New truck, exhaust question
Discussion in 'Performance and Tuning' started by GEORGE STRAIT, May 21, 2012.
  1. May 21, 2012 at 8:52 AM
    GEORGE STRAIT
    GEORGE STRAIT [OP] (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    Hey y'all. I just bought a 2011 regular cab 4x4 yesterday and couldn't be more excited. I'm already lookin at different things to add to my new taco. I had a question for all you performance junkies out there. Obviously my reg cab is a little underpowered, given it only has 159hp. I was hoping to add a little power to the truck just to aid me if I ever need to tow anything or just need a little extra juice. I considered getting a flowmaster exhaust and maybe an air intake/ and performance filter. I've seen people on this forum put flowmasters on their V6's, but haven't seen much about putting them on the I4's. Do you guys think it would be beneficial to put an exhaust on it, or would it just be a waste of money?
  2. May 21, 2012 at 8:53 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    You won't gain much for power with intake and exhaust. Headers + intake + exhaust might get you some, but probably not worth the cost.
  3. May 21, 2012 at 9:09 AM
    GEORGE STRAIT
    Da Magic City, AL
    That's what I figured. I guess if I wanted power I shoulda got the V6 :eek:
  4. May 21, 2012 at 9:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    www.lceperformance.com
    I believe that they have a header for your engine. It will be a nice bump in power alone. Others with your engine have testified to that.
    www.urdusa.com has a Supercharger kit I believe. That will definitely help boost up you towing torque.
    Check those two sites. Talk with them about the intakes. If the factory design was very restrictive, then there will be a gain from an aftermarket intake.
  5. May 21, 2012 at 9:32 AM
    GEORGE STRAIT
    Da Magic City, AL
    Thanks, that is actually very helpful
  6. May 21, 2012 at 9:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Accurate knowledge is power my friend. I am glad to help. :thumbsup:
  7. May 21, 2012 at 9:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
  8. May 21, 2012 at 9:47 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    That is good info provided above.
    Check out my build page for header, exhaust, and CAI mods. There are plenty of pics and vids on the first page.
