New Truck Terrible Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dunchystudios, Aug 23, 2021.
  1. Aug 23, 2021 at 12:19 PM
    Dunchystudios
    Dunchystudios [OP] Member
    SoCal
    2023 White TRD Pro
    Hi guys,
    First time poster but long time lurker. I just bought my truck in June and it’s developed an issue where it makes loud screeching sounds (I think it’s the brakes) for about the first 100 feet or so as I am driving out of my complex. Some days it is worse than other but it almost always makes some kind of sounds now. The thing is it only makes the sound for the first 100 feet so when I took it to the dealer, they could not replicate the issue. I started recording some videos with the issue and have uploaded a few to Vimeo (link below). What do you guys think it could be?
    https://vimeo.com/591182338
    tacotoe likes this.
  2. Aug 23, 2021 at 12:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Are you using the brakes when it makes the noise? Does it do it in reverse with the brakes on?
    There may be a small rock that has gotten between the rotor/pads, rotor/splash shield, rotor/caliper, etc.
  3. Aug 23, 2021 at 12:23 PM
    Dunchystudios
    SoCal
    2023 White TRD Pro
    Most of the video I am off the brakes. Really just at the end by the gate.
    tacotoe likes this.
  4. Aug 23, 2021 at 12:23 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Yes ceramic brakes do that, they have to have some heat in them before they get quiet.
    If it really annoys you just drag the brakes the first 50ft.
    tacotoe and Dunchystudios[OP] like this.
  5. Aug 23, 2021 at 12:25 PM
    eurowner
    eurowner Duke Sky
    Scoty
    2021 Tacoma comes stock with ceramic brakes?
    tacotoe and RedWings44 like this.
  6. Aug 23, 2021 at 12:27 PM
    Key-Rei
    Key
    Florida
    I mean I'm sure they're not your high content ceramic carbon F1 brakes but it wouldn't surprise me.
    I've got ceramic brakes on my truck. From Toyota, made by Akebono for Toyota. They're not advertised as ceramic but they do have ceramic in them, if you go to the dealer they usually have at least two or three options of brake pads available for your truck the most expensive ones are supposed to be the 'ceramics'.
    tacotoe likes this.
  7. Aug 23, 2021 at 12:40 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Noise is not some normal ceramic brake noise . My truck has never made a noise like that . You obviously having something warped or not lubed properly . I would take that video to the dealer and have them Start tearing stuff down . Starting with the basics .
    Bleep100 and ndoldman59 like this.
  8. Aug 23, 2021 at 1:00 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Take it to the dealer, do advise the board what the issue was -
  9. Aug 23, 2021 at 1:01 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Had a similar issue with my wife's Avalon. Seems the rotors would "flash rust" overnight, and then with the first brake application in the morning they'd grind or squeal. Once the rust was scraped off by the pads they were fine from then on.
    Maybe that's what you're dealing with.
    Are you in a humid climate with heavy dew overnight?
    tacotoe likes this.
  10. Aug 23, 2021 at 1:02 PM
    Dunchystudios
    SoCal
    2023 White TRD Pro
    When I took it to the dealer for a break in oil change I showed them the video but they said they couldn’t do anything if they couldn’t replicate it. They suggested I leave the truck there for a few days so they could drive joy cold but wouldn’t cover a rental until they were sure it was a warrantee issue. I think I plan to call Toyota today.
    tacotoe likes this.
  11. Aug 23, 2021 at 1:06 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Do you apply your parking brake overnight?
    tacotoe likes this.
  12. Aug 23, 2021 at 2:00 PM
    Dunchystudios
    SoCal
    2023 White TRD Pro
    Thanks for the questions and recommendations. I do apply the parking brake overnight. I am located in San Diego CA.
    I’ve heard of the flash rust thing but the noise seems super excessive.
    tacotoe likes this.
  13. Aug 23, 2021 at 2:23 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Stock pads are semi-metallic.
  14. Aug 23, 2021 at 2:39 PM
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    Yea.. that's not normal on a new vehicle. Can't believe a dealer would give you push back on that.
    tacotoe and wilcam47 like this.
  15. Aug 23, 2021 at 2:53 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I've had my truck since mid May, not a peep. Was it my imagination or was there a correlation between the sound and suspension travel?
  16. Aug 23, 2021 at 2:59 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    My guess is brakes, but it’s hard to tell without hearing it first hand. They shouldn’t be making a giant racket unless they have rocks stuck in them or they rusted while sitting.
    wilcam47 likes this.
  17. Aug 23, 2021 at 3:02 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    That's not right...Hell, I'm deaf and could hear that.
    I'd pull the wheels and front calipers. Check for wear or rubbing.
    Edit... I first said "pull rotors" I'd pull calipers and inspect.
    Rexfordian13 likes this.
  18. Aug 23, 2021 at 3:18 PM
    Dunchystudios
    SoCal
    2023 White TRD Pro
    yes, there does seem to be some correlation between the suspension travel and noise. Most/loudest is when I am actually using the brakes.
  19. Aug 23, 2021 at 3:19 PM
    Dunchystudios
    SoCal
    2023 White TRD Pro
    BTW, I’ve emailed Toyota with this info and a link to the videos to see if that motivates my dealer to take it in.
    tacotoe likes this.
  20. Aug 23, 2021 at 3:25 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    You said complex.....so guessing you live in an apartment? If so, does it have an irrigation system? Sounds like your truck might be getting wet from that (typically early in the morning) then flash rust forms on the rotors
