New TRD Pro tire damage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Funyun, Jun 18, 2020.
  1. Jun 18, 2020 at 5:02 AM
    Funyun
    Funyun [OP] New Member
    I just picked up a '20 TRD Pro last week and after only 100 miles noticed some significant tire damage that I thought may be from rubbing something. I took it into the dealer and they said nothing was wrong and maybe I was turning too aggressively. Judging by where on the tire and the type of damage that didn't seem very plausible and it was maybe done in reverse? I think I found a piece of plastic on the fender liner behind the tire that seemed to be sharp and have a piece chipped off it but I can't see how the tire would of hit there. Has anyone ever had problems like this before on a brand new TRD Pro? The damage is only on the front tires and more so on the driver side pictured.
  2. Jun 18, 2020 at 5:09 AM
    Chris_The_Red
    Chris_The_Red Well-Known Member
    Brooklyn, NY
    2018 Cement Tacoma TRD OR
    I see this as a sign from the Tacoma Gods to get rid of the stock tires and get some bigger tires. All praise the Tacoma Gods!:amen:
  3. Jun 18, 2020 at 5:31 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Have you been off road? That looks like abrasion from being stuck and a tire spins. Plastic probably won't do that. Most likely concrete, rock, etc. I agree that it probably happened in reverse. My detective sense would say that you got stuck, put it in reverse, spun the tires, and snagged something in the hole. I could be completely wrong, but I have seen damage like that before. It happens a lot after it snows and people get stuck.
    You can either deal with it or go to a Goodyear dealer and have them look at it. Goodyear will likely say it is from misuse and offer some goodwill replacement offer. Maybe 50% and you pay install costs.
    RelentlessFab, Bertw192 and Chew like this.
  4. Jun 18, 2020 at 5:37 AM
    Funyun
    It was driven 100% on pavement to and from work for 4 days and then to the store once on the weekend. I must be missing something because it just doesn't make sense. I'd say almost 80% of the miles driven were going to the store that one day and driving it back from the dealer as my commute is extremely short.
  5. Jun 18, 2020 at 5:38 AM
    Grindstone
    Grindstone Requires Adult Supervision
    10k miles on my '20 Pro and I do not have any wear patterns close to that. Last time I've had a tire wear like that it was a wheel bearing giving out on a Chevy. But that was over the course of a few thousand miles.
  6. Jun 18, 2020 at 5:40 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Either your alignment is fucked or something else is.
    Edit: Take it in, tell them you want an alignment because of extreme tire wear and insist it be covered by warranty. Alignment is covered for the first 12k.
    Pro-Taco, Philrab and Shellshock like this.
  7. Jun 18, 2020 at 5:47 AM
    Funyun
    Forgot to mention they said the alignment was fine when I took it in. The passenger side toe in was a hair off I believe he said but besides that nothing else. That's the side that has minimal damage though in comparison to the one pictured.
  8. Jun 18, 2020 at 5:56 AM
    ChuckTownRC51
    ChuckTownRC51 Well-Known Member
    Mark
    2016 TRD Off Road 4x4 Double Cab
    None, yet
    What year was the tire manufactured? It's the last 4 digits of the TIN on the tire. If they threw old tires on there it could be dry rotted. I had dry rotted tires before and they are fragile
  9. Jun 18, 2020 at 6:00 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Maybe bad tires? With no off-roading and given it's brand new, I tend to think something is maybe wrong with the tires.
    I think the tires usually are warrantied individually by the mfg, so you may have to take it up with Goodyear. Ask dealer to document nothing is rubbing, no damage, good alignment, and mileage before you call.
  10. Jun 18, 2020 at 6:11 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Could be old tires on a new truck...that's one reason...date of manufacturing is coded on the side wall...google and decipher it...
    Junkhead and Chew like this.
  11. Jun 18, 2020 at 6:13 AM
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    Maybe, the truck was taken for a demo ride while still at the dealers lot, before you purchased it. You just didn't see the tire damage on delivery.
  12. Jun 18, 2020 at 6:17 AM
    Sungod
    St Augustine
    Any chance you missed it before you bought it?
    I would rotate the tires now just to see if it really is something rubbing on the front, but honestly to do that kind of damage, you would know it. That kind of rub would have made one hell of a racket.
    Chew likes this.
  13. Jun 18, 2020 at 6:25 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Yeah only thing I can think is hard driving on new full tread tires. That said, at least Goodyear should warranty them...the dealer really should help.
  14. Jun 18, 2020 at 6:29 AM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Someone drive up against a low curb?
    OldGregg, BSFord, Ch78 and 4 others like this.
  15. Jun 18, 2020 at 7:32 AM
    rosstermyer
    rosstermyer Member
    goodyear should warranty them. your dealer buys 100s of tires from them as OEM replacements they should be advocating for you here. especially if you bought the vehicle from them. talk to service manager or dealership GM.
    Toyko Joe likes this.
  16. Jun 18, 2020 at 7:35 AM
    texbaz
    "Buffalo Creek" TX
    So, both sides show damage just one side more. I'm tending to think like one forum member already said,its from being in FWD possibly rocky terrain, high torque, or wheels spinning. Someone took it for a joy ride "Hey, look at me i'm in a TRD Pro" how many miles on it when you got it. Go back to the dealership, take a stroll through the lot, look at some of the other TRD OR's or Pro trucks on the lot see if they have similar damage. if they do ?
  17. Jun 18, 2020 at 7:47 AM
    Mace27
    Mace27 Well-Known Member
    18 TRD OR
    Dealer should replace those tires. There is a split in the sidewall at 2 o'clock and it also looks like there is a small amount of cupping on the siping. No way that was done with 100 miles on pavement.
    TXpro4X4 likes this.
  18. Jun 18, 2020 at 8:43 AM
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    Maybe the dealer swapped the tires/wheels off another truck to make sale?
  19. Jun 18, 2020 at 8:59 AM
    markgphoto
    markgphoto Well-Known Member
    Mark
    Middle Tennessee
    2020 Tacoma ArmyGreen TRD Pro
    Those tires look like they have more than 100 miles on them.
  20. Jun 18, 2020 at 9:01 AM
    Sungod
    St Augustine
    I was thinking the same thing and the wheels have a substantial amount of dust. Not exactly what I would expect after only 100 miles.
