New Toyo Open Country A/T III tire
Discussion in 'Wheels & Tires' started by Drifter001, Feb 29, 2020.
  1. Apr 27, 2021 at 7:30 AM
    #1101
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Be interested to know as well. I have a camper about the same weight and still debating whether to go with SL or jump up to LT or not. Wish they had a D tire or something in between, that might be a bit of a middle ground.
    dirtnsmores likes this.
  2. Apr 27, 2021 at 11:17 AM
    #1102
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Thank you for your question PM coming your way.
  3. Apr 27, 2021 at 11:33 AM
    #1103
    jstj0sh
    jstj0sh Member
    Magnolia, TX
    2018 MGM Tacoma TRD OR 4x4
    @Discount Tire If y'all could shoot me some info too that would be appreciated!
  4. Apr 27, 2021 at 12:15 PM
    #1104
    hanahou7
    hanahou7 Well-Known Member
    2012 Tacoma DCLB 4x4
    Bilstein 5100s OME 885 2" AAL
    @Discount Tire I spoke to one of the associate's at my local America's Tire and they said running/ towing in SL would be fine as long as you max out the PSI on the rear when towing...he said if you leave it at 32psi then it'll compress too much and appear flat due to the weaker side walls...while it's doable, he said he would recommend a C load or E load for longevity/ sidewall strength if towing large packages
    SoCali_Guy likes this.
  5. Apr 28, 2021 at 1:27 PM
    #1105
    Discount Tire
    Arizona, USA
    Thank you for your inquiry - PM on the way.
    Yes, very much so, I apologize we had not addressed your question. The Standard load tire is what came on it from the factory and the tires are rated to hold the maximum safe towing and bed capacity of the truck. However to piggyback on what the store said, if it is a consistent thing where you are having heavy trailers or loading the bed of the truck up, than there would be some benefits to having a heavier tire construction.
    We hare happy to assist further, pm on the way.
    hanahou7[QUOTED] likes this.
  6. Apr 29, 2021 at 3:21 PM
    #1106
    Discount Tire
    Arizona, USA
    PM coming your way (apologies, i did not catch your post the first time around)
  7. Apr 29, 2021 at 11:20 PM
    #1107
    MAYNIAC
    MAYNIAC Well-Known Member
    Bay Area
    2018 TRD Sport DCLB
    @Discount Tire I’m interested as well if you can send over some info. Thanks!
    jstj0sh[QUOTED] likes this.
  8. May 1, 2021 at 1:55 PM
    #1108
    Discount Tire
    Arizona, USA
    Absolutely, PM on the way
  9. May 2, 2021 at 8:48 AM
    #1109
    FortuneFavorstheBruin
    FortuneFavorstheBruin Well-Known Member
    Zack
    Austin, Texas
    2018 Tacoma Off-Road
    @Discount Tire can i plz get in on the discount code? I'd pull the trigger on these for my daily if you all could be so kind :anonymous:
  10. May 3, 2021 at 7:54 AM
    #1110
    Discount Tire
    Arizona, USA
    Unfortunately we do not have Discount codes, rather than marking up our tires and then offering troublesome discount codes we try and put our best price available to everyone on our webpage. Although even still sometimes our competitors will have a lower price this is where our Low price guarantee comes from.
    The Flash sale that was running has unfortunately ended however we would love to earn your business. PM on the way
  11. May 7, 2021 at 8:42 AM
    #1111
    SoCali_Guy
    SoCali_Guy Well-Known Member
    California
    TRD OFF ROAD
    My personal experience w these tires.. go w E Rated.. they ride like a dream.. keep the PSI down to 33.. & rotate religiously.. you won’t regret
  12. May 8, 2021 at 2:59 PM
    #1112
    ibensted
    ibensted Active Member
    Ian
    North Vancouver
    2018 TRD Pro
    Black wrap roof
    Just picked up my 265/75r16 at3’s 116t (p rated).
    Initial impression is that they look great but feel a little rougher.
    Canadian Caber and TheSquid like this.
  13. May 9, 2021 at 6:49 AM
    #1113
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    I haven't done the Alpine Loop, so I can't speak to it, but for the other trails, SL tire is totally fine for use. Airing down to the low-mid 20s will greatly reduce the chance of tire punctures, but don't air down so much (say below 20 psi) that you run the risk of a pinch flat.
  14. May 9, 2021 at 7:01 AM
    #1114
    pinem56
    NE
    2018 TRDOR DCSB AT
    I have noticed that at the same psi, the toyos do feel stiffer than the stock GYs. Online calculator does say to run these at 28 psi vs 30 psi for stock tires to achieve the same load rating. Not sure if that means anything. I have been running them about 2 psi lower than stock GYs, to get the same approx. feel. The sidewalls do pooch a bit more than the stock tires though, but I suppose that stands to be expected with the higher sidewall profile.
  15. May 11, 2021 at 5:04 AM
    #1115
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    I am having a set of these installed this week. Which side is the "wrong side out"??
    keith88lx and onesixonetwo like this.
  16. May 11, 2021 at 9:38 AM
    #1116
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    The DOT side has a more aggressive looking sidewall. It will be easy to tell the difference when you look at them.
  17. May 11, 2021 at 11:25 AM
    #1117
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    Yeah when you look at the tires the dot side is more aggressive. There are side siphons and the letters are more prominent
  18. May 11, 2021 at 12:14 PM
    #1118
    deusxanime
    MN
    It's different depending if you have the SL or LT tires though too, isn't it?
  19. May 12, 2021 at 9:18 AM
    #1119
    not0ny
    yeah i think the lt tires look the same on both sides? if it has a white wall on lt thats the main difference the color
  20. May 20, 2021 at 6:12 PM
    #1120
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    Do you have a side shot ? Interested to see how a 3”/2” lift looks w/ the LT 265/75/16’s. Truck looks amazing.
    GladiatorNOT likes this.
