New truck wont go into 4wd low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeff3004x4, May 20, 2010.
  1. May 20, 2010 at 4:25 PM
    Jeff3004x4
    Jeff3004x4 [OP] Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    I posted this in another thread and didn't get any results, i did do a search which wasn't very helpful. I will call the dealer in the AM if I don't figure it out. I just took my GF for her first ride in my new truck, I was all excited to show her what 4wd low range was like, you know make the taco do some crawling up a dirt hill and stuff. I pushed the clutch in (all the way down) shifted it into 4wd Hi, pushed the switch in a little, and turned it to 4wd low.......beep beep beep beep wtf? Anyone have this problem? I read the manual I did everything correctly. I went from forward to reverse drove around and everything.............beep beep WTF????
  2. May 20, 2010 at 4:35 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    were you stopped?
  3. May 20, 2010 at 4:42 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    It may be an ESO problem :wave:. But I'm not sure how the manuals go into 4 low, I have and automatic.
  4. May 20, 2010 at 4:44 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    regardless of transmission i thought you had to be stopped and in neutral to engage 4lo. correct?
  5. May 20, 2010 at 4:47 PM
    Rainman998
    Rainman998 Well-Known Member
    "The QC" AZ
    SEXY 2010 Double Cab 4x4 TRD Off Road
    Waiting for my sugar mama to hook it up
    That is what I have always heard as well.
  6. May 20, 2010 at 4:47 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    Are you sure that it went into 4wd first before you tried to go to 4low ? you might try to drive a little in 4wd then try to shift to 4low. My transfer case was a little stubborn when new, they do work a lot smoother with some use.
  7. May 20, 2010 at 5:03 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    usually want to engage and drive alittle inbetween the settings of 2wd/4hi/4lo
    to engage 4lo, stop, put in neutral, then select. if it doesnt engage, put in gear and roll slightly back or forth usually does the trick.
  8. May 20, 2010 at 5:05 PM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    I was stopped thanks guys Im going to try again when I leave my GF's house tonight I have a steep dirt driveway I will try it when I get home. New Mexico thanks if I have any problems I will PM you. Hearing that other people had stubborn new transfer cases is reassuring I will update you guys tomorrow.
  9. May 20, 2010 at 5:12 PM
    whiskey101
    whiskey101 Well-Known Member
    Clarksville, TN
    '17 Super White 4WD TRD Off-Road
    Leer 100XQ
    I'd say pull that handy card out of the sun visor and follow it step for step and if that doesn't work, head to the dealership.
  10. May 20, 2010 at 5:36 PM
    BBiggs
    BBiggs Well-Known Member
    Brent
    Canada
    05 SR5 Access Cab
    I just got it!
    I was hoping to come in here and tell you that all you had to do was push the knob in a little, but I guess that won't help. Rats.
  11. May 20, 2010 at 7:03 PM
    MarineTacoDriver
    MarineTacoDriver Well-Known Member
    Brian
    Cherry Point
    09 SR5 4x4
    ARB front bumper, Warn M8000, ATO front/transmission/transfer case skids, Icon ext travel coilovers, Total Chaos UCA's, OME Dakar leaf springs, Bilstein/RCD 5100 3-4" lift shock, extended stainless brake lines, DrewFab shackle flip, rear ARB Airlocker, ARB air compressor
    You need to make sure the clutch is pushed ALL the way in. I (thought) had problems with my 4lo for a while, turns out i wasn't pushing the clutch to the full extent and that was why it wouldn't disengage.
  12. May 20, 2010 at 7:11 PM
    dougdiggler
    dougdiggler Member
    Doug
    Longview WA
    08 TRD Sport 6spd on 265's
    Husky Floor Mats, Leer Canopy
    I am not alone! This happened to me as well make sure the floormat is not in the way, clutch is pushed thru the floor and mine worked after that. I have an 08 and it will go from 2h to 4lo with no need to drive around.
  13. May 20, 2010 at 7:18 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    If you are having problems getting it too engage, just be aware it will most likely also cause problems when you try to disengage, I know mine does.
    If all else fails this is the one trick that works for me.
    If you get nothing but the beeping after several attempts Turn the little piece of shit selector knob to the desired function and shut off the truck for a few minutes, when you restart it many times it will be doing what the arrow on the little piece of shit knob symbol says it is supposed to be doing.
  14. May 20, 2010 at 8:01 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    I had the same problem. It wouldn't go into 4wd low, and when it finally did, I couldn't get it back out. I drove around a snowy parking lot at the VA for an hour stopping and trying...had the manual out and was doing everything right. Turns out, my after-market floor mats (only about 3/16" thick were the reason. The manual says to depress the clutch "all the way"....they mean ALL THE WAY!
  15. May 20, 2010 at 8:37 PM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    I came home put it in 4 hi at the end of my driveway drove up the driveway at the top I stopped pressed in the clutch switched it to 4low......Beep beep beep. I said fuck this parked the truck and now I'm going to bed. Tomorrow after work I will asses my floor mat situation. I think I am pressing the clutch in all the way, I am hoping once it goes into 4low it comes back out. I can't understand why my factory floor mats would get in the way when they are factory and hooked in there two little spots to hold them in place. Idk it's kind of pissing me off now, I'll hold off on yelling at the dealership I want to make sure I'm not being an ass and doing something wrong first.
  16. May 20, 2010 at 11:08 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    Both my '09 (manual) and '10 (auto) were stubborn when I first got them. Took a few trys back and forth to get the transfer case to shift. But after going back and forth between 4hi and 4lo a few times, shifted fine. Definitely have to have the clutch in, definitely have to be in 4hi, definitely have to be stopped.
  17. May 21, 2010 at 10:54 AM
    Brandon###
    Brandon### Well-Known Member
    I had the same problem with my truck, and mine is an auto. I was stopped, in neutral and turned the knob all the way to 4 lo. It started beeping and raising hell. I then put it in drive and let off the brake, to see if it would engage, and it suddenly did and it made a horrible banging/grinding noise. I put it back in neutral, then 2wd.
    Moral of the story: I think you have to engage 4hi first, then go to neutral, then to 4lo. Once I did that there were no beeps, and it went in smoothly.
  18. May 21, 2010 at 11:32 AM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    My goal after I get out of work is to go home and get my truck in 4 low lol I will try everything.
  19. May 21, 2010 at 12:17 PM
    stangkeip10
    stangkeip10 Well-Known Member
    Cincinnati
    '10 Magnet Gray 4x4 Access Cab SR5
    BHLM, Black OR TRD wheels, BFG Mud terrains, yellow wire mod, 5100s @ 2.5, toytec tsb aal
    i had the same problem with my 4cyl 5 speed. you have to be stopped and already in 4 hi. i litterally have to stand on my clutch for it to go into 4 low and make sure there is not a floor mat under it. try adjusting your clutch which is my weekend project.
  20. May 21, 2010 at 4:33 PM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    Well it works, and it works perfectly. I was doing something wrong, you guys helped me out big time thank you very much.
