New Toyo Open Country A/T III tire
Discussion in 'Wheels & Tires' started by Drifter001, Feb 29, 2020.
  1. Jun 28, 2021 at 8:16 AM
    #1221
    EDDIESDASHYT
    EDDIESDASHYT Well-Known Member
    Eddie
    21 TACOMA TRD OFFROAD
    MESO CHROME DELETE (BLACK) EVERYTHING!, 21 TRD PRO 16" WHEELS, TOYO OPEN COUNTRY A/T 3 265/75/R16! MESO RED START STOP BUTTON (BIG LETTERING)
  2. Jun 28, 2021 at 9:15 AM
    #1222
    bliso249
    bliso249 Member
    Ben
    Pittsburgh, PA
    2020 MGM TRD OR DCSB
    I’m going to get these just not sure on SL or E. It is my daily driver and on road 98% of the time, however I think the E load look better and I am occasionally off-road. I was wondering what the mpg drop is going from 265/70/16 stock OR tires to 265/75/16 E rated Open Country ATIII (or SL for comparison). Any input is appreciated!
    Travelinman301 and deusxanime like this.
  3. Jun 28, 2021 at 3:41 PM
    #1223
    v8rboi
    v8rboi Well-Known Member
    Raymond
    Southern California
    2019 Tacoma TRD Sport 4x4
  4. Jun 28, 2021 at 3:51 PM
    #1224
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    The heavier the tire the more your fuel mileage suffers. That's why I went with the stock sized AT 3's in XL as they were the same weight as the highway treads they replaced. My fuel mileage is about the same.
    bliso249[QUOTED] likes this.
  5. Jun 29, 2021 at 7:23 AM
    #1225
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    We would be happy to help, PM on the way.
    02tacotoy likes this.
  6. Jun 29, 2021 at 7:28 AM
    #1226
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Has anyone had experience with these in wet, icy & snowy conditions? I'm debating about going with either these AT3's in E loads or wildpeaks in SL.
  7. Jun 29, 2021 at 11:25 AM
    #1227
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    NICE!!! had my appointment scheduled at 10:30am today at Discount Tire to get the Toyo's installed, they called me this morning and said "your tires are not here yet, we will call you when they get here" i ask if they knew what time cause i adjusted my schedule today at work to go to the appointment and he said "whenever FedEx truck come they should be on it" well i have wasted my entire day so far .. no phone call, no tires and it's now 2:25pm
    LESSON LEARNED ... if they want to schedule appointment for install tell them you will wait till they have the tires on hand and then schedule a appointment. Pretty aggravating to adjust my work schedule and everything and this happens.
    deusxanime likes this.
  8. Jun 29, 2021 at 11:28 AM
    #1228
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    There is no pleasure without pain...
    Sorry man, that sucks.
    OhioTaco68[QUOTED] likes this.
  9. Jun 29, 2021 at 11:34 AM
    #1229
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    I tell the wife that all the time
    OhioTaco68 likes this.
  10. Jun 29, 2021 at 11:35 AM
    #1230
    OhioTaco68
    Central Ohio
    And .... that's when she wacks it with a hammer :annoyed:
    gsubioguy likes this.
  11. Jun 29, 2021 at 11:53 AM
    #1231
    Jfish12
    Jfish12 Well-Known Member
    2017 Black Tacoma TRD Sport RWD
    What PSI does everyone run on their SL 265/75/16?
  12. Jun 29, 2021 at 8:24 PM
    #1232
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    My truck is maybe 300 to 350 lbs over stock weight with armor/me added. At this weight, 32 psi was starting to wear the inside of the tire a bit more than the outside. I ended up settling on 31 psi front and 30 psi rear for pavement. If you run a tire pressure calculator, to get the same load rating as the OEM Goodyears at 30 psi, you should run them at about 27.5 psi. At 27 psi, it looks like the outside was wearing a bit faster than the inside after a road trip to CO and UT, but that was fully weighed down with camping/recovery gear (1000 lbs over stock weight, essentially at the max GVWR).
    On maintained rocky/washboard forest/county roads, running them at 27 psi could be a bit harsh, but I am still running stock TRDOR suspension. 25 psi was better, but then you probably need to air up once you get on pavement to prevent overheating the sidewall at higher speeds. On rock gardens, 20 to 22 psi was the highest I would recommend going. Given the flexible sidewall of the SL, I wouldn't go much below 20 psi on rocks.
    I can say that the SL held up well to rocks in CO (San Isabel NF and San Juan Mountains) and UT (Monticello BLM). The sidewalls definitely got scuffed, but no cuts of any sort to report. No problems with traction on rocks (wet or dry) or in sand to speak of, with the exception of one ledge I had to kick in the diff lock to get up, and then it was easy peasy.
  13. Jun 30, 2021 at 9:52 AM
    #1233
    LC7
    Far Nor Cal
    Do a chalk test to determine your psi for uniform tread wear. Do it again if you change the weight. Everyone's is different based on their weight.
  14. Jun 30, 2021 at 9:57 AM
    #1234
    OhioTaco68
    Central Ohio
    Great advice !
  15. Jun 30, 2021 at 12:48 PM
    #1235
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    Discount tire direct discount on my 265/65/17s to throw on my new gloss grey TRD rims. I have a set of these tires on my tow rig and love them. The 110 off was very much appreciated!!!
  16. Jun 30, 2021 at 1:30 PM
    #1236
    Raijin822
    Canada
    2021 TRD OR
    Are these E or SL? Also are these made in Japan or USA? Curious if the sidewall difference between where it was manufactured is still a issue.
  17. Jun 30, 2021 at 2:23 PM
    #1237
    Cheap Taco
    They are the SL, I have the E range on my tow vehicle.
    I will check the manufacturer location 9n the paper work when I get out of work
  18. Jun 30, 2021 at 5:23 PM
    #1238
    manwithtools
    manwithtools Well-Known Member
    Dan
    So Cal - San Diego
    2021 Cement Gray Off Road
    Fox 2.5's Deaver Stage 2. 5.29's, 285/70/R17 Front E-Locker
    Don't you also have Discount Tire stores, we have one local to me in Poway, CA? Btw, I'm about to buy a set of 285/75 - 17's of this tire from them I hope. Any discount available here?
  19. Jul 1, 2021 at 5:24 AM
    #1239
    OhioTaco68
    Central Ohio
    @Discount Tire
    Still don't have my tires, i ordered online June 24th and had appointment for Tuesday the 29th to get them put on .. they called Tuesday saying "your tires have not showed up yet" i called yesterday and still no tires.
    I messed up, when i bought them on the 24th they had a online special 10% off purchase of 4 tires ... if i would of ordered the 25th i would of got 10% off + a $60.00 prepaid Mastercard
    I think since my tires are late they should give me the $60 Mastercard, after all i took a half day off work Tuesday because my appointment was scheduled to get my tires put on that morning. i know that won't happen but hopefully i get my tires soon.
  20. Jul 1, 2021 at 5:34 AM
    #1240
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Welp....my 9 month old BFG KO2'S just shit the bed after failing me horribly on the trail (3 out of the 4 of them mind you).....After 16 years of being a BFG KO2 fan.....never again. I just purchased 4 new 285/70R17's from Discount Tire and can't wait till they come in.
