new toyota remote - need programming info
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowyer2002, Oct 6, 2014.
  1. Oct 6, 2014 at 10:56 AM
    bowyer2002
    bowyer2002 [OP] always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    I bought a toyota remote for my Tacoma and have tried 2-3 different programming instructions found on the internet.
    AANNDDD None worked. :confused:
    Can someone please point me in the right direction?!
    Thanks!
  2. Oct 6, 2014 at 10:59 AM
    Sandyman
    Sandyman Well-Known Member
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
    Let's see.
    turn to on position with key,
    with both hands out the window, key in the secret squirrell code in the radio with your left pinky toe....
    No wait that's Audi!
  3. Oct 6, 2014 at 3:42 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    1) Getting a Replacement Remote
    Look on ebay or google, make sure the remote has the following FCC-ID: bab237131-056
    2) Installing the remote (credit to iPal)
    1 open door, take key out...
    2 insert and remove key from ignition 2 times
    3 close and open driver's door 2 times
    4 insert and remove key from ignition
    5 close and open driver's door 2 times
    6 insert key into ignition
    7 close door
    8 turn ignition from 'lock' to 'on' and back to 'lock'
    if you do step #8
    *1 time it's for add mode
    *2 times for rewrite mode
    *3 times for confirmation mode
    *4 times for prohibition mode
    9 remove key
    10 then door lock will cycle 'lock' and 'unlock' a number of times
    corresponding to your key cycles in step #8
    11 press lock and unlock button together for 1 ~ 1.5 sec then release
    12 then within 3 sec press lock button for 1 sec then release
    13 if you did correctly door lock will cycle once...
    if wrong, twice... then do it over...
    That worked on my 2004
  4. Oct 6, 2014 at 5:16 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    I used this one, worked perfectly
    http://www.programyourremote.com/classified/2004-toyota-tacoma-listing-6522.aspx#.VDMwuRauSe0
  5. Oct 7, 2014 at 6:57 AM
    bowyer2002
    NE Missouri
    Thanks!
    Ill give that a try at lunch!
