New Truck Owner: Lift advice needed!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomAthenaSport4x4, Mar 27, 2019.
  1. Mar 27, 2019 at 12:00 PM
    TacomAthenaSport4x4
    TacomAthenaSport4x4 [OP] Member
    2019 TRD Sport 4x4
    K&N Drop In Filter
    i want to do a very simple lift (3inch). Everyone is saying get the Bilstein 5100...is that all i need? Are they a universal shock? (Reason i ask that is becasue i see that they are being sold for under 300 for the 2015s and lower on Amazon) And where do i purchase these for a 2019? Thank you for all the help!
  2. Mar 27, 2019 at 12:04 PM
    SpeySquatch
    2016 TRD OR DCSB
    no, 3rd gen frontend weighs 300lbs more than the second gen. Shocks may be the same, but you will need different springs. Stock OR spring is 700#
    Also 3" is the max you can do before a drop bracket lift. If you care about longevity 2" is better for your CVs
    Gritto likes this.
  3. Mar 27, 2019 at 12:07 PM
    Papadave418
    Papadave418 Well-Known Member
    Go buy kings and never look back. Haha:crapstorm:
  4. Mar 27, 2019 at 12:08 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    What are you thinking about in the rear?
  5. Mar 27, 2019 at 12:19 PM
    TacomAthenaSport4x4
    2019 TRD Sport 4x4
    K&N Drop In Filter
    Didnt know there was difference. New to all this. Im looking for a lift to where it doesn't require a lot of other changes. I want to use the truck for easy/moderate off roading while still being a good daily driver
  6. Mar 27, 2019 at 12:22 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    Go with something around 2”. Far less potential for problems and should be sufficient for your needs. Bilstein 6112/5160 is a good intermediate option
  7. Mar 27, 2019 at 12:41 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Shocks don't provide lift, spring and coils do. So the coil or spring will determine your height. The front will require a coilover or strut assembly, the rear will require new leaf pack, add-a-leaf or something else.
    SpeySquatch and Gritto like this.
  8. Mar 27, 2019 at 12:50 PM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    I say keep it stock for now, it will handle your stated needs just fine as is. Save up for some coilovers, higher end shocks and complete rear leaf packs
    Gritto and JCOOR like this.
  9. Mar 27, 2019 at 1:53 PM
    Taco_Craig
    Craig
    A super cheap lift kit is going to be spacers in the front and blocks in the rear (literally just lifting your truck up and putting little metal spacers to make it higher). A little better is something like the coilover replacements in the front, some kind of new shock in the back, and some kind of add-a-leaf (AAL) for the rear. Without a block or AAL in the rear, you're going to end up with a heavy bro lean (staring at the sky).
    There are tons of complete kits at different price ranges.
  10. Mar 27, 2019 at 2:05 PM
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    I did Bilstein 8112/8100 and I love em. Buy once, cry once.
  11. Mar 27, 2019 at 2:13 PM
    INT.EGRATED
    INT.EGRATED Well-Known Member
    San Francisco, CA
    2006 Lexus GX470
    nationwide backorder until may...
  12. Mar 27, 2019 at 7:59 PM
    JCOOR
    TRD Burglar
    I believe @Wheeler's Off-Road Inc has been getting batches in recently
  13. Mar 27, 2019 at 8:52 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Call @HeadStrong Off-Road and ask them, bunch of :crazy:bozo’s here don’t know what they’re telling you :crapstorm:
    Well, some of them anyways :rolleyes:
    tacotroy17 likes this.
  14. Mar 27, 2019 at 9:18 PM
    JCOOR
    TRD Burglar
  15. Mar 28, 2019 at 9:50 AM
    Wheeler's Off-Road Inc Well-Known Member
    Grants Pass, OR
    Back ordered for now. No response from Bilstein yet.
  16. Mar 28, 2019 at 10:04 AM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I'm in the same boat. I haven't done a lift yet, but feel like I'd really rather be about 2" higher. I don't want to mess up the geometry or handling as it's my daily driver but also want some off road capability for roads similar to the pics below.
    Truth is, I have been on roads like that and some I'd say were worse (or better depending on your perspective) in my stock Tacoma and it did just fine. It's really a pretty capable vehicle off the lot. I do need to get some sliders and maybe skids and those are probably more important than a lift. I'd say drive it as is or better yet add sliders and see how it goes.
  17. Mar 29, 2019 at 11:55 AM
    TacomAthenaSport4x4
    2019 TRD Sport 4x4
    K&N Drop In Filter
    This is awesome. Thanks for that response brotha.
  18. Mar 29, 2019 at 12:15 PM
    Taco_Craig
    Craig
    Just keep in mind that the armor (skids, sliders, bumpers, etc.) is going to weigh you down and affect your approach angles/clearance... So even an inexpensive suspension lift is totally worth it, if only to accommodate the additional weight. And yes, this might be a little lame, but the lift is probably the single biggest cosmetic change you'll make. Even something in the 1.75" - 2" range (mine) really changes the look of the truck -- gives it a little more aggressive stance.
  19. Mar 29, 2019 at 12:18 PM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    That's why I went with the ARB/OME kit, just the nitrochargers not the BP-51s. Been very happy with it. I got the "heavy kit" with the 886 front springs since I added a steel bumper and winch.
  20. Mar 29, 2019 at 1:01 PM
    Ctupton
    Ctupton Well-Known Member
    And there it is.. beat me too it ;)
    Papadave418[QUOTED] likes this.
