New truck, first scheduled oil change at 10,000... really?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by birdbrooks, Nov 14, 2019.
  1. Nov 21, 2019 at 7:50 AM
    #561
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    How do you know the oil is "cleaner"?
    If your filter is in place, how could this be true?
    Please do not refer to oil darkness or color as a response.
    Go.
    Stocklocker, GreyBaldTaco and TFly like this.
  2. Nov 21, 2019 at 7:56 AM
    #562
    Mr. Excitement
    Mr. Excitement Well-Known Member
    J
    Custom floormats, fuzzy dice
    My old MINI Cooper was at the dealership to replace the main seal. They drained the oil, replaced the seal, and put the old oil back in. I was disgusted!!! Thats like picking a booger, looking at it for a while, then just putting it back in your nose. Animals I tell ya!!!
    Junkhead, Stocklocker, BSFord and 2 others like this.
  3. Nov 21, 2019 at 7:56 AM
    #563
    mike2810
    mike2810 Well-Known Member
    Arizona - Rim Country
    had 06 Sport 4x4 , now 2016 Nissan Pro 4x
    What about it? One could ask you the same thing. What is your responsibility to the environment? Do you use a vehicle to get around? What type is it? How have you reduced your fossil fuel use?
    I change my oil every 6 months as my Frontier manual calls for. I rarely hit the recommended miles. I drive less than 7500 miles a year. That is how I help the environment. :rofl:
    Superdave1.0 and The hammer like this.
  4. Nov 21, 2019 at 8:19 AM
    #564
    BIGorca4419
    BIGorca4419 Member
    Georgetown Texas
    2019 cement grey Tacoma LB TRD off road
    None yet
    I don’t think proof is needed. I doubt they would assemble a truck and pop a motor in then pray it starts. In assembly of the motor each has to meet some type of quality standard. I know for a fact that’s how brand new motorcycles are assembled. I should look into it though I’m curious now what they do to insure the motor is sound.
  5. Nov 21, 2019 at 8:23 AM
    #565
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Cranking one up for a function check and putting it on a dyno are two different things.
    I don't know what they do for these engines, but I can't imagine each one going on a dyno. My guess would be a random one is selected at random times per shift to be dyno tested, all others just go down the line and get started up, gears checked and on the ready line.
  6. Nov 21, 2019 at 8:24 AM
    #566
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I doubt they'd go through the trouble of all that setup for each and every engine. I'd be willing to bet that the first time it starts is when they drive it off the assembly line. If they designed it well and their assembly procedures are good (which Toyota is really really good at), there is no reason an engine wouldn't be ready to roll.
  7. Nov 21, 2019 at 8:25 AM
    #567
    BIGorca4419
    BIGorca4419 Member
    Georgetown Texas
    None yet
    i could see that.
    daddy_o[QUOTED] likes this.
  8. Nov 21, 2019 at 8:28 AM
    #568
    BIGorca4419
    BIGorca4419 Member
    Georgetown Texas
    None yet
    Yeah I guess in hindsight that would be a lot of trouble to go through.
  9. Nov 21, 2019 at 8:35 AM
    #569
    0xDEADBEEF
    Yeah. The electrical stuff is easy, but fuel and antifreeze are a mess. I'm sure it could be optimized, but Toyota is the type of company that would rather put that effort into just making sure they don't build a dud in the first place.
    BIGorca4419[QUOTED] likes this.
  10. Nov 21, 2019 at 8:41 AM
    #570
    0xDEADBEEF
  11. Nov 21, 2019 at 9:00 AM
    #571
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    fuel injection has reduced gas wash which used to be a problem with a not so efficient carb. old oils didn't have the additives that clean inside the engine, newer oils don't sludge up like older oils did.new oils suspend contaminates better . add that to better materials, better machining and you can go longer between oil changes.
    just like the wood stove you refer to.. you get a lot less ash with dry quality wood along with a lot more heat so a lot less cleaning out. use a not so quality wood and not properly seasoned wood it becomes less efficient (less heat) creates more ash and creosote in the stack..
  12. Nov 21, 2019 at 9:11 AM
    #572
    Mr. Excitement
    J
    So I should be using 93 octane?
    Rock Lobster and GreyBaldTaco like this.
  13. Nov 21, 2019 at 9:34 AM
    #573
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    That's a major waste. For an 18 gallon fill-up your ratio should be 5 gallons of 87, 4 gallons of 90, and 9 gallons of 93. Drive away enlightened and wave at the growing long line of angry peasants waiting to get their gas.
    0xDEADBEEF, BSFord and Superdave1.0 like this.
  14. Nov 21, 2019 at 9:36 AM
    #574
    Mr. Excitement
    J
    I wish my truck ran on rage. I would have a full tank by the time I got to work.
  15. Nov 21, 2019 at 9:40 AM
    #575
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
  16. Nov 21, 2019 at 9:40 AM
    #576
    daddy_o
    Bossier City, La
    But 87 and 93 mixed makes 90. Did you account for that in the ratio?
    Rock Lobster[QUOTED] likes this.
  17. Nov 21, 2019 at 9:49 AM
    #577
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    No I did not. Also 87 and 93 are performance rankings, not volumetric measurements. Mixing them gets you 180 octane, the best octane there is.
  18. Nov 21, 2019 at 9:51 AM
    #578
    Mr. Excitement
    J
    ^^^^^ True. I set my timing to 360 degrees using it and no pings!
  19. Nov 21, 2019 at 9:59 AM
    #579
    daddy_o
    Bossier City, La
    87 octane mixed with 93 octane in equal parts yields 90 octane. I thought you were a scientist.:D
  20. Nov 21, 2019 at 10:01 AM
    #580
    guru
    guru Well-Known Member
    Theo
    Ontario, Canada
    ** トヨタ・タコマ **
    You see, I am training my truck. I add 1 cup of water with every gasoline fill-up for on 1 month. Then I increase it to 2 cups per fill-up, then 4 cups etc...
    The truck doesn't even notice that I do this (I am a bit of a Ninja if I say so myself). This time next year, I will be filling up with (free!) water.
    Reading what all the experts in this thread have to say, I am thinking I am going to extend this experiment to my oil too. 0W20 is practically water already. Just taste it, you'll know what I mean.
