeak's. He recommended that I stay away from Falken. In his experience, he's seen nothing but issues. Lot's of Wildpeak's (at this location) getting replaced multiple times to find a set that would balance properly. Really interesting for a tire that is so popular. In either case, the Toyo's should tick all of my boxes. Can't wait!
  11. Jan 18, 2021 at 8:32 PM
    #851
    Jacked Burton
    What size/load did you go with?
  12. Jan 18, 2021 at 8:39 PM
    #852
    svendough
    Colorado
    2020 Cement DCSB OR
    265/70/17 SL's.
  13. Jan 19, 2021 at 2:14 AM
    #853
    TOML-Moose
    TOML-Moose Well-Known Member
    2021 TRD Off-Road DCLB
    Full discloser, I only made it to page 19 before giving up.
    Will 265/75r16 fit a 21 OR, stock suspension, WITH factory mudflaps?
    Appreciate you all!
  14. Jan 19, 2021 at 5:44 AM
    #854
    ItalynStylion
    Steven
    DFW, Tx.
    Check my pictures on the previous page. That's a 285/75/17 in C load.
    I'm done with trimming and adjustments. Got my new SPC control arms on the truck yesterday. I've been taking my time because I'm waiting for my suspension to get back from Accutune Offroad. Once I get the shocks back I'll get the truck back on the ground.
  15. Jan 19, 2021 at 8:42 AM
    #855
    Prez
    Prez Well-Known Member
    San Clemente, CA
    2018 White TRD OFFROAD 4x4 LB
    This is the exact reason I am not going Falken again. I warrantied my first set because of the vibrations and balancing issues. New set same thing. I ended up ordering my TOYOs last night. 285/75r16. Will post pictures as-well.
    TACO TM and svendough[QUOTED] like this.
  16. Jan 19, 2021 at 8:43 AM
    #856
    Prez
    San Clemente, CA
    You will probably have to take off front mudflaps but thats all.
    TOML-Moose[QUOTED] likes this.
  17. Jan 19, 2021 at 9:22 AM
    #857
    ItalynStylion
    Steven
    DFW, Tx.
    A 31.6" tire that's only 265 wide should have zero issue fitting with stock everything. You shouldn't even be close to rubbing anything at all.
  18. Jan 19, 2021 at 10:23 AM
    #858
    01 dhrracer
    Still Shopping
    On a 2011 TRD Offroad. I have been running 265/75/16 Cooper AT3's on a 16x8 wheel with 0 offset/4.5" back spacing, Bilstein 5100's with stock springs set on third notch. They have settled to be only about an 1.25 -1.5" lift. And yes I do run the mud flaps with no issues.
  19. Jan 19, 2021 at 10:54 AM
    #859
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    The 265/75R16 (and 265/70R17) are the generally accepted largest size that will fit on stock OR and Sports without modification to suspension or anything else. It is extremely common and you should be fine. I don't think you even have to take mudflaps off for that.
  20. Jan 19, 2021 at 12:59 PM
    #860
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    CMC, pinch weld flattened, flare plastic trimmed, and fender liner heated and reshaped last weekend.
    Got my 285/75r17's mounted today. Nothing too fancy, but I think they fill up the wheel wells pretty good.
