New transmission TSB software fixed shifting issues!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rob4092xx, Jul 21, 2018.
  1. Sep 13, 2018 at 10:46 AM
    #61
    trdtacomahi
    trdtacomahi 2018 trd off road 4x4
    Hawaii
    Currently being upgraded One @ a time
    Tsb tsb tsb getting me all woried
    Im about to get my self a 2018 trd off road 4x4
    Should i wait or theyved already fixed this issue
  2. Oct 9, 2018 at 6:26 AM
    #62
    Antleraddict87
    Antleraddict87 New Member
    Nick Johnson
    2016 Tacoma TRD OFF ROAD
    LEVELING KIT, 285/70/17 TOYO AT2
    I didn’t buy my truck from this specific dealership it’s a 2016 with 40k miles will it cost me to get them to do the TSB update?
  3. Oct 9, 2018 at 7:56 AM
    #63
    pmortiz01
    pmortiz01 Active Member
    Michael
    2016 Toyota Tacoma Limited
    I have a 2016 taco limited. Wondering if I should just buy a shift sense pro seeing that the TSB ends up reverting to shit for a lot of people. Been reading up on the TSB for about a month now and I see a lot from both sides in the forums.
    indowaver likes this.
  4. Oct 9, 2018 at 7:59 AM
    #64
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Nothing. It's covered until 80k miles or 96 months.
  5. Oct 26, 2018 at 8:35 AM
    #65
    Sauzacoma
    Sauzacoma IG: @Stancaban
    Southern California
    2017 TRD Off-Road (DCLB)
    You took TSB-0062-18 in or was it a different one to get it flashed?
  6. Nov 12, 2018 at 8:49 PM
    #66
    wfo4ever
    wfo4ever Active Member
    2018 Tacoma TRD Sport 4x4
    How are you supposed to check the transmission fluid level? I have a 2018 TRD Sport with A/T.
  7. Nov 12, 2018 at 9:00 PM
    #67
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
  8. Dec 1, 2018 at 1:02 PM
    #68
    Yoda910
    Yoda910 Active Member
    2018 SR5
    None
    Took mine in for 10k service and they said my tranny needs flashes. 2018 sr5 it hunts gears really bad especially at lower highway speeds such as 55mph and down shifts into 1st hard sometimes when I'm in the city. Hope it works!!
  9. Dec 1, 2018 at 1:19 PM
    #69
    MrBrooks
    Midwest
    That should take care of the gear hunting. It helped on mine quite a bit. Cruise control even works properly now I noticed on my last trip after having the flash done. The 1st gear clunk is a separate issue tho. There's a thread about it & has been a problem on earlier gens also
    https://www.tacomaworld.com/threads/any-fix-for-the-‘cold-clunk’.580099/
  10. Dec 2, 2018 at 9:45 PM
    #70
    Bluepearlconcepts
    Bluepearlconcepts New Member
    2018 Toyota Tacoma
    My 2018 Tacoma automatic transmission experienced low RPM shifting and was searching for gears constantly. I brought it to the dealer in June and the master mechanic said it was shifting normal. Mine was assembled in March 2018. Brought it back in at 4,000 miles and had them check the tranny again. This time the performed the software upgrade per TSB and finally it is shifting much better. This is how it should have been shifting when I bought the truck.
  11. Dec 8, 2018 at 8:57 PM
    #71
    Blue Pro
    Blue Pro New Member
    Joseph
    2019 Tacoma Offroad
    Stock
    I just got my 2019 Off-road. My first Tacoma and after 100 miles and 4 days it was started shifting funny and trans fluid was seeping. The dealer topped off the trans fluid to see if it would leak again but so far none they can see. The truck is on lift waiting for to another foreman to figure out the issue. Check engine light is also lit.
  12. Dec 10, 2018 at 3:56 PM
    #72
    mrsr71
    mrsr71 Active Member
    Dan
    In the Country
    2018 TRD Off Road Access Cab 4X4
    Took my '18 TRD Off Road to the dealer today. They did the TSB (attached) and it's WAY better :)
  13. Jan 5, 2019 at 6:39 PM
    #73
    Gothy666
    Gothy666 Well-Known Member
    2019 TRD Off-Road
    Does the TSB apply to 2019s?
  14. Jan 5, 2019 at 6:47 PM
    #74
    Lt. Dangle
    Ohio
    Probably came with it. I have the 062 tsb, but they all have the same ecu calibration numbers so they all are the same.
    I'm 99% certain the 19's are born with it already.
  15. Jan 5, 2019 at 6:57 PM
    #75
    MrBrooks
    Midwest
    I would assume the 19's already programmed with the latest. TSB has been out since July I think
    I had my 18 flashed awhile ago & drives a lot better & much better mpg's. Got 24 mpg today 20%city/80%hwy. Pretty happy considering my heavier wheels & tires
  16. Jan 5, 2019 at 7:06 PM
    #76
    Gothy666
    2019 TRD Off-Road
    Thanks!
    Lt. Dangle[QUOTED] likes this.
  17. Jan 5, 2019 at 7:57 PM
    #77
    Lt. Dangle
    Ohio
    If you check the tsb thread, the official tsbs are on the first couple of pages and it states what it applies to and what calibration code the 19's have. The tsb updates to what the 19 should have...
  18. Jan 30, 2019 at 7:23 PM
    #78
    Srcapo
    Srcapo Member
    Tacoma TRD offroad XP
    I have a 2019 and it shifts too early and weird not smooth i wonder if they have an update i mean i just have 2500 miles tho
  19. Feb 13, 2019 at 6:54 AM
    #79
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    The update seemed like it helped right after it was done, but a few months later it feels like shit again. Below 40 it’s fine, but as soon as it drops into 6 it doesn’t want to let go. When I’m going up a slight grade it bucks a lot until it finally downshifts.
    Dealer is ready to open a case with cooperate because they have nothing else to offer as a fix other than driving in ECT.
  20. Feb 13, 2019 at 8:04 AM
    #80
    Gothy666
    2019 TRD Off-Road
    What year do you have?
