New transmission TSB software fixed shifting issues!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rob4092xx, Jul 21, 2018.
  1. Feb 13, 2019 at 8:57 AM
    #81
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    17’
  2. Feb 13, 2019 at 10:21 AM
    #82
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    S mode would help.
    Disconnecting the battery would help.
    Disconnecting the battery and driving it hard for awhile would help.
    Anything that keeps you from using the AI learning of the transmission fixes the issue.
    The problem isn't that the tsb didn't take or work, the issue is the learned behavior of the transmission and it's programming.
  3. Feb 13, 2019 at 11:01 AM
    #83
    Sinister184
    Those may help, but they’re all things that people shouldn’t have to do for the truck to operate properly.
    Travis804 and zonks12 like this.
  4. Feb 13, 2019 at 11:07 AM
    #84
    trayscool
    trayscool Well-Known Member
    Travis
    Long Beach
    2018 TRD OR
    Thanks for posting. Im printing this out and taking to the dealer tomorrow along with my other issues
  5. Feb 13, 2019 at 11:19 AM
    #85
    Lt. Dangle
    Ohio
    Ok.
    StayinStock and MoDuMan like this.
  6. Feb 13, 2019 at 11:53 AM
    #86
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    What exactly is the TSB? couldn’t get the pdf to load. Is it just reflashing it back to start the learning over? I haven’t noticed it being too bad with my new 19, but if it helps I’d like to get it done.
  7. Feb 16, 2019 at 6:28 AM
    #87
    MoDuMan
    MoDuMan Member
    Tacoma Limited 2017
    Bed camper shell
    My transmission clunks when it is down shifting between 20 and 15 mph. They flashed the system at my 15k and 20k mile check. It worked for a few days and then back to the same. They keep denying anything is wrong. I am about to write to the factory before my warranty is up. My Taco is a 2017 Limited.
    watersoilair and Tig3r_Bit like this.
  8. Feb 16, 2019 at 9:31 AM
    #88
    MoDuMan
    MoDuMan Member
    Tacoma Limited 2017
    Bed camper shell
    My 2017 began acting up after 12,000 miles
  9. Feb 19, 2019 at 9:05 AM
    #89
    Wengel21
    Wengel21 Well-Known Member
    Ben
    SoCal
    2017 DC LB TRD OR
    Mine does the same, it's like a hard down shift
  10. Feb 21, 2019 at 11:52 AM
    #90
    oldbarn70
    oldbarn70 Member
    Sandwich, NH
    2018 Tacoma XC SR5 MGM 4x4
    My '18 Tacoma has been constantly searching for gears since new. Two months ago I got the TSB....still shifts like crap. And for the first time, I took it on the highway to Boston...MPG was 17.0, and constantly shifting up down up down, etc. Sometimes I just get so mad I stomp the pedal to the floor to make it downshift and move. I love the truck otherwise, but I can't take it anymore. I've had all kinds of trucks, none of them including previous Toyotas have had this problem. I think it is because the new 3.5 is a low torque/high HP motor at high RPM, and with the tranny always trying to upshift for a low rpm, it just does not work. My 2nd Gen 4.0L/auto shifted flawlessly.
    Tig3r_Bit likes this.
  11. Feb 21, 2019 at 12:51 PM
    #91
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Before you give up try driving it in s5 all the time. It won't shift as much because you are locking out 6th gear.
  12. Feb 21, 2019 at 12:53 PM
    #92
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Imo, if you like how it drives now, I wouldn't change anything. But that's me.
  13. Feb 22, 2019 at 4:47 AM
    #93
    MoDuMan
    MoDuMan Member
    Tacoma Limited 2017
    Bed camper shell
    My truck took about 5,000 miles before the engine loosened up and allowed the MPG to go up. Now I am peaking at 22.5.
    bulalo likes this.
  14. Feb 22, 2019 at 5:53 AM
    #94
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    OVTUNE!!!
    wahoobie likes this.
  15. Feb 22, 2019 at 5:54 AM
    #95
    Tig3r_Bit
    2018 TRD OR 4x4
    Best thing to do is trade it for a Tundra or for another Truck.
  16. Feb 25, 2019 at 5:04 AM
    #96
    MoDuMan
    MoDuMan Member
    Tacoma Limited 2017
    Bed camper shell
    Took the Taco out for a 100 mile trip and noticed that it does not matter if the engine is cold or not, the clunking is not affected by temperature.
  17. Mar 5, 2019 at 8:30 AM
    #97
    waytolatetothegame
    waytolatetothegame Well-Known Member
    James
    2016 Inferno Tacoma TRD OR
    I have a 2016 and was about to take it in for my 40K. I brought up the TSB because I'm having all the issues people are describing. They told me it's not covered because I'm over 36k. I promptly showed them the TSB printout I had in hand that states "96 months or 80K." They still won't honor it. I'm not sure what to do now. Might go to a different dealer and see if they will honor it.
  18. Mar 5, 2019 at 10:05 AM
    #98
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    I had this same TSB done to mine at the first 5000 mile tire rotation...it made a world of difference.
  19. Mar 5, 2019 at 10:11 AM
    #99
    Travelinman301
    Florida
    It's TSB 0058-18 for automatic transmissions. It changes the shift points in the tranny to higher RPM's and generally makes the truck a lot more pleasurable to drive. I don't find it "hunting" for down or upshifts anymore. Don't know if it's for the 19 so have your service writer check with the tech.
  20. Mar 6, 2019 at 7:17 PM
    #100
    Tig3r_Bit
    2018 TRD OR 4x4
    Sad. I'm still searching for a dealership to update my truck. Been to 3. Fail.
