New TRD "TVS" S/c For the D-VVTi 1GR-FE at SEMA
Discussion in 'Performance and Tuning' started by BrokenTusk, Nov 2, 2012.
  1. Nov 2, 2012 at 2:13 PM
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  2. Nov 2, 2012 at 2:20 PM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    This a different style for the TRD supercharger or what? lol
  3. Nov 2, 2012 at 3:01 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Next Gen charger for the Dual VVTi
  4. Nov 2, 2012 at 4:17 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Interesting, wonder if there was improvement on this SC from the old one? Other then like a redesign lol il have to read up on this
  5. Nov 2, 2012 at 4:23 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Seeing that the old design is approaching 7 years old. I would hope some material advances, giving slightly better efficiency..
  6. Nov 2, 2012 at 4:27 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    That would be nice for better MPG's, I would be amazed and kinda bummed if toyota gave it more boost to the engine or they will keep it at 6 PSI ish lol
  7. Nov 2, 2012 at 5:05 PM
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    Here's some more info on it:
    "Power comes from the V6 4.0-liter engine that has gained a TRD supercharger with a Twin Vortices System (TVS) and a big air-to-water intercooler. Thanks to these changes, the engine is now 30 percent more powerful and has 25 percent more torque, producing 345 hp (257 kW) at 3,500 rpm and a peak torque of 340 lb-ft (460 Nm) at 3,500 rpm."
    Link:
    http://www.worldcarfans.com/112102649835/toyota-fj-cruiser-concept-by-trd-arriving-at-2012-sema
    kinda wish we could retrofit DVVT-i into our engines and use this SC...that's a big bump in power over our vvt-i 1gr-fe
  8. Nov 2, 2012 at 5:15 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    It won't be cheap but can be done along with a dvvt-i engine. Just a matter of $$$.
  9. Nov 2, 2012 at 5:19 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Damn that's a nice jump from 236 to 345!! got ripped off 41 HP with the old one! haha
    To bad we can't use it -.-
  10. Nov 2, 2012 at 5:22 PM
    Oscarbob
    Bob
    Central New York
    just speculating, what would entail going from vvt-i to dual on our engines?
    Is the block the same? the heads? Obviously new electronics and the intelligence system on exhaust cam...but i feel like you basically have to install new heads...just curious
  11. Nov 2, 2012 at 5:30 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Wouldn't a D-VVTi Engine drop in place of our current one? They should still bolt up to the tranny fine. :notsure:
  12. Nov 3, 2012 at 6:20 PM
    Silver DC
    Silver DC Well-Known Member
    Mark
    Nashville
    07 TRD Prerunner SuperCharged
    Supercharged,TRD CAI, TRD exhaust, DTLT Headers, L.E.D. Taillights, Factory BHLM,Wet Okole Seat Covers,Weather Tech Digi-cut Floorliners
    Will be getting one for the wifey's 4runner. Should be out sometime in the summer:D
  13. Nov 4, 2012 at 8:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Based off the base dyno charts we have, there is an average of 16% drive train loss, with stock drive-train components. So assuming the same loss for the dual VVT vehicles, that BHP number translates into approximately 289 whp, bolt on.
  14. Nov 4, 2012 at 8:08 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Not bad at all
  15. Nov 4, 2012 at 8:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not sure about bolt up differences on components, but being that the heads have rockers instead of just bearing caps with shim buckets, that will create some differences I'd imagine. The block itself should most likely be different internally on the bottom end. Since the crank now only has 5 counterweights compared to I think 9 on the non dual VVT engines. Lucario Runner has those specs.
    Down side is that they increased compression and have less counterweights. Thus makes a less boost happy engine. :(
  16. Nov 5, 2012 at 11:18 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The dvvti should bolt up exactly as the vvti though you would need the electronics with it to run it. The engine is not exactly the same as heads and internal components has slight differences so much better to get a complete dvvti engine rather than making vvti to dvvti though I don't think the amount of money that will be spent in doing so justify the gain.
  17. Nov 5, 2012 at 4:59 PM
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    the new dvvti engine is rated at 270hp so its still only a 70hp gain. its also supposed to unmodifiable unlike the current sc for the vvti motor. this is due to a very small snout pulley and the location of the oil filter make fitting a larger crank pulley very very difficult. the only way it may be possible to get more boost out of it would be to due a snakebite overdrive system.
  18. Nov 19, 2012 at 8:06 PM
    Twistinemup307
    Twistinemup307 Well-Known Member
    Alex
    Wyoming
    2012 DCLB tacoma SC sport
    Its so damn sexy haha
  19. Nov 19, 2012 at 10:38 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    do not forget the low weight engine oil too. Toyota did many things to this engine so for it to be called a 1grfe is a mistake. On the bottom end the cylinders have been hollowed out on the bottom of the piston head to reduce weight. The shape of the piston has also changed. The crankshaft also had some revisions made. The new dual VVT-i have a 5 counter weighted shaft compared to the previous one which had 9. Compression has increased to 10.4:1 from 10.0:1. In essence the bore and stroke have been left unchanged. Interesting enough though is that a pressure sensor for the power steering has been added. The cylinder heads have gone under a big revision as well, but we already knew that. The biggest feature, besides the dual vvt-i. is that a roller rocker arm is used and that the camshaft housing is separate from the rest of the cylinder head.
  20. Nov 19, 2012 at 10:44 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    What do you mean by a 5 versus 9 counter weight? :notsure:
