new truck engine break in?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alan in GA, Jan 3, 2012.
  1. Jan 3, 2012 at 8:46 AM
    Alan in GA
    Alan in GA [OP] Well-Known Member
    Alan
    Powder Springs, Georgia USA
    '12 Tacoma Off Road 4x4
    tool chest, company logo/decals
    OK, a gazillion ideas on this, but to keep it simple, Did you do anything other than 'normal driving' for your NEW Tacoma Truck?
    I drive mine EASY for at least 500 miles to let any 'tight/high' spots wear in instead of 'melt in' [picture a tight spot on a crank or cam lob or bearing journal]. Then I start easing some heavier throttle in lower gears [2nd and 3rd] only for short 3 or 5 second durations, immediately easing off to let any 'tight/hot' spot in wear areas to cool.
    At the 1K mile mark I start driving normal around town but still stay out of Over Drive. I'll get some interstate miles soon but will not be towing my boat, a light aluminum 16'/40 hsp/stick steer rig until a few thousand more miles, and then 65mph max.
    What think? Overkill? I do believe in 'gentle at first 1K miles, then definately some 'increase in throttle' to get some break in wear as I believe one can be 'too easy' on a new engine, too {after 1 or 2K put on it}.
    What's your thinking on engine break in? {I've heard the "get in and floor it on the interstate for an hour" technique....don't believe I like that one"}
  2. Jan 3, 2012 at 8:48 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Well, every engine is broken in from the factory. But it is a good idea to drive your brand new truck easy for a few hundred miles. That's what I did and had no problems.. It's also good to change the oil.
  3. Jan 3, 2012 at 8:51 AM
    Lunercrab
    Lunercrab Well-Known Member
    Beth
    Lehigh Valley area, PA
    2019 off road cement
    I've gotten so many different responses. The guy From the dealership told me like for instance the vvti engines learn the way u drive. So he said he tells people drive it exactly how u would the second u leave the lot.
  4. Jan 3, 2012 at 10:02 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    The computer can re learn a new driving style if you simply unplug the battery, then re connect and drive. :cool:
  5. Jan 3, 2012 at 10:06 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    My manual read dont put the engine under heavy load ( full throttle ) or tow for the first 500 miles.
  6. Jan 3, 2012 at 10:10 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Babying your new engine does nothing for the engine. If anything it keeps the rings from properly seating. The key factor for the first 500 miles is to not drive at a long constant speed (think cruise control on a long road trip), vary the speed constantly with acceleration and deceleration using the engine to brake.
    The cams and crank are for the most part pre-broke in from the factory, proper ring seating is the major reason for a break in period as well as just minor deburring and flushing of the engine.
    If anything is going to go wrong its usually quite early in the process. After 500 miles your fine driving like normal but I would still avoid heavy towing for a while longer.
    By contrast my race engines on my motorcycles are broken in with a couple low throttle pulls on a dyno and then once warm and the basic brake in is complete a half dozen full throttle full load pulls all the way to the rev limiter. That being said, those engines are only expected to last me a year and a few thousand miles before being rebuilt so..
  7. Jan 3, 2012 at 12:57 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I just drove mine normally. I didn't do any heavy towing or hauling but only because I didn't have a reason to.
  8. Jan 3, 2012 at 1:10 PM
    Ohbrian
    Ohbrian Taco Roja
    Brian
    Fremont, CA
    04 PreRunner
    Eclipse head unit,scratched paint,ripped seat, black chaos 6 rims, Bilstein 5100's, top plate spacers, AAL, Midget antenna, Bakflip G2 cover, 14" Magnaflow, 400W inverter, LR UCA's
    I say drive it like you stole it. No need to break anything in.
  9. Jan 3, 2012 at 3:34 PM
    yak619
    yak619 Member
    I'm breaking in mine just by varying the speed (not taking too much highway). Every once in a while I get on it a little bit for a short burst.
    Couldn't find anything in the manual other than this:
    Break-in schedule
    If your vehicle is new or equipped with any new power train components
    (such as an engine, transmission, differential or wheel bearing), Toyota recommends
    that you do not tow a trailer until the vehicle has been driven for
    over 500 miles (800 km).
