NEW TSB, Whine Noise From Rear of Vehicle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Feb 7, 2018.
  1. Feb 7, 2018 at 10:00 AM
    Murrayb4
    Murrayb4 [OP] Internet Toyota Tech
    Downingtown, PA
    2017 Blazing Blue TRD Sport DCSB with 3 pedals
    Custom cracked windshield
    Its not just the driver!
    looks like i'll be doing a bunch of leaf springs again.
    i wonder if my parts manager will order the OR springs for my sport.
    TSB pdf attached.
    Atowns40, RebeccaT, Zip250 and 9 others like this.
  2. Feb 7, 2018 at 10:01 AM
    Murrayb4
    Downingtown, PA
    damn, should have searched first... its already in the thread regarding this noise
  3. Feb 7, 2018 at 12:08 PM
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    Yeah but it was only a image of the 1st page. You actually provided the entire TSB.
    Looks like no new springs for us DCLB.
  4. Feb 7, 2018 at 12:51 PM
    NJTaco08088
    NJTaco08088 Well-Known Member
    2017 DCLB SR5 4x4
    Doesn't include the sr5's,
  5. Feb 7, 2018 at 1:00 PM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Nor access cabs and any 2018's. I am hoping this is just the first wave of the TSB. I imagine they wouldn't want to recall every model at once. Start with the most popular models and move on down the list.:fingerscrossed:
    MOC221_ likes this.
  6. Feb 7, 2018 at 1:25 PM
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Thank you for posting this. There is hope for us OCD/noise sensitive Taco owners after all. :)
    shakerhood likes this.
  7. Feb 7, 2018 at 1:32 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yeah, I hope you're right. Access cab here and whining like crazy :mad:
  8. Feb 7, 2018 at 2:13 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    What is a TSB? Is it a mandatory recall?
    MOC221_ likes this.
  9. Feb 7, 2018 at 2:15 PM
    MOC221_
    Frank
    Technical Service Bulletin.
    You have to take your truck in and prove you have the problem, basically.
    If you don't do it before your warranty is up, or the dealer can't reproduce the symptom.. well ur facked.
  10. Feb 7, 2018 at 2:46 PM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Wait so let me get this straight. They have a new fix for it now that just released?
    tcjacado likes this.
  11. Feb 7, 2018 at 2:48 PM
    MOC221_
    Frank
    Fix might be the wrong term, but if it deadens the whine and nothing grenades down the road.. all good. It's for specific trucks though..
  12. Feb 7, 2018 at 2:50 PM
    LilTexan22
    2017 Tacoma
    Do you know why its only for specific models and not sr, sr5's, etc?
    MOC221_[QUOTED] likes this.
  13. Feb 7, 2018 at 2:57 PM
    MOC221_
    Frank
    "Some 2016 – 2017 model year Tacoma Double Cab 4WD vehicles equipped with a BD22 rear differential may exhibit a whine type noise from the rear of the vehicle. This condition may occur while driving around 50 mph at constant speed, slight acceleration, or slight deceleration and may be caused by rear differential vibration transferring through the chassis and body. Follow the Repair Procedure in this bulletin to address this condition."
    What all the horseshit in that document boils down to is this:
    That BD22 axle I believe is the 8.75" rear diff found in ORs (ALL), PROs (ALL), and also M/T trucks that are not OR/PRO. You cannot get an SR5 in M/T, but the SR you can (not the '18 though).
    Hiluxski, tcjacado and shakerhood like this.
  14. Feb 7, 2018 at 2:59 PM
    Critical05
    2017 DCLB TRD OR
    It's only for double cab with 8.75 rear end. The "all other except TRD pro, manual transmission" is where the sport, sr, and sr5 comes in. Those in manual transmission have the 8.75" rear end. OR and Pro automatics have 8.75" rearend, all other automatics have the smaller 8".
    Jeff Lange and MOC221_ like this.
  15. Feb 7, 2018 at 3:01 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Mine doesn't do this frequently but when it does it does drive my OCD bonkers and of course haven't been able to produce at the dealership... Hopefully I'll be able to reproduce it for the dealer in the next 10k miles so I can get this done for free vs. it becoming a more frequent problem later I have to either pay to get fixed or live with.
  16. Feb 7, 2018 at 3:05 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What’s a Dynamic Damper?
    MOC221_ likes this.
  17. Feb 7, 2018 at 3:09 PM
    MOC221_
    Frank
    Something that helps mask/deaden/block the whine I guess. They're treating the symptom and not the cause IMO..
  18. Feb 10, 2018 at 6:00 PM
    TacoWave
    TacoWave Well-Known Member
    Adam
    2017 Cement Tacoma Pro MT
    Maybe I’m missing something here, but what do the leaf springs have to do with the diff whine? It’s like replacing engine mounts to fix a cylinder knock.
    tacoguy88, Argo98 and over60 like this.
  19. Feb 10, 2018 at 6:09 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    But the SR Manual would have only been in Access Cab Configuration
  20. Feb 10, 2018 at 6:14 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The leaf springs are the component that is conducting the resonance. Any time you have rotating gearing there is going to be noise and vibration. In this case other components are amplifying the slight sound.
    Jeff Lange, MOC221_ and shakerhood like this.
