New Toyo Open Country A/T III tire
Discussion in 'Wheels & Tires' started by Drifter001, Feb 29, 2020.
  1. Feb 24, 2024 at 2:00 PM
    #1841
    kaptainsims
    kaptainsims Well-Known Member
    Sims
    2021 Tacoma TRD Offroad Double Cab 6 speed
    None yet
    What size are you thinking?
  2. Feb 24, 2024 at 2:09 PM
    #1842
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I really did like the size of the stocks, I’m pretty sure I got a bad tire. It’s just sometimes hard getting a bad tire proven and swapped out, and I was tired of spending time at the tire shop. It was easier to force new tires by changing sizes than doing single tire swaps. Anyways, the reason I stayed away from larger was for acceleration, but thankfully I don’t feel like I lost any anyways. I think the initial gain felt good when I downsized because I was coming from 12lb heavier LTs. The larger SLs are only like 1 lb heavier and they’re actually narrower than the stocks so I think it all worked out well to be null as far as acceleration/mpg hit goes.
    Polythemus[QUOTED] likes this.
  3. Feb 24, 2024 at 2:23 PM
    #1843
    Polythemus
    Polythemus Well-Known Member
    B.C. Canada
    2023 MGM Tacoma Trail Edition
    Toyo Open Country 265 75 r16 tires FN Countersteer Type X, 16x8, 0 offset Front clip PPF, ceramic coated.
    That's good to know. your new tires look awesome on your truck, fills out the wheelwell a bit better.
    My concern was also loss of acceleration with the 265 75s, but an additional 1lb is negligible. Ill be going with those tires next time.
    BLtheP[QUOTED] likes this.
  4. Feb 24, 2024 at 2:53 PM
    #1844
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Yes, same here. Very easily been up to 140KM/h+ briefly, , on a quite section of highway. Over 2 years later and I'm still happy with them. Mine are 265 70 R17. You could easily go one tire size up next time. IMO.
    bctaco21 and Polythemus[QUOTED] like this.
  5. Feb 24, 2024 at 3:45 PM
    #1845
    Polythemus
    B.C. Canada
    Ive got the 1 inch lift in front 1/2 inch in rear as a buffer, came with trail edition, so no reason not to, now that I know acceleration wont be affected too much. Stock goodyears were also slightly taller than the toyos of same size, which was a little unexpected.
  6. Feb 24, 2024 at 5:19 PM
    #1846
    BLtheP
    Plano, TX
    Yeah, my stock size were Japan as well. Looks like ATIIIs coming from Serbia is a newer thing. Interestingly enough, my 5 were made through various times of 2023. One of them was as early as the 25th week and all the others were in the 40s weeks.
  7. Feb 24, 2024 at 5:20 PM
    #1847
    BLtheP
    Plano, TX
    That is interesting because I thought the 70s were pretty tall looking. They measured out to provide the same speedo calibration as stock. They definitely look taller than something like a Michelin, which is probably expected. They were also pretty wide too though which makes them extra beefy looking despite whatever the height is.
  8. Feb 24, 2024 at 6:19 PM
    #1848
    Polythemus
    B.C. Canada
    I compared the unmounted goodyears to the toyos, and I realize now that this is unsprung. I'm guessing when tires are mounted and on they vehicle, they appear a bit shorter? probably really close to stock size. I just made a mistake. Toyos are certainly wider in 70 size, wider tread and more square corners. love the looks.
    BLtheP likes this.
  9. Feb 26, 2024 at 10:23 AM
    #1849
    Polythemus
    B.C. Canada
    The guy at the tire shop tells me that tires can age and have an expiry date? He warned me not to keep tires around for years and re- mount them or sell them after they get too old. I guess that makes sense. rubber can dry out over time.
    MGMDesertTaco likes this.
  10. Feb 26, 2024 at 10:33 AM
    #1850
    MGMDesertTaco
    Yes, rubber dries out and cracks over time. Your climate can expedite wear too. Here in AZ tires seem to wear faster, because the pavement is so hot in the summer.
  11. Feb 26, 2024 at 10:38 AM
    #1851
    scocar
    scocar Patron of the Farts
    He advised you to sell them if they get too old? With full disclosure to the buyer I assume?
  12. Feb 26, 2024 at 10:50 AM
    #1852
    Polythemus
    B.C. Canada
    he advised not to sell them if too old. I just sold my stock goodyears to a friend this weekend anyway, off of my 2023 taco.
    scocar likes this.
  13. Feb 26, 2024 at 2:14 PM
    #1853
    MGMDesertTaco
    Most tire shops won't install tires older than say 5 years anyway.
  14. Feb 27, 2024 at 2:19 PM
    #1854
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I think I was running them at around 32psi. I had them mounted to 16' FJ wheels and have a 2.5' lift. :)
  15. Feb 27, 2024 at 5:06 PM
    #1855
    barch88
    barch88 Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    Loving these - they've been treating me good for last 1k miles, deep snow, mud, etc. People complain about noise but honestly nah.
    Roody, Polythemus and MGMDesertTaco like this.
  16. Mar 5, 2024 at 11:58 PM
    #1856
    DRob
    DRob Well-Known Member
    David
    Nor Cal
    2017 DCLB OR4X4 SW
    Fox w/DSC, Camburg UCA, SCS GEN5 17x8.5 -12,
    285-75-17 All mounted up with the new wheels. Buttery smooth ride
  17. Mar 6, 2024 at 3:38 AM
    #1857
    barch88
    Michigan, USA
    What size lift? Looks good!
    Roody likes this.
  18. Mar 6, 2024 at 9:31 AM
    #1858
    DRob
    David
    Nor Cal
    2017 DCLB OR4X4 SW
    Thank you. Sitting about 3” front and 1.8” rear.
    barch88[QUOTED] likes this.
  19. Mar 6, 2024 at 9:34 AM
    #1859
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    This should not be news to anyone
  20. Mar 6, 2024 at 10:17 AM
    #1860
    barch88
    Michigan, USA
    Looks awesome. I just have 31’s (265/70). Went with a 2” front / 1.5” rear but gonna do 1” rear instead.
