New truck, first scheduled oil change at 10,000... really?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by birdbrooks, Nov 14, 2019.
  1. Nov 20, 2019 at 3:37 PM
    #521
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    This works fine and sometimes makes things last longer. And lubricants are expensive.
  2. Nov 20, 2019 at 3:38 PM
    #522
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    It works for my butt-hurt.:anonymous:
  3. Nov 20, 2019 at 3:51 PM
    #523
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    I tried to drive with my windows down, but all the panties being thrown at me kept hitting me in the face.
  4. Nov 20, 2019 at 3:53 PM
    #524
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    No offense taken brah, math and science don't lie no grasping required its not that complicated
    That’s like saying you’re only going to drive 3500k miles instead of 5500k or two logs vs three (one less room to heat) so no.
    Less btu’s=Less ash, yes.
    Here’s the thing with carburetor vs fuel injection, it does not change the air to fuel ratio for a more ideal combustion.
    But if you believe it does, please show me the science.
    All that fuel injection does is that it keeps the fuel delivery at a more constantly accurate 14.7:1 ratio that we need for more efficient combustion.And that's a fact.
    But you are still only burning 20-30% of the fuel, so you still get the same amount of the resulting by-product that needs to be cleaned out by changing the oil just like in the old days. and that's a science.
    That said, because newer oils are much better and engines are better made with better tolerances, it may last longer if you don’t change it than with the older designs.
    I normally just need a beer after work, but here I need a double scotch whisky and its not even Friday!
    Hope that helps
    Superdave1.0 likes this.
  5. Nov 20, 2019 at 4:07 PM
    #525
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  6. Nov 20, 2019 at 4:16 PM
    #526
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    Tighter tolerances on cylinders and pistons reduces blow by, pushing more out the exhaust and less into your oil. Synthetic with modern additives is also better at dealing with contaminants. You're acting like 100% of fuel combustion is pumped straight in to the oil, and there's nothing you can do to reduce it, and there have been zero advancements in oil in the last 30 years.
  7. Nov 20, 2019 at 4:24 PM
    #527
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    We aren't talking about thermal efficiency, we are talking about how complete the combustion is, at what temperatures, how fast, etc. All of those things have an effect on the combustion products. With better engine controls, we have better control over combustion, and can make it cleaner and more complete.
    It's sorta like when you run an engine rich and it puffs out nasty black smoke, but when you get it running at the proper stoichiometric ratio, it burns cleanly - only more subtle. Same fuel, way different results.
  8. Nov 20, 2019 at 4:44 PM
    #528
    0xDEADBEEF
    I collect them in a basket and wring them out over a funnel into my engine. Best lubricant nature ever created.
  9. Nov 20, 2019 at 4:45 PM
    #529
    Stocklocker
    17TRDORDCSBAT
    You are a brave person taking this on with our buddy hammer. It was my life’s work, but I am spent. I am laying down my sword, knowing in my heart I fought for truth and justice.
  10. Nov 20, 2019 at 4:47 PM
    #530
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    But do you have sources for this info?
    The hammer and GreyBaldTaco like this.
  11. Nov 20, 2019 at 4:49 PM
    #531
    Stocklocker
    17TRDORDCSBAT
    supmet, The hammer, GillyLink and 3 others like this.
  12. Nov 20, 2019 at 5:09 PM
    #532
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Engine swap!
  13. Nov 20, 2019 at 5:18 PM
    #533
    Stocklocker
    17TRDORDCSBAT
  14. Nov 20, 2019 at 5:23 PM
    #534
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    The current Camry 4 cylinder has used 0/16 for two and a half years now.
    The more recently introduced RAV4 and Corolla now use it as well
  15. Nov 20, 2019 at 5:26 PM
    #535
    Stocklocker
    17TRDORDCSBAT
    I’m sure hammer will recommend 3k max interval on those bad boys.
  16. Nov 20, 2019 at 5:46 PM
    #536
    Superdave1.0
    SoCal
    Wouldn't tighter tolerances in the cylinder bore cause more metal to metal contact? Also modern additives in synthetics cannot magically break down metal particles. Yes synthetics might be more efficient at combating sludge and carbon, but not solid matter like sand, dirt, metal particles.
    BSFord likes this.
  17. Nov 20, 2019 at 6:03 PM
    #537
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    No, but modern oil filters magically trap solid matter like sand, dirt and metal almost immediately.
    Stocklocker and GreyBaldTaco like this.
  18. Nov 20, 2019 at 6:18 PM
    #538
    The hammer
    As far as combustion efficiency goes, yes, that’s pretty much on target.
    Stick around :D
    We don’t have better control over combustion, it’s still only at 20-30% efficiency with 70-80% still going as waste or by-products as before. Easy to look it up.
    When you say “we have better control over combustion” you are only supplying the optimal amount of air to fuel or 14.7:1 ratio because anything less hurts performance and anything more is waste. That would also be like saying a fire log is going to leave less ash because it is getting the right amount of air during combustion.
    That’s never going to happen, combustion efficiency as of this moment is what it is and there’s nothing we can do, except get it the right amount of air/fuel ratio so it burns to its most efficient. But I guarantee you will still have about the same by-products left as before.
    That said and combustion being what it is, what we do with the energy produced is what has changed.
    We insulate homes better, and we go farther with the automobile by using better tires (radial) than before, we produce more power from the same combustion energy with better lubrication and better tolerances so we go farther with the same gallon.
    But that same gallon still leaves behind the same amount of waste behind as by-products of un-burned fuel
    Stocklocker and BSFord like this.
  19. Nov 20, 2019 at 6:40 PM
    #539
    0xDEADBEEF
    Your mental model of what's going on in there is entirely too simplistic. It is far more complicated than burn gas, get heat. But we've all tried, and failed. Oh well.
    :frusty:
  20. Nov 20, 2019 at 6:43 PM
    #540
    The hammer
    You want me to go the maximum amount allowed (10k miles) before I change my oil I know, but I won't tow to the limit of 6400lbs either if it's any consolation, so there's that
    Cheers