    After the vehicle has been driven for over 500 miles (800 km), you can start
    towing. However, for the next 500 miles (800 km), drive the vehicle at a
    speed of less than 50 mph (80 km/h) when towing a trailer, and avoid full
    throttle acceleration.
    Here's the 2012 manual in pdf, i just did a search for 'break'.
    http://www.toyota.com/owners/web/pa...neportlet_javax.portlet.action=processRequest
  10. Jan 3, 2012 at 3:38 PM
    Aw9d
    Aw9d That one guy
    I drove mine like a grandma till about 1500 miles, then I started getting on it till about 2500miles, now I consider it broken in.
    We did this same thing with my wife's 2000 Civic Si. Still on stock motor (and clutch, which she learned to drive stick on) and it has 185,000 miles, no issues, compression is still killer on it.
  11. Jan 3, 2012 at 3:44 PM
    Tbones taco
    Tbones taco Well-Known Member
    Tony
    Carrollton
    07 PreRunner ext cab
    Flowmaster 40 smittybuilt bull bar smittybuilt nerf bars hella lights crome custome grill
    Listen these trucks are not equipped with a race ready motor. If it were than there is a proper break in method. Its a Toyota drive it the way you drive. no need to baby it. Hell if anything goes wrong its under warranty. They are broken in at the factory.
    Just my two cents.
  12. Jan 3, 2012 at 3:50 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I took it easy on mine and just drove it like normal. Did my first oil change at about 1K to try and get rid of the metal shavings from the new engine components.
  13. Jan 3, 2012 at 6:30 PM
    Commanderwiggin
    Commanderwiggin Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    Drove it pretty hard for the break-in...I've got 1100km on it now and I'm changing the oil early just being preventative. I like to break my new engines/vehicles in hard to seat everything properly.
  14. Jan 3, 2012 at 10:19 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    well, the dealer i purchased from drove my vehicle 200 mi. (had to swap w/ another dealer), before changing hands to me.. so, hopefully they didn't screw anything up :D since then i've been kinda babying it, no hard accel, just some moderate accel here an there, ...light/mod braking, also a good deal of hwy mi. too (includes commute back/forth to work)
  15. Jan 3, 2012 at 10:35 PM
    johnanm
    johnanm Well-Known Member
    Up
    2011 Double Cab 2.7L Prerunner
    Bilstein 5100 @ 1.75" front shocks on stock springs, AFE ProDry drop-in, white DTRLs, Sylvania ZXE headlamps, DeeZee bed mat, Tailgate hose clamp mod, cheap snap craigslist tonneau, Weathertech vent visors, secondary air filter removed, Class III hitch
    You drive less than 2,000 miles a year? You must not do anything during the week!
  16. Jan 4, 2012 at 4:24 AM
    tpr676
    tpr676 Well-Known Member
    My dealer put a sticker in the windshield stating 5000 miles before my first oil change now that's a break in.
  17. Jan 4, 2012 at 4:31 AM
    396tears
    396tears Well-Known Member
    did we really need a detailed description of the boat
    LOL
  18. Jan 4, 2012 at 6:20 AM
    Alan in GA
    Alan
    just be glad I didn't start describing my last fishing outing in it,...with pictures! HA!
    Side note: have not tried it yet, but it looks like the tailgate cam will show me exactly how far to back up to the trailer coupling!!! With my previous truck, the Nissan 2000 Frontier 4x4 [more 'extra info' LOL]...I had to get out and back in the driver's seat several times, walking back to see the hitch ball/ trailer coupling alignment!
  19. Jan 4, 2012 at 1:22 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Just drive it normal. I advise not to tow or do any real off roading with it for the first 500 miles. These new engines are pretty much broken in from the factory
  20. Sep 28, 2015 at 6:13 AM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I've seen multiple people state they change the oil right after they take it off the lot. Is there any real reasoning behind this? Or just something people like to do. I could see changing the oil after the initial 500-1000 mile "break in" Is that more what you're referring to?
