New Truck Terrible Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dunchystudios, Aug 23, 2021.
  1. Aug 23, 2021 at 3:25 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Makes sense since your suspension will shift down a bit when you step on the brakes. I'm no mechanical expert by any means but don't rule out a suspension issue.
  2. Aug 23, 2021 at 3:29 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Heat shield or a small rock in the caliper
    Late Camaro likes this.
  3. Aug 23, 2021 at 4:10 PM
    Dunchystudios
    Dunchystudios [OP] Member
    SoCal
    2023 White TRD Pro
    I do live in a condo but no water or irrigation near the truck.
  4. Aug 23, 2021 at 4:12 PM
    Dunchystudios
    SoCal
    2023 White TRD Pro
    I would understand if it was constant but it is only about the first 200 feet or so.
    jmneill and wilcam47[QUOTED] like this.
  5. Aug 23, 2021 at 4:12 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    @Dunchystudios:
    My '21 TRD OR doesn't grind or squeal BUT the brakes are awfully 'grabby' for the first couple of applications in the morning, probably related to our Summertime humid climate here in CT.
  6. Aug 23, 2021 at 4:15 PM
    jasmits1
    jasmits1 Well-Known Member
    2018 DCSB Off Road 6MT
    Ironman FCP with SPC UCAs
    I'd get the rear drum's adjustment checked also, maybe came from the factory a couple ratchets tight.
  7. Aug 23, 2021 at 4:17 PM
    wilcam47
    Will
    Bourbon state
    Brake heat shield warms up and it moves away from the rotor. Ive personally had it happen. Ive read about others too. Im not saying its 100% it but worth checking out
  8. Aug 23, 2021 at 4:57 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Brakes never made that sound on any of my toyota pickups. Sounds more like a harmonic noise from something rubbing.
  9. Aug 23, 2021 at 5:05 PM
    eurowner
    eurowner Duke Sky
    Scoty
    :burnrubber:
    OmahTako likes this.
  10. Aug 23, 2021 at 5:11 PM
    Dunchystudios
    SoCal
    2023 White TRD Pro
    There is a little noise in reverse but not much. I only reverse out of my parking spot and then drive forward the rest of the way.
  11. Aug 23, 2021 at 5:18 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Rock, stone, pebble in one of the front back I g plates… caught between rotor and plate …
  12. Aug 23, 2021 at 6:02 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Sounds like a rear brake drum noise issue. Could be out of round, parking brake needs adjustment or some debris cough in there.
    I highly recommend you find another dealer, one that will show some initiative or interest in addressing the issue and since they get paid either way, I don’t understand their attitude so that’s no bueno.
    At any rate, get it looked at by a real pro and let us know the outcome.
    Good luck
    shakerhood and Dunchystudios[OP] like this.
  13. Aug 23, 2021 at 6:26 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    My first guess would be a dragging rear shoe due to the parking brake not releasing properly.
    Dunchystudios[OP] likes this.
  14. Aug 23, 2021 at 10:48 PM
    JMB711
    JMB711 Well-Known Member
    2000 Tacoma
    None
    Something rubbing up against the rotor heat shield maybe? Sounds to me the rotor shield is resonating. To me anyway it changes pitch as you move along.
    Dunchystudios[OP] and zoo truck like this.
  15. Aug 23, 2021 at 11:05 PM
    #35
    k20pham
    k20pham Well-Known Member
    KP
    2019 taco
    Can you confirm if noise is coming from the rear drums? I might have a similar issue with brake squeak. As you can see in the video, it is clearly coming from the rear drums. 2019 TRDOR this now occurs daily at 48k miles. Happens when pulling out of garage, crawl/city traffic. Only at low speeds when riding the brakes.
    I have extended warranty but dealer "cannot replicate". This video is after they have actually performed a drum brake clean/lubricate service. Additionally, the service manager even went as far as to check the axles for warpage as apparently is an issue in Tundras. No dice and I am left a bit frustrated.
    At this point, I live with this noise everyday when commuting. Would love to find the issue eventually.
  16. Aug 23, 2021 at 11:46 PM
    #36
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    welcome aboard and good luck! I think it's coming the rear drums.
  17. Aug 24, 2021 at 10:21 AM
    #37
    JMB711
    2000 Tacoma
    None
    Cant speak to what the dealer did as I wasent there..But the shoes ride up against the backing plate and those points need high temp brake grease.
    Or perhaps your pads and drums are glazed from forgetting to release the parking brake before driving. I went from 1st generation to 3rd gen tacoma and
    cant claim to have never ever always released the parking brake lever..Ha!
  18. Aug 24, 2021 at 11:56 AM
    #38
    k20pham
    KP
    2019 taco
    Very true! I also was not there in the service bay to truly know what they did. Since drums need to be cleaned and lubricated regularly, I would definitely need to take a look down there myself.
  19. Aug 24, 2021 at 1:00 PM
    #39
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    If it only does it on the first drive of the day u could drop it off the night before so they cculd test drive it in the morning. Doesnt need to be there multiple days
  20. Aug 24, 2021 at 3:10 PM
    #40
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    It doesn't sound like typical disc brake noise, so I'd shoot for taking a closer look at the drums first. I would have to imagine you are setting the parking brake at night? If so, try reversing a bit after releasing it and see what happens. Otherwise, if it were me I would try manipulating the parking brake slightly while driving at slow speeds like in your video and listen for any changes in the sound.
    If you are not setting your brake at night, try setting it hard and then letting it off.
