New TRD PRO lift kit option?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aliosha323, Feb 5, 2020.
  1. Feb 7, 2020 at 8:13 PM
    #81
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    What makes it’s shit? Have you tried it or known anyone that has tried it or run this kit?
  2. Feb 7, 2020 at 8:17 PM
    #82
    TacoBuffet
    AL
    So let me ask you a question is a coil-over a spacer lift?
  3. Feb 7, 2020 at 8:27 PM
    #83
    vsyntax
    vsyntax Well-Known Member
    WNC
    2018 Tacoma TRD PRO
    Interested in this kit.. do these guys post on TW?
  4. Feb 7, 2020 at 8:28 PM
    #84
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Get a pair of .50 inch spacers for the front, good for 1" front lift. that will cost you about 50 bucks if you install yourself. Add an alignment for about 100 bucks. Just my thoughts, if you were asking.
    TheAredub and Big tall dave like this.
  5. Feb 7, 2020 at 8:29 PM
    #85
    BadKitty
    BadKitty Well-Known Member
    Indianapolis
    2017 Black Tacoma TRD-offRoad 6spd
    TRD Intake, TRD exhaust
    are sandals shoes?
    do you have to taste a turd to know it tastes like shit?
  6. Feb 7, 2020 at 8:47 PM
    #86
    TacoBuffet
    AL
    You are completely right! Do the same thing in lifting the truck but wrong in how they fail. A spacer on the strut pushes it down and now the control arm is no longer the stopping point. In return the strut can’t handle the load of the downward motion of the vehicle so the failure is the strut the weak link. The preload collar on Westcott Designs does not change the bottom out point of the control arm or the TRD PRO Fox strut from its factory design so it’s not possible to fail like a spacer lift. I have one of these kits and it was designed to accommodate a larger tire and keep as close to factory ride as possible, Also not damage any factory parts or break the bank when wanting to lift it and keep the factory suspension after spending $50k for a truck.
    e46_ema and CaptainBart45 like this.
  7. Feb 7, 2020 at 8:48 PM
    #87
    BadKitty
    Indianapolis
    At the price point the TRD-PRO's fall in (~$2800), its full pants-on-head retarded in the same way putting block spacers on a KING suspension would be. It makes literally no sense at all why anyone is arguing for this to be a good thing let alone even necessary.
    If you bought a TRD-PRO and want to modify your truck to fit 33"+ tires, you simply need to sell your massively expensive progressive-rate, position sensitive OEM shocks, and buy Kings or something to that effect. The TRD-PRO suspension simply was not engineered for Changes to the disposition of the shock body. There is an objective undeniable reality that at or near 2" of lift, you begin to max out the OEM alignment cams and shortly there after the Upper control arms. All it takes is a simple print-out of your alignment specs, or a quick look at your lower control arms to see reality for what it is.
  8. Feb 7, 2020 at 8:51 PM
    #88
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    You all making us work.
    Stahp!!!
    Thomasf94, TacoBuffet and tcBob like this.
  9. Feb 7, 2020 at 8:54 PM
    #89
    TacoBuffet
    AL
    Point has been made here! You are someone that is bored and does not have a clue. You just run your mouth with no proof or anything to back it. Moving on.
  10. Feb 7, 2020 at 9:16 PM
    #90
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    How do you think LC's, 4runners, Jeeps, superduties and any other coil suspensions achieve lift? You don't need a shock to lift a vehicle but you do need a coil or spring.
    Stop being so dramatic
    Been a LONG time since I added someone to my ignore list.
  11. Feb 7, 2020 at 10:14 PM
    #91
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    bruv and BeefyTacoSupreme like this.
  12. Feb 8, 2020 at 3:38 AM
    #92
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    He's a troll that does this in other threads. Pretty much ruins any reasonable discussions.
    ramrod84, vsyntax, 5nahalf and 2 others like this.
  13. Feb 10, 2020 at 12:48 PM
    #93
    BeefyTacoSupreme
    BeefyTacoSupreme Well-Known Member
    Brady
    Denver, CO
    2019 Tacoma TRD Pro - Super White
    Stock TRD PRO
    I'd say worse; at least the 427AP offers the AAL in the rear, opposed to rear blocks.
  14. Feb 10, 2020 at 1:18 PM
    #94
    Rising Eagle
    Rising Eagle Well-Known Member
    Berkshires MA
    2020 DCSB OR
    Yup! But someone out there in TW land will buy it.
  15. Oct 6, 2020 at 7:11 PM
    #95
    Plugz
    Plugz Well-Known Member
    James
    Colorado
    2021 Tacoma TRD Pro in Lunar Rock
    Grille lights, cast aluminum running boards, bed mat, window deflectors, tailgate insert
    I'm strongly considering doing this to my truck. My main thoughts are that there are other things I want to do that I know will serve me better right now (bed rack and roof top tent) but would like to get some beefier tires without having to spend a few thousand on a proper lift for at least a little while. Would you recommend going this route for a temporary lift?
    TacoBuffet[QUOTED] likes this.
  16. Oct 6, 2020 at 7:12 PM
    #96
    TacoBuffet
    AL
    100%, Jeff's kit is solid and will let you throw on 285s no issues.
    Thomasf94 likes this.
  17. Oct 6, 2020 at 7:14 PM
    #97
    Plugz
    James
    Colorado
    What sort of price do you think I should be looking for just the installation?
  18. Oct 6, 2020 at 7:16 PM
    #98
    TacoBuffet
    AL
    Could do yourself pretty easy, but maybe 2 hours max, so $180-200, and then whatever alignment costs.
  19. Oct 6, 2020 at 7:18 PM
    #99
    Plugz
    James
    Colorado
    I was quoted 4 hours at a pretty reputable shop out here.. which would be like $500 for install alone. Im gonna call around and see what I can find. Thanks man!
  20. Oct 6, 2020 at 7:20 PM
    #100
    TacoBuffet
    AL
    I knocked out my few lifts on my 11, 15 and 19 in the driveway which included UCAs and rear leafs and that took about 6-8 hrs, any reputable shop should be able to get it done in 2-3 hours, but as you know most will try to pad the hours, no prob!
