New truck new build
Discussion in '2nd Gen. Builds (2005-2015)' started by fireturk41, Apr 1, 2015.
  1. Apr 1, 2015 at 8:41 AM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Just bought a new 2015 taco
    I want to solid axle swap it, I have a toyota straight axle in the garage I'm going to use out of an 85 pick up
    I'm going to do the welding myself with my 110 stick welder from harbor freight.
    Can anyone help with a cheap parts my budget is $500
  2. Apr 1, 2015 at 8:55 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Just cut the front frame clip off pickup and graft it to taco frame, boom
  3. Apr 1, 2015 at 10:13 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    I only have the front clip from an 89 will that count?
  4. Apr 1, 2015 at 10:32 AM
    ajohnson
    Andy
    Charlotte, NC
    Well that is IFS, too. So would probly be more work. 79-85 frame would be easier. Or, if you want simple and cheap, you could use heavy duty zip ties and strap the axle to the bottom of the '15's control arms, wouldn't even have to weld. It worked on that one dude's lightbar.
  5. Apr 1, 2015 at 12:55 PM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    You are going to cut apart a 2015 truck? Install a SAS for 500 dollars with parts that are 30 years old?
    Sweet, post lots of pictures!
    I am in full support of this project. Do not listen to the haters!
  6. Apr 1, 2015 at 1:00 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    sounds like a bad idea. if you wanted to hack up a truck you should have got a used one.
  7. Apr 1, 2015 at 1:01 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    skip the leaf springs. Andy will have some extra exhaust tubing here shortly that you can probably pick up from him for cheap. nice big diameter would make for some strong ass links, and help fit your $500 budget.
  8. Apr 1, 2015 at 2:15 PM
    ajohnson
    Andy
    Charlotte, NC
    ^ hell yea, brilliant
  9. Apr 1, 2015 at 3:13 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Forget the 110 welder...you would do better with a couple of batteries and some slightly damp rod. Also, forget the exhaust tubing for links...simply sneak around and "borrow" a bunch of high lift handles...they would make much better links!
  10. Apr 1, 2015 at 4:01 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Good idea ^
    On an unrelated note, time to figure out how to put a lock on my hilift handle
  11. Apr 1, 2015 at 4:55 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    You're going to cut up a new truck.
    Well, go for it and good luck.
  12. Apr 1, 2015 at 5:08 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Drilled my first hole in my year-old 2014 this weekend and I almost cried. You sir have a mighty pair.
  13. Apr 1, 2015 at 5:33 PM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    april fools?
  14. Apr 1, 2015 at 8:33 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Got started today
  15. Apr 1, 2015 at 9:32 PM
    TRDMEDIC
    TRDMEDIC Well-Known Member
    Sacramento, CA
    14 DC OFFROAD
    I call bs. You're a seasoned member and post a build in the non build thread. Good try on the April fools.
  16. Apr 2, 2015 at 5:29 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Haha yes April fools, done a solid axle swap before but not with high lift jack handles and a $500 budget
